PH calibration using 4 - 7 solutions
Graham2212
Post by Graham2212 »
Good day all. I'm a complete newby to marine aquariums (my first tank has been running for almost 3 months now). Just received my new Reef Angel. Can anyone help with the calibration of the PH probe? I have managed to get hold of solutions 4 and 7 (not the recommended 7 and 10). I believe that I can still perform the calibration with these solutions, but that there needs to be a change in the config code? Can anyone provide me with this code adjustment? Much appreciated!!
Sebyte
Re: PH calibration using 4 - 7 solutions
Post by Sebyte »
Take a look at http://forum.reefangel.com/viewtopic.ph ... d&start=10
Roberto explains the calculation when using 4 & 7 calibration fluids.
Graham2212
Thanks very much for the values to use. Where do I go on the programme to make these adjustments (to the configuration code I believe) - (feeling a bit overwhelmed at the moment)?
Graham2212
How do I navigate to the setup() section of my code?
Can you post the code you are using?
Graham2212
    ReefAngel.PHMin=217;
    ReefAngel.PHMax=512;
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit;
    InternalMemory.OverheatTemp_write( 290 );
    ReefAngel.StandardATO( Port1,50 );
    ReefAngel.WavemakerRandom1(Port5,15,60); // Turn Port5 on/off random cycles that lasts from 15 to 60 secs
    ReefAngel.WavemakerRandom2(Port6,15,60); // Turn Port6 on/off random cycles that lasts from 15 to 60 secs
    ReefAngel.Portal( "Graham2212" );
    int x,y;
    // Parameters
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
    // Main Relay Box
    // Date and Time
Graham2212
Could you kindly let me know if I'm on the right track here?
Yeap :)
Graham2212
Thanks very much for your help? Would you be able to possibly help me with customizing my main screen? I would love a graph of temp, ph and salinity, actual values in the middle, with the relay box graphic below... do I need to create a new post?
That's how it is now, isn't it?
For custom screens, start with this post:
http://forum.reefangel.com/viewtopic.php?f=14&t=109
