More temp probes
ScottT
More temp probes
Post by ScottT »
Is it possible to have more than 3 temperature probes on a Reef Angel?
Re: More temp probes
Yes, but the controller only has 3 ports.
You would need to splice an extension to have more ports.
The other thing that would need to be done is libraries changes. It's hard coded to only 3 probes right now.
ScottT
Post by ScottT »
Thank you,
I'm not up for that quite yet, but maybe one day. Three will do for now :-)
Piper
Post by Piper »
Roberto - Is there a limit on the probes if you splice like that?
I think just RAM memory constrains.
You will probably start seeing errors when the capacitance hits a certain level.
More cable = more capacitance and the pull-up resistor can't keep up to pull the data line as fast as the signal needs to be, which will cause errors.
At this point, I'm sure there are dedicated chips to pull-up the data line faster than a single resistor.
Piper
Post by Piper »
I'm still on chapter 1 in my Electronics for Dummies book so maybe I need to rephrase my question :) I can probably get away with 5 total if I wanted to, yes?
You should be fine with 5
