What's your favorite function?
Ask in here.
I've heard people refer to controllers as glorified timers, but the RA is so much more than that. Now that I've turned all my customized code into self contained functions, I thought of a nice way for people to share small snippets of code that they've written. A little change from all the how to or eureka DIY projects.
Anyway, share your favorite function, block of code, library call, whatever it is that you love, are happy with, etc. it doesn't even have to be custom or written by you. So if you love ReefAngel.StandardHeater(), let's hear about it!
Here's my contribution. I threw this together to automate my water changes and I'm quite pleased with how self contained and simple it became. It took a few tweaks to get working properly, but was pretty unchanged from the initial concept. If I had the right plumbing, I could make this a continuous gradual change.
void autoWaterChange() {
  byte wcReady=InternalMemory.read(Mem_B_WaterChange); // Trigger to start
  int wcFillTime=InternalMemory.read_int(Mem_I_WCFillTime);
  // Start automatic water change here.
  ReefAngel.SingleATOHigh(Extension); // refill from SW bucket
  // Find out if we are ready to start
  if(wcReady)
    wcTimer.SetInterval(wcFillTime); // One bucket at a time
    wcTimer.Start();
    InternalMemory.write(Mem_B_WaterChange, 0);
    bitSet(ReefAngel.Relay.RelayMaskOff,ReactorBit); // Start draining
  if(wcTimer.IsTriggered())
    bitClear(ReefAngel.Relay.RelayMaskOff,ReactorBit); // Stop draining
So, let's see what you got!!
Re: What's your favorite function?
I believe I enjoy the simplicity of the PWMParabola and the many uses everyone has found for it. But that's my choice today...tomorrow it could be something else lol.
This is what I use on mine.
It allows you to create several screens and move through them using the joystick.
Mine in particular has all the parameter in the screen 0 using the large font.
Screen 1 has the relay statuses and graph.
You can increase the number of screens too, but I just need 2 :)
#define NumScreens 2
int ScreenID=0;
  switch (ScreenID)
  case 0:
      //Draw screen 0
      break;
  case 1:
      //Draw screen 1
      break;
  if (ReefAngel.Joystick.IsLeft())
    ScreenID--;
  if (ReefAngel.Joystick.IsRight())
    ScreenID++;
  if (ScreenID<0) ScreenID=NumScreens-1;
That's awesome! You just made my day with that one :) I can have my graphs back and much more room for info!!!
Edit: I think we could make a screen class to manage the number of screens and scrolling through... Just a thought :)
Keep sharing people!!
lnevo wrote: Edit: I think we could make a screen class to manage the number of screens and scrolling through... Just a thought :)
I'm not sure about creating a class for it, BUT I'm sure I can come up with something for the menu generator to allow for multiple screen creation based on that simple code logic. :geek: wouldn't that be nice??
00Warpig00
Post by 00Warpig00 »
Couldn't that same concept be used for nested menu's? top menu has say 3 options screen ID 1/2/3 select (2) and have screen ID 2 show you more options with say screen ID's 6/7/8/9 etc. treat the programming portion as one. I'm guessing the hard part comes in with selecting an option from the joystick...
Nick
180G FOWLR
20GH QT#1
29G QT#2
00Warpig00 wrote:Couldn't that same concept be used for nested menu's? top menu has say 3 options screen ID 1/2/3 select (2) and have screen ID 2 show you more options with say screen ID's 6/7/8/9 etc. treat the programming portion as one. I'm guessing the hard part comes in with selecting an option from the joystick...
The big part of this would be to know which menu has a submenu. Not to mention that each submenu has to have its own skeleton for functions pre-created so you can override them. If you just allow for 1 submenu for each entry item (so there's only 1 level deep). That's a maximum of 90 function skeletons (9 per menu item * 9 items on main menu plus 9 for the main menu) that would have to be added.
I'm not saying it can't be done, it just needs to be looked into further to see if there is a simpler way of doing things. :?
Bump! Lets see some cool stuff. Amazing the ideas from just a couple of posts!!! Keep em coming!
jsclownfish
Post by jsclownfish »
I'm a big fan of the multiple screens! :D
http://forum.reefangel.com/viewtopic.php?f=11&t=923
Jon
What Would make things simpler than submenus would be to have additional menu screens...the same as if you do with main screen you could just assign those menu items with more CustomMenu functions...
You could even do it right in the scrolling code
    if ( Joystick.IsDown() )
        // process DOWN press
        // > allows for selection of last item, >= skips it
        if ( (++SelectedMenuItem) > qty )
            // add switch to page 2...
            // we've hit the bottom of the list
            // wrap around to the top of the list
            // maybe take away ability to wrap.
            SelectedMenuItem = DEFAULT_MENU_ITEM;
        redrawmenu = true;
        menutimeout = now();
Would be nice to have another page of menus..
mls228
Post by mls228 »
rimai wrote:This is what I use on mine.
First post here, sorry for the newbie question, how would I incorporate this function into my code. I need a little help to get started, then I'll be on my way I'm sure. Thanks everyone.
Here is my current code:
    ReefAngel.FeedingModePorts = Port1Bit | Port4Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port4Bit;
    ReefAngel.StandardHeater( Port2,771,781 );
    ReefAngel.StandardLights( Port3,22,0,14,0 );
    ReefAngel.StandardATO( Port4,60 );
    ReefAngel.Wavemaker( Port5,60 );
    ReefAngel.PWM.SetDaylight( PWMSlope(13,0,22,0,15,100,60,15) );
    ReefAngel.PWM.SetActinic( PWMSlope(14,0,21,0,15,100,60,15) );
    ReefAngel.Portal( "mls228" );
Are you trying to get several screens in your code?
mls228
Post by mls228 »
rimai wrote:Are you trying to get several screens in your code?
Yes
May I suggest you start with with creating just one??
Then when you are familiar with creating the first one, we move to create additional ones?
http://forum.reefangel.com/viewtopic.php?f=14&t=109
