Alternating Main Screen
thekameleon
Post by thekameleon »
I want to alternate my main screen every 5 seconds from the parameter values to a chart... I am not having much luck. What am I doing wrong?
#include "Moon.h"
TimerClass screenTimer;
boolean showChart;
    ReefAngel.FeedingModePorts = Port3Bit | Port5Bit;
    ReefAngel.FeedingModePortsE[0] = Port1Bit | Port3Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port7Bit;
    ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port4Bit | Port6Bit | Port8Bit;
    ReefAngel.LightsOnPortsE[0] = Port2Bit | Port4Bit | Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit | Port6Bit | Port8Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port2Bit | Port4Bit | Port7Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.AddStandardMenu();
    ReefAngel.Display24h();
    ReefAngel.AddDateTimeMenu();
    screenTimer.SetInterval(5);
    showChart = 0;
    moon_init(47, -122);
    ReefAngel.StandardHeater( Port1 );
    ReefAngel.DayLights( Port2 );
    ReefAngel.DayLights( Port4 );
    ReefAngel.ActinicLights( Port6 );
    ReefAngel.MoonLights( Port8 );
    ReefAngel.DayLights( Box1_Port2 );
    ReefAngel.ActinicLights( Box1_Port4 );
    ReefAngel.Relay.DelayedOn( Box1_Port6 );
    ReefAngel.ActinicLights( Box1_Port7 );
    ReefAngel.Relay.DelayedOn( Box1_Port8 );
    if(ReefAngel.PWM.LightsOverride)
      ReefAngel.PWM.SetChannel( 0, 100 );
      ReefAngel.PWM.SetChannel( 1, 100 );
      ReefAngel.PWM.SetChannel( 2, 100 );
      ReefAngel.PWM.SetChannel( 3, 100 );
      ReefAngel.PWM.SetChannel( 4, 100 );
      ReefAngel.PWM.SetChannel( 5, 100 );
    else if ((hour() >=10) && (hour() <21)){
      ReefAngel.PWM.ActinicPWMSlope(60);
      ReefAngel.PWM.Channel0PWMSlope();
      ReefAngel.PWM.Channel1PWMSlope();
      ReefAngel.PWM.Channel2PWMSlope();
      ReefAngel.PWM.Channel3PWMSlope(60);
      ReefAngel.PWM.Channel4PWMSlope(60);
      ReefAngel.PWM.Channel5PWMSlope(60);
      //Moonlight Phase 9pm-10am (CH3-CH5)
      //We got to dim my super bright LEDS :)
      byte moon = PWMParabola(Moon.riseH, Moon.riseM, Moon.setH, Moon.setM, 11, ((MoonPhase() / 10) + 10), 0);
      ReefAngel.PWM.SetDaylight(0);
      ReefAngel.PWM.SetActinic(0);
      ReefAngel.PWM.SetChannel( 0, 0 );
      ReefAngel.PWM.SetChannel( 1, 0 );
      ReefAngel.PWM.SetChannel( 2, 0 );
      ReefAngel.PWM.SetChannel( 3, moon );
      ReefAngel.PWM.SetChannel( 4, moon );
      ReefAngel.PWM.SetChannel( 5, moon );
    ReefAngel.WaterLevelATO(Port7, InternalMemory.ATOExtendedTimeout_read(), 15, 60);
    if(!screenTimer.IsTriggered())
      screenTimer.Start();
      if(showChart)
        showChart = false;
        showChart = true;
    ReefAngel.Portal( "thekameleon", "265210" );
    int x,y;
    if(!showChart)
      // Dimming Expansion
      x = 15;
      y = 2;
      for ( int a=0;a<6;a++ )
        if ( a>2 ) x = 75;
        if ( a==3 ) y = 2;
        y += 10;
      // moon
      x = 15;
      y = 31;
      sprintf(text, "%02d:%02d", Moon.riseH, Moon.riseM);
      ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MR:"); x+=21;
      if(Moon.isRise)
        ReefAngel.LCD.DrawText(COLOR_GREEN,DefaultBGColor,x,y,text);
        ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,text);
      sprintf(text, "%02d:%02d", Moon.setH, Moon.setM);
      x = 75;
      ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MS:");
      x+=21;
      if(Moon.isRise)
        // Parameters
      ReefAngel.LCD.DrawMonitor( 15, 40, ReefAngel.Params,
      ReefAngel.LCD.DrawMonitor( 15, 40, ReefAngel.Params );
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,70, "SAL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,69, ReefAngel.Params.Salinity );
    // ORP
    ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,75,70, "ORP:" );
    ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,99,70, ReefAngel.Params.ORP );
    // Water Level
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,81, "WL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,81, ReefAngel.WaterLevel.GetLevel() );
    // Main Relay Box
    ReefAngel.LCD.DrawOutletBox( 12, 91, TempRelay );
    // Relay Expansion
    ReefAngel.LCD.DrawOutletBox( 12, 104, TempRelay );
    // Date and Time
  int x,y;
  x = 5;
  y = 5;
  if(showChart)
    // Draws the main screen graph
    ReefAngel.LCD.Clear(DefaultBGColor,0,y,131,y+69);
    ReefAngel.LCD.Clear(DefaultFGColor,x,y,x,y+69);
    for (byte i=6; i<=131; i+=3)
        ReefAngel.LCD.PutPixel(GraphDotLineColor, i, y+25);
    ReefAngel.LCD.DrawSingleGraph(T1TempColor,x,y,InternalMemory.T1Pointer_read());
    ReefAngel.LCD.DrawSingleGraph(T2TempColor,x,y,InternalMemory.T1Pointer_read()+120);
    ReefAngel.LCD.DrawSingleGraph(T3TempColor,x,y,InternalMemory.T1Pointer_read()+240);
    ReefAngel.LCD.DrawSingleGraph(PHColor,x,y,InternalMemory.T1Pointer_read()+360);
show_chart is only going to be true for a few micro seconds.
I would write it to do something like this.
If (screetimer.isTriggered) {
Screentimer.start()
If (showchart)
Showchart=false
Else
Showchart=true
This way it should only switch when the timer triggers.
Sorry the code is pseuo'ish
For the record, glad to see you going this route :) this will be in my next evolution :)
thekameleon
Re: Alternating Main Screen
Ummm not working :(. Well sorta... So when I was in feed mode and went back I saw the chart then it went back to the params and has not left since....
My suggestion is get rid of the timer and use this:
    showChart = now()%10<5;
thekameleon
No luck there either... What I notice though is for 5 seconds the screen flickers a bit... So I tried moving the chart into the DrawCustomMain method and while it did flip to the chart... the Chart was a hot mess to say the least.... <sigh>
Declare this in global section:
boolean drawGraph=false;
And this is your custom screen code:
  int x,y;
  if (millis()%5000<200)
      drawGraph=true;
  if(!showChart)
    if (drawGraph)
      drawGraph=false;
      ReefAngel.LCD.Clear(DefaultBGColor,0,0,131,75); // Clear screen
      x = 15;
      y = 2;
        if ( a>2 ) x = 75;
        if ( a==3 ) y = 2;
        y += 10;
      // moon
      x = 15;
      y = 31;
      x+=21;
      if(Moon.isRise)
      x = 75;
      x+=21;
      if(Moon.isRise)
      // Parameters
    if (drawGraph)
      drawGraph=false;
      x = 5;
      y = 5;
  // Salinity
  // ORP
  // Water Level
  // Main Relay Box
  // Relay Expansion
  // Date and Time
thekameleon
I see that you are trying to draw the graph only once in each 5 second interval... right? But I want to understand why.
If you draw more than once, you will get the flickering effect you mentioned.
thekameleon
What is the interval that DrawCustomMain and DrawCustomGraph is called?
Main is called every loop, but graph is called every 6 minutes.
