JEBO WP-40
Re: JEBO WP-40
Thanks. Maybe Tidal was not a good one for me to start with. I really just needed the changes with in what I had posted at 5:05. In order to help me identify where I needed the numerical values and the definitions. You DA man. I was also trying to figure what to type in feed mode toggle ports to turn off the PWMDaylight. I tried PWMDaylight, LEDPWMDaylight, PWM.SetDaylight (0)? IDK how else I would do it.
Re: JEBO WP-40
Wow, moving fast here.
Are you guys using the harness or doing your own cables mods?
Also, any idea on when the pre-ordered cables will be ready for delivery?
Re: JEBO WP-40
Change thisPaulturner911 wrote:Thanks. Maybe Tidal was not a good one for me to start with. I really just needed the changes with in what I had posted at 5:05. In order to help me identify where I needed the numerical values and the definitions. You DA man. I was also trying to figure what to type in feed mode toggle ports to turn off the PWMDaylight. I tried PWMDaylight, LEDPWMDaylight, PWM.SetDaylight (0)? IDK how else I would do it.
bitSet(ReefAngel.Relay.RelayMaskOff,Port5-1);
bitSet(ReefAngel.Relay.RelayMaskOff,Port6-1);
To
ReefAngel.PWM.SetDaylight( 0 );
And you could get rid of the tidal swell mode to this
ReefAngel.PWM.SetDaylight( speed );
Then the f loop would switch from full speed to 1/2 speed depending on the mode and you old play with th pump with a constant speed based on the memory setting.
Re: JEBO WP-40
Some people got theirs from the initial batch.jayathome wrote:Wow, moving fast here.
The next batch should be shipped early next week.
Re: JEBO WP-40
I'm using the harness. I was refreshing the order page for two hours straight waiting for them to show up just to make sure I got in on the initial batchjayathome wrote:Wow, moving fast here.
Re: JEBO WP-40
Ok, I ordered the very next day. Darn it. Guess I will just monitor until I get to play next week.
Re: JEBO WP-40
Okay so I've finally got some time to mess with my cable.
I would lie to start with the reef crest. Is it just as simple as pasting the reef crest mode in the custom code area? I'm assuming then I can adjust from custom memory location?
Can someone post the link to the wave pattern thread. Can't find it.
Re: JEBO WP-40
Add the wave pattern functions on that post to the end of your code until the next libs get released.
Then to use the wave pattern you want, your code should look like this:
ReefAngel.PWM.SetActinic ( ReefCrestMode(50,20,true) ); // ReefCrest at 50 +/- 20 in sync mode
ReefAngel.PWM.SetDaylight ( ReefCrestMode(50,20,false) ); // ReefCrest at 50 +/- 20 in anti-sync mode
Re: JEBO WP-40
Im getting invalid conversion error on this
//ReefCrest
if (mode=ReefCrestMode) {
} else {
ReefAngel.PWM.SetDaylight( speed / 2 );
//ReefCrest
} else {
Re: JEBO WP-40
Try this:
//ReefCrest
if (mode == ReefCrestMode) {
} else {
JEBO WP-40
It may not like speed / 2 the way its written. Try commenting it out for now..
Re: JEBO WP-40
Piper wrote:Try this:
//ReefCrest if (mode == ReefCrestMode) { ReefAngel.PWM.SetDaylight ( ReefCrestMode(50,20,false) ); // ReefCrest at 50 +/- 20 in anti-sync mode } else { ReefAngel.PWM.SetDaylight( speed / 2 ); }
Errors
ISO C++ forbids comparison between pointer & integer
//ReefCrest
if (mode == ReefCrest) {
} else {
This works...I removed the word MODE in this line
if (mode == ReefCrestMMode) {
As for the speed/2 Im not sure what it does( I think it runs at 50%) I just pulled it from the tidal swell that Lee was kind enough to provide.
JEBO WP-40
Yeah ReefCrestMode is the name of the function. The define is just ReefCrest
Re: JEBO WP-40
I tried this an got an error of "mode was not declared in this scope". Any ideas? I pasted this code in the custom code section....Paulturner911 wrote:Piper wrote:Try this:
Errors
//ReefCrest
} else {
Re: JEBO WP-40
Your missing this part.
int mode=InternalMemory.RFMode_read();
int speed=InternalMemory.RFSpeed_read();
int duration=InternalMemory.RFDuration_read();
Re: JEBO WP-40
[quote]
#include <[color=#CC6600]Wire[/color].h>
#include <[color=#CC6600]OneWire[/color].h>
#include <[color=#006699]LED[/color].h>
#include <[color=#006699]Relay[/color].h>
#include <[color=#006699]Timer[/color].h>
#include <[color=#006699]Salinity[/color].h>
#include <[color=#006699]RF[/color].h>
#include <[color=#006699]IO[/color].h>
#include <[color=#006699]ORP[/color].h>
#include <[color=#006699]AI[/color].h>
#include <[color=#006699]PH[/color].h>
#include <[color=#006699]WaterLevel[/color].h>
#include <[color=#CC6600]ReefAngel[/color].h>
[color=#7E7E7E]////// Place global variable code below here[/color]
[color=#7E7E7E]////// Place global variable code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]()
[color=#7E7E7E]// This must be the first line[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]Init[/color](); [color=#7E7E7E]//Initialize controller[/color]
[color=#7E7E7E]// Ports toggled in Feeding Mode[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]FeedingModePorts[/color] = [color=#006699]Port5Bit[/color] | [color=#006699]Port6Bit[/color];
[color=#7E7E7E]// Ports toggled in Water Change Mode[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]WaterChangePorts[/color] = [color=#006699]Port5Bit[/color] | [color=#006699]Port6Bit[/color] | [color=#006699]Port7Bit[/color] | [color=#006699]Port8Bit[/color];
[color=#7E7E7E]// Ports toggled when Lights On / Off menu entry selected[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LightsOnPorts[/color] = [color=#006699]Port1Bit[/color];
[color=#7E7E7E]// Ports turned off when Overheat temperature exceeded[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]OverheatShutoffPorts[/color] = [color=#006699]Port2Bit[/color] | [color=#006699]Port7Bit[/color];
[color=#7E7E7E]// Use T1 probe as temperature and overheat functions[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]TempProbe[/color] = [color=#006699]T1_PROBE[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]OverheatProbe[/color] = [color=#006699]T1_PROBE[/color];
[color=#7E7E7E]// Ports that are always on[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port5[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port6[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port8[/color] );
[color=#7E7E7E]////// Place additional initialization code below here[/color]
[color=#7E7E7E]////// Place additional initialization code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]loop[/b][/color]()
[color=#CC6600]ReefAngel[/color].[color=#CC6600]DayLights[/color]( [color=#006699]Port1[/color] );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]ActinicLights[/color]( [color=#006699]Port2[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Set[/color]( [color=#006699]Port3[/color], ![color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Status[/color]( [color=#006699]Port1[/color] ) );
[color=#CC6600]if[/color] ([color=#CC6600]ReefAngel[/color].[color=#006699]HighATO[/color].[color=#CC6600]IsActive[/color]())
[color=#CC6600]ReefAngel[/color].[color=#CC6600]SingleATOLow[/color]( [color=#006699]Port4[/color] );
[color=#CC6600]else[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]Off[/color]( [color=#006699]Port4[/color] );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardHeater[/color]( [color=#006699]Port7[/color] );
[color=#7E7E7E]////// Place your custom code below here[/color]
[color=#7E7E7E]////// Place your custom code above here[/color]
[color=#7E7E7E]// This should always be the last line[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]Portal[/color]( [color=#006699]"SeedlessOne"[/color] );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]ShowInterface[/color]();
[color=#CC6600]void[/color] DrawCustomMain()
[color=#CC6600]int[/color] x,y;
[color=#CC6600]char[/color] text[10];
[color=#7E7E7E]// Parameters[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawMonitor[/color]( 15, 20, [color=#CC6600]ReefAngel[/color].[color=#006699]Params[/color],
[color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]GetDaylightValue[/color](), [color=#CC6600]ReefAngel[/color].[color=#006699]PWM[/color].[color=#CC6600]GetActinicValue[/color]() );
#else [color=#7E7E7E]// defined DisplayLEDPWM && ! defined RemoveAllLights[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawMonitor[/color]( 15, 20, [color=#CC6600]ReefAngel[/color].[color=#006699]Params[/color] );
#endif [color=#7E7E7E]// defined DisplayLEDPWM && ! defined RemoveAllLights[/color]
[color=#CC6600]pingSerial[/color]();
[color=#7E7E7E]// pH Expansion[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color]( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,66, [color=#006699]"PHE:"[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color]( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,66, [color=#CC6600]ReefAngel[/color].[color=#006699]Params[/color].[color=#006699]PHExp[/color] );
[color=#7E7E7E]// Water Level[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color]( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, [color=#006699]"WL:"[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawText[/color]( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, [color=#CC6600]ReefAngel[/color].[color=#006699]WaterLevel[/color].[color=#CC6600]GetLevel[/color]() );
[color=#7E7E7E]// Main Relay Box[/color]
[color=#CC6600]byte[/color] TempRelay = [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayData[/color];
TempRelay &= [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayMaskOff[/color];
TempRelay |= [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#006699]RelayMaskOn[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawOutletBox[/color]( 12, 92, TempRelay );
[color=#7E7E7E]// Date and Time[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LCD[/color].[color=#CC6600]DrawDate[/color]( 6, 122 );
[color=#CC6600]void[/color] DrawCustomGraph()
[/quote]
Can you help me out on this code section or post your code so I can see where exactly you guys are placing this code. I would like to just get this one in reefcrest mode. Thanks for the help....
Re: JEBO WP-40
Take a look at the code here...and try reading the past couple of pages.,, we just did the same
http://forum.reefangel.com/viewtopic.php?p=22903#p22903
Sent from my GT-P31 thing... 13 using Tapatalk 2
Re: JEBO WP-40
Sadly I've read that more than once. Still missing something. Back to the chalk board.lnevo wrote:Take a look at the code here...and try reading the past couple of pages.,, we just did the same
JEBO WP-40
Just look where this code is...
This will fix the error you reported...
Re: JEBO WP-40
The code you pasted is coming up wrong so I can't modify it easily to put in the code you need....
Re: JEBO WP-40
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port7Bit;
ReefAngel.DayLights( Port1 );
ReefAngel.ActinicLights( Port2 );
ReefAngel.Relay.Set( Port3, !ReefAngel.Relay.Status( Port1 ) );
ReefAngel.SingleATOLow( Port4 );
ReefAngel.Relay.Off( Port4 );
ReefAngel.Portal( "SeedlessOne" );
int x,y;
// Parameters
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,66, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,66, ReefAngel.Params.PHExp );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel() );
// Main Relay Box
// Date and Time
LOL sometimes the RA makes me feel like a complete noob. Own an IT consulting business and consider myself a bright guy but seem to trip all over this coding....
Re: JEBO WP-40
ReefAngel.PWM.SetActinic (ReefCrestMode (speed, duration, true);
ReefAngel.PWM.SetDaylight(ReefCrestMode (speed, duration, false);
int x,y;
// Parameters
// pH Expansion
// Water Level
// Main Relay Box
// Date and Time
// add the reefcrestmode function here
Speed and duration in the vortech mem location should now set your pwm ports to whatecer values you add. The duration value will be the intensity of the mode, amd if you have two pumps they will be in anti sync.
Sent from my GT-P3113 using Tapatalk 2
Re: JEBO WP-40
int x,y;
// Parameters
// pH Expansion
// Water Level
// Main Relay Box
// Date and Time
// byte ReefCrestMode(byte WaveSpeed, byte WaveOffset, boolean PulseSync)
static unsigned long lastwavemillis=millis();
static int newspeed=WaveSpeed;
if ((millis()-lastwavemillis) > 5000)
if (random(100)<50) newspeed--; else newspeed++;
newspeed=constrain(newspeed,WaveSpeed-WaveOffset,WaveSpeed+WaveOffset);
newspeed=constrain(newspeed,0,100);
if (PulseSync)
return newspeed;
return WaveSpeed-(newspeed-WaveSpeed);
Reefcrestmode not declared in the scope. If Im doing something extremely dumb, please excuse me.
Re: JEBO WP-40
Almost there! Near the bottom, where you pasted the ReefCrestMode, you need to remove the two slashes. That's commenting out that function.
From this:
To this:
From this:
Re: JEBO WP-40
Already tried taking those out. Received a different error. \Piper wrote:Almost there! Near the bottom, where you pasted the ReefCrestMode, you need to remove the two slashes. That's commenting out that function.
From this:To this:Code: Select all
Expected before token.
Re: JEBO WP-40
ReefAngel.PWM.SetActinic (ReefCrestMode (speed, duration, true));
ReefAngel.PWM.SetDaylight(ReefCrestMode (speed, duration, false));
Re: JEBO WP-40
Getting much closer. Uploaded just fine to my controller this time. Pump seems to just be running at a constant speed right now though.
Thanks for all the help so far everyone!!!
Re: JEBO WP-40
Does your display show you the PWM speed? That should tell you what speed your pump is running at. If you watch it you can see if the speed adjusts at all.
Re: JEBO WP-40
yup...and running at 100%.....
