Can someone post sample codes on how to control the aforememtnioned lights using the RA plus...
Thank you
Need Help promming my AI sols and Ecotech radion
ecam
ecam
Re: Need Help promming my AI sols and Ecotech radion
Yes i did. But i cant not get any of the functionality to show up on my display and i cannot control the blue and whites on the AI. I also cant get full functionality of the VOrtech while we are talking.
Sample codes would be really helpful to see how it all works. Thanks Roberto
rimai wrote:Did you try the wizard?
There is an example code in File->Sketchbook->Example Codes->CustomMain_AquaIllumination.
ecam
here is my current code. I went back to this b\c the wizard code was not working correctly
byte vtechmode;
boolean bFeeding=false;
ReefAngel.Init(); // Initialize Controller
ReefAngel.AddStandardMenu();
ReefAngel.AddDateTimeMenu();
ReefAngel.WaterChangePorts = Port1Bit | Port8Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
ReefAngel.FeedingModePorts = Port1Bit | Port6Bit | Port8Bit; // Turn off Ports 1, 6, 7 and 8 when Water Change Mode is activated
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit| Port5Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit |Port3Bit | Port4Bit | Port5Bit | Port7Bit; // Turn off Ports 3, 4 and 7 when overheat occurs
ReefAngel.RF.SetMode( NutrientTransport,85,10 );
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit| Port5Bit; // Turn on/off Ports 3 and 4 when Light On/Off menu option is selected
ReefAngel.Relay.On( Port1 ); // Return Pump
// Hardcode PH calibrations
ReefAngel.PHMin=544; // PH7.0
ReefAngel.PHMax=830; // PH10.0
ReefAngel.LCD.DrawLargeText(COLOR_STEELBLUE,COLOR_WHITE,28,121,"Edwin's Reef"); // Display Reef Angel banner
//Light instructions
ReefAngel.StandardLights( Port2,19,15,7,4 );//Refugium
ReefAngel.StandardLights(Port3,7,5,19,15); // T5s - High Noon
ReefAngel.StandardLights(Port4,9,5,17,0); // AI Sols - Regular
ReefAngel.StandardLights(Port5,9,5,17,0); // Ecotech Radions - MH
ReefAngel.StandardHeater( Port7,780,800 );
ReefAngel.Relay.DelayedOn( Port8,2 ); //Skimmer
//Light instructions (Start Hr,Min, End Hr, Min)
//ReefAngel.Wavemaker1(Port5); // Wavemaker 1
//ReefAngel.Wavemaker2(Port6); // Wavemaker 2
ReefAngel.PWM.StandardDaylight(); // Dimming for Daylight Channel
ReefAngel.PWM.StandardActinic(30); // Dimming for Actinic Channel
//-------------------------------------------------------- Start RF Nightmode Control ---------------------------------------------
if (hour()>=23 || hour()<7) // Defining "Nightmode" hours for VorTech = between 11 PM and 7 AM
ReefAngel.RF.UseMemory=false;
vtechmode = 9;
ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
ReefAngel.RF.UseMemory=true;
vtechmode = InternalMemory.RFMode_read();
//---------------------------------------------------------- End RF Nightmode Control ---------------------------------------------
byte vtechmode;
vtechmode = 9;
That doesn't have the aqua illumination code in it.
It's not even a code that the wizard would output.
Go through the wizard and generate a code and make sure you enable the aqua illumination and RF expansion module.
ecam
Okay Roberto... Here is the code from the wizard....
Now how do I show the current setting of my vortechs on my display and how can i toggle modes rfrom the controller\iphone app.
#include <RF.h>fa
// Setup ATO Port for AI communication
ReefAngel.AI.SetPort( lowATOPin );
ReefAngel.Relay.Set( Port2, !ReefAngel.Relay.Status( Port4 ) );
ReefAngel.StandardLights( Port3,11,0,15,0 );
ReefAngel.StandardLights( Port4,11,0,20,0 );
ReefAngel.StandardLights( Port5,9,0,19,0 );
ReefAngel.AI.SetChannel( White, PWMParabola(11,0,17,0,0,60,0) );
ReefAngel.AI.SetChannel( Blue, PWMParabola(9,0,20,0,15,100,15) );
ReefAngel.AI.SetChannel( RoyalBlue, MoonPhase() );
ReefAngel.RF.SetChannel( Radion_White, PWMParabola(9,0,20,0,0,60,0) );
ReefAngel.RF.SetChannel( Radion_RoyalBlue, MoonPhase() );
ReefAngel.RF.SetChannel( Radion_Red, PWMParabola(9,0,20,0,15,65,15) );
ReefAngel.RF.SetChannel( Radion_Green, PWMParabola(9,0,20,0,15,50,15) );
ReefAngel.RF.SetChannel( Radion_Blue, MoonPhase() );
ReefAngel.RF.SetChannel( Radion_Intensity, PWMParabola(9,0,20,0,15,94,15) );
if ( second()==0 ) ReefAngel.RF.RadionWrite();
ReefAngel.Portal( "ecam" );
int x,y;
// Aqua Illumination
x = 10;
y = 20;
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x,y,"WH:" );
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+38,y,"BL:" );
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+76,y,"RB:" );
for ( int a=0;a<3;a++ )
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+18,y,ReefAngel.AI.GetChannel(a) );
x += 38;
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
// Main Relay Box
// Date and Time
#include <RF.h>fa
int x,y;
x = 10;
y = 20;
x += 38;
// Parameters
// Main Relay Box
// Date and Time
ecam
Roberto, also in the last 10 mins my controller has rebooted itself 5x times. itll flash red while doing it and then start up again. THe main problem is that my skimmer keeps turning off and on
Your code is set to hard coded settings so you can't change any settings with smart phone app.
You would need to choose internal memory setting when generating your code.
To display the modes in the controller screen, you will need to create a custom main screen.
There are several other users that have done custom screens to display vortech mode.
It will display automatically on the smart phone apps or Portal.
