http access to Reef Angel
Xender
Post by Xender »
I've got error when I try to see the http page on Internet Explorer
It's says "Please wait Loading"
Librairies : V.8.5.16
My scketch :
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#define Pump1               8
#define DrainPump           7
#define Osmoseur            6
#define CO2                 5
#define Heater              4
#define Bubbles             3
#define Light2              2
#define Light1              1
// Labels for the web banner
#include <avr/pgmspace.h>
prog_char id_label[] PROGMEM = "xender";
prog_char probe1_label[] PROGMEM = "Water";
prog_char probe2_label[] PROGMEM = "NA";
prog_char probe3_label[] PROGMEM = "NA";
prog_char relay1_label[] PROGMEM = "Light%201";
prog_char relay2_label[] PROGMEM = "Light%202";
prog_char relay3_label[] PROGMEM = "Bubbles";
prog_char relay4_label[] PROGMEM = "Heater";
prog_char relay5_label[] PROGMEM = "CO2";
prog_char relay6_label[] PROGMEM = "RO%20Osmoseur";
prog_char relay7_label[] PROGMEM = "Drain%20Pump";
prog_char relay8_label[] PROGMEM = "Pump%201";
    ReefAngel.SetTemperatureUnit(1);  // set to Celsius Temperature
    ReefAngel.Relay.On(Port8);
    ReefAngel.StandardHeater(Heater,842,860);  // Setup Heater to turn on at 78.9F and off at 79.1F
    //WifiAuthentication("xender:test");
    ReefAngel.Timer[4].SetInterval(60);  // set interval to 120 seconds
    ReefAngel.Timer[4].Start();
  // Specific functions
  ReefAngel.StandardLights(Port1);
  ReefAngel.MHLights(Port2);
  ReefAngel.StandardHeater(Port4);
// Web Banner stuff
        ReefAngel.WebBanner();
//CO2
  if ( ReefAngel.Params.PH <= 600 )
    ReefAngel.Relay.Off(Port5);
  if ( ReefAngel.Params.PH >= 650 )
    ReefAngel.Relay.On(Port5);
//Bubbles
  if ( ReefAngel.Params.PH <= 580 )
    ReefAngel.Relay.On(Port3);
  if ( ReefAngel.Params.PH >= 595 )
    ReefAngel.Relay.Off(Port3);
//Chiller
  if ( ReefAngel.Params.Temp1 >=315 )
    ReefAngel.PWM.SetDaylight(100);
  if ( ReefAngel.Params.Temp1 <=300 )
    ReefAngel.PWM.SetDaylight(0);
  if (hour()>23 || hour()<7)
    ReefAngel.PWM.SetActinic(PWMSlope(23,0,7,0,0,MoonPhase(),90,ReefAngel.PWM.GetActinicValue()));
byte MoonPhase()
  int m,d,y;
  int yy,mm;
  long K1,K2,K3,J,V;
  byte PWMvalue;
  m=month();
  d=day();
  y=year();
  yy=y-((12-m)/10);
  mm=m+9;
  if (mm>=12) mm-=12;
  K1=365.25*(yy+4712);
  K2=30.6*mm+.5;
  K3=int(int((yy/100)+49)*.75)-38;
  J=K1+K2+d+59-K3;
  V=(J-2451550.1)/0.29530588853;
  V-=int(V/100)*100;
  V=abs(V-50);
  PWMvalue=4*abs(50-V); // 5.12=100% 4=~80%
  //pinMode(lowATOPin,OUTPUT);
  return (PWMvalue*100)/255;
Détails de l’erreur de la page Web
Agent utilisateur : Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 3.0.04506.30; .NET CLR 3.0.04506.648; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; .NET CLR 2.0.50727; .NET4.0C; .NET4.0E)
Horodateur : Sun, 4 Sep 2011 16:15:23 UTC
Message : 'x' a la valeur Null ou n'est pas un objet.
Ligne : 74
Caractère : 4
Code : 0
URI : http://www.reefangel.com/wifi/ra1.js
Fresh Water Aquarium 180*60*80
Salt Water Aquarium 60*60*60
Click Here to see the Video of my Fresh Water Aquarium
Re: http access to Reef Angel
Does any parameter show on the screen at all?
Xender
Post by Xender »
No parameters on the web page.
I see the parameters on the controler.
You CAN see it here : http://82.236.104.229:2000/wifi/
It's a bug.
I'm going to investigate.
The problem is on the calculation of the XML string length
The request is this:
GET /r99 HTTP/1.1
Accept: application/x-ms-application, image/jpeg, application/xaml+xml, image/gif, image/pjpeg, application/x-ms-xbap, */*
Accept-Language: en-US
User-Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; InfoPath.3; .NET4.0C; .NET4.0E)
Accept-Encoding: gzip, deflate
Host: 82.236.104.229:2000
Connection: Keep-Alive
And this is what I got:
HTTP/1.1 200 OK
Server: ReefAngel
Cache-Control: no-store, no-cache, must-revalidate
Pragma: no-cache
Connection: close
Content-Type: text/xml
Content-Length: 162
<RA><T1>303</T1><T2>0</T2><T3>0</T3><PH>674</PH><R>140</R><RON>0</RON><ROFF>255</ROFF><ATOLOW>0</ATOLOW><ATOHIGH>0</ATOHIGH><PWMA>50</PWMA><PWMD>0</PWMD></RA>
The 162 is wrong.
It's supposed to be 158.
This is good to know. I can never get the wifi page to work on my controller either and i just dealt with it. I was having the exact same problem.
Hey Curt,
I pushed the fix.
Can you try to see if it fixes the problem?
rimai wrote:Hey Curt,
I pushed the fix.
Still having the problem. Looking at the developer tools inside chrome & firefox, the error says "ra1.js:72 Uncaught TypeError: Cannot read property 'documentElement' of null".
So somewhere along the line the statement you do "x=a.responseXML.documentElement;" is null and it errors out.
I tested on firefox and it was working for me on Win7 x64.
Let me download chrome.
What happens when you browse /r99??
Do you get the correct and formated properly XML?
rimai wrote:What happens when you browse /r99??
the /r99 works fine for me. i've always gotten the proper results back from it. it's just browsing that wifi page does not work for me under all of my machines: 32bit xp-chrome & ie, 64bit linux-chrome & firefox
i get the same error on all of them about the documentElement being null. i made the exact same changes you sent me with the code, so i doubt it's the code.
Hey Curt,
Just out of curiosity, could you try loading standard libraries to see if you get same error?
Loaded the stock 0.8.3.13 from your github and still encountered the same error with the documentElement being null under both xp ie and linux chrome. I can view the /r99 command and get a nicely formatted XML structure though.
I tried Chrome 14, IE8, Firefox 6 and for some reason I can't get it to replicate the error. All tests were done on Win7 x64.
I used the online dev board you put up.
http://curtbinder.dyndns.info:2000/wifi
Let me try different machines
rimai wrote:I tried Chrome 14, IE8, Firefox 6 and for some reason I can't get it to replicate the error. All tests were done on Win7 x64.
I just tested Chrome 14 on my Win7 x64 laptop AND my desktop running Chrome 12 (ubunutu) to my dev board and it worked just fine. So, I don't know what is going on with it.
