newbie with question
wijigong
Post by wijigong »
scuse i am french guy
i think to purchase RA in couple of week, but before i try to familiar with programmation.
i try ragen but i think is not make what y need.
i have led+meanwell dimmable and i need sunset sunrise,cloud and thunderstorm
i need pulse 2 wavemaker,ato,heater control
i try in arduino to copy paste this pde file find in the forum
#include <ReefAngel_Colors.h>
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
void ConvertNumToString(char* string, int num, byte decimal)
char temptxt[3];
int Temp = num;
if (Temp==0xFFFF) Temp=0;
itoa(Temp/decimal,string,10);
if (decimal>1)
itoa(Temp%decimal,temptxt,10);
strcat(string, ".");
if (Temp%decimal<10 && decimal==100) strcat(string, "0");
strcat(string, temptxt);
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawDate(6, 2);
x = 12;
y += MENU_START_ROW+1;
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Display pH");
char text[7];
ConvertNumToString(text, ReefAngel./Params, 100);
ReefAngel.LCD.Clear(DefaultBGColor, x+16, y+65, x+65, y+16);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text,
Font8x16);
ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
y += MENU_START_ROW*2;
x = 10;
ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+(16*4),y+16);
ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, x, y, text);
x += (16*4) + 8;
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,8,y+25,"Sump:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, T2TempColor,
24, y+35, 10);
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,x+8,y+25,"LED:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, T3TempColor,
x+24, y+35, 10);
//y += 39*2;
// x = 13;
ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
// #ifdef RelayExp
// draw 1st expansion relay
// TempRelay = ReefAngel.Relay.RelayDataE[0];
// TempRelay &= ReefAngel.Relay.RelayMaskOffE[0];
// TempRelay |= ReefAngel.Relay.RelayMaskOnE[0];
// ReefAngel.LCD.DrawOutletBox(12, 105, TempRelay);
//#endif RelayExp
//Start of PWM Expansion Code Header
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={
0,0,0,0,0,0};
//End of PWM Expansion Code Header
randomSeed(second());
// setTime(1313771580); // Unix time
// now();
// ReefAngel.RTC.set(now());
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
// Specific functions
// ReefAngel.StandardLights(Port1,20,00,1,00);
ReefAngel.SingleATOLow(Port2);
ReefAngel.StandardLights(Port3,10,30,19,30);
ReefAngel.StandardLights(Port4,10,00,20,00);
// ReefAngel.StandardFan(Port8);
//ReefAngel.PWM.SetActinic(PWMSlope(10,0,20,00,15,100,60,ReefAngel.PWM.GetActinicValue()));
//ReefAngel.PWM.SetDaylight(PWMSlope(10,30,19,30,15,65,60,ReefAngel.PWM.GetDaylightValue()));
// Calculate your regular sunrise/sunset PWM value
PWMChannel[LEDPWM0]=PWMSlope(10,0,20,0,15,100,60,PWMChannel[LEDPWM0]);
PWMChannel[LEDPWM1]=PWMSlope(10,30,19,30,15,75,60,PWMChannel[LEDPWM1]);
//PWMChannel[LEDPWM2]=MoonPhase();
if (hour()>=20 || hour()<1)
PWMChannel[LEDPWM2]=0;
CheckCloud();
//PWMChannel[LEDPWM3]=PWMSlope(11,0,20,00,0,50,40,PWMChannel[LEDPWM3]);
//PWMChannel[LEDPWM4]=PWMSlope(11,0,21,30,0,50,40,PWMChannel[LEDPWM4]);
//PWMChannel[LEDPWM5]=PWMSlope(11,0,20,00,0,50,40,PWMChannel[LEDPWM5]);
PWMExpansion(LEDPWM0,int(2.55*PWMChannel[LEDPWM0]));
PWMExpansion(LEDPWM1,int(2.55*PWMChannel[LEDPWM1]));
PWMExpansion(LEDPWM2,int(2.55*PWMChannel[LEDPWM2]));
//PWMExpansion(LEDPWM3,int(2.55*PWMChannel[LEDPWM3]));
//PWMExpansion(LEDPWM4,int(2.55*PWMChannel[LEDPWM2]));
//PWMExpansion(LEDPWM5,int(2.55*PWMChannel[LEDPWM3]));
// ReefAngel.LCD.DrawText(0,255,75,120,PWMChannel[LEDPWM1]);
// ReefAngel.LCD.DrawText(0,255,35,120,PWMChannel[LEDPWM1]);
// ReefAngel.LCD.DrawText(0,255,65,120,PWMChannel[LEDPWM2]);
// ReefAngel.LCD.DrawText(0,255,95,120,PWMChannel[LEDPWM3]);
//Start of PWM slope function code designed for the PWM Expansion module
void PWMExpansion(byte cmd, byte data)
Wire.beginTransmission(8); // transmit to device #2
Wire.send('$'); // sends $
Wire.send(cmd); // sends a value
Wire.send(data); // sends 255
Wire.endTransmission(); // stop transmitting
//End of PWM slope function code designed for the PWM Expansion module
byte MoonPhase()
int m,d,y;
int yy,mm;
long K1,K2,K3,J,V;
byte PWMvalue;
m=month();
d=day();
y=year();
yy=y-((12-m)/10);
mm=m+9;
if (mm>=12) mm-=12;
K1=365.25*(yy+4712);
K2=30.6*mm+.5;
K3=int(int((yy/100)+49)*.75)-38;
J=K1+K2+d+59-K3;
V=(J-2451550.1)/0.29530588853;
V-=int(V/100)*100;
V=abs(V-50);
PWMvalue=4*abs(50-V); // 5.12=100% 4=~80%
//pinMode(lowATOPin,OUTPUT);
return (PWMvalue*100)/255;
void CheckCloud()
#define Clouds_Every_X_Days 1
// Minimum number of minutes for cloud duration
#define Min_Cloud_Duration 3
#define Max_Cloud_Duration 10
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(11,30)
#define End_Cloud_Before NumMins(18,30)
// Channels used by the actinic LEDs on the PWM Expansion module
// These channels will not be dimmed when the cloud effect is triggered
// Number is a binary form. B001100 means channel 2 and 3 are used for actinics
#define Actinic_Channels B000001
// Channels used by the daylight LEDs on the PWM Expansion module
// These channels will be used for the spike when lightning effect is triggered
// Number is a binary form. B000011 means channel 0 and 1 are used for daylights
#define Daylight_Channels B000010
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
#ifdef printdebug
Serial.print("Cloud Chance: ");
Serial.println(cloudchance,DEC);
#endif
if (cloudchance)
lightningchance=random(100);
#ifdef printdebug
Serial.print("Num of Clouds: ");
Serial.println(numclouds,DEC);
Serial.print("Cloud Start: ");
Serial.println(cloudstart,DEC);
Serial.print("Cloud Start Range: ");
Serial.print(Start_Cloud_After,DEC);
Serial.print(" - ");
Serial.println(Start_Cloud_After+((End_Cloud_Before-Start_Cloud_After)/(numclouds*2)),DEC);
Serial.print("Cloud Duration: ");
Serial.println(cloudduration,DEC);
Serial.print("Lightning Chance: ");
Serial.println(lightningchance,DEC);
Serial.print("Lightning at: ");
Serial.println(cloudstart+(cloudduration/2),DEC);
time_t t=cloudstart;
t*=60;
t+=1311551999;
setTime(t); // Unix time
now();
Serial.print("NumMins: ");
Serial.println(LastNumMins,DEC);
#endif
if (cloudchance)
//is it time for cloud yet?
// let's go through all channels to pick which ones will be dimmed
for (int a=0;a<6;a++)
if (bitRead(Actinic_Channels,a)==0)
// this will slope down the channel from the current PWM to 0 within 3minutes.
// then it will stay at 0 for the duration of the cycle
// and finally slope up from 0 to PWM value within 3 minutes
// it is basically an inversed slope
PWMChannel[a]-=PWMSlope(cloudstart/60,cloudstart%60,(cloudstart+cloudduration)/60,(cloudstart+cloudduration)%60,0,PWMChannel[a],3,PWMChannel[a]);
#ifdef printdebug
if (second()==0)
Serial.print("Dimming Channel ");
Serial.print(a,DEC);
Serial.print(PWMChannel[a],DEC);
Serial.println("%");
if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()>5)
adjustTime(((cloudduration/2)*60)-6);
Serial.print("Adjusting time to: ");
Serial.println(now());
#endif
#ifdef printdebug
Serial.println("Lightning...");
#endif
for (int b=0;b<6;b++)
if (bitRead(Daylight_Channels,b)==1)
else lightningstatus=0;
if (lightningstatus) PWMChannel=100;
else PWMChannel=0;
//delay(10);
#ifdef printdebug
Serial.print(b,DEC);
Serial.println(PWMChannel,DEC);
#endif
PWMChannel=20;
#ifdef printdebug
if ((NumMins(hour(),minute())!=(cloudstart+(cloudduration/2))) && second()==0)
adjustTime(((cloudduration/2)*60)-1);
if (second()==0) delay(1000);
#endif
cloudindex++;
if (cloudindex < numclouds)
#ifdef printdebug
Serial.print(Start_Cloud_After+(((End_Cloud_Before-Start_Cloud_After)/(numclouds*2))*cloudindex*2),DEC);
Serial.println((Start_Cloud_After+(((End_Cloud_Before-Start_Cloud_After)/(numclouds*2))*cloudindex*2))+((End_Cloud_Before-Start_Cloud_After)/(numclouds*2)),DEC);
t*=60;
t+=1311551999;
now();
#endif
ReefAngel.LCD.Clear(255,0,115,132,132);
ReefAngel.LCD.DrawText(0,255,5,115,"C");
ReefAngel.LCD.DrawText(0,255,11,115,"00:00");
ReefAngel.LCD.DrawText(0,255,45,115,"L");
ReefAngel.LCD.DrawText(0,255,51,115,"00:00");
int x=0;
if ((cloudstart/60)>=10) x=11; else x=17;
ReefAngel.LCD.DrawText(0,255,x,115,(cloudstart/60));
if ((cloudstart%60)>=10) x=29; else x=35;
ReefAngel.LCD.DrawText(0,255,x,115,(cloudstart%60));
//ReefAngel.LCD.DrawText(0,255,35,120,cloudstart);
ReefAngel.LCD.DrawText(0,255,90,115,cloudduration);
ReefAngel.LCD.DrawText(0,255,110,115,PWMChannel[LEDPWM1]);
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
ReefAngel.LCD.DrawText(0,255,x,115,((cloudstart+(cloudduration/2))%60));
#ifdef printdebug
#endif
but i have this error
In file included from sketch_sep20a.cpp:20:
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:27:20: error: EEPROM.h: No such file or directory
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:31:22: error: NokiaLCD.h: No such file or directory
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:85: error: redefinition of 'const prog_char XML_T1 []'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Wifi/ReefAngel_Wifi.h:28: error: 'const prog_char XML_T1 [9]' previously defined here
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:86: error: redefinition of 'const prog_char XML_T2 []'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Wifi/ReefAngel_Wifi.h:29: error: 'const prog_char XML_T2 [10]' previously defined here
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:87: error: redefinition of 'const prog_char XML_T3 []'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Wifi/ReefAngel_Wifi.h:30: error: 'const prog_char XML_T3 [10]' previously defined here
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:88: error: redefinition of 'const prog_char XML_PH []'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Wifi/ReefAngel_Wifi.h:31: error: 'const prog_char XML_PH [10]' previously defined here
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:89: error: redefinition of 'const prog_char XML_R []'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Wifi/ReefAngel_Wifi.h:32: error: 'const prog_char XML_R [9]' previously defined here
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:90: error: redefinition of 'const prog_char XML_RON []'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Wifi/ReefAngel_Wifi.h:33: error: 'const prog_char XML_RON [10]' previously defined here
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:91: error: redefinition of 'const prog_char XML_ROFF []'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Wifi/ReefAngel_Wifi.h:34: error: 'const prog_char XML_ROFF [13]' previously defined here
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:92: error: redefinition of 'const prog_char XML_RE_OPEN []'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Wifi/ReefAngel_Wifi.h:35: error: 'const prog_char XML_RE_OPEN [3]' previously defined here
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:93: error: redefinition of 'const prog_char XML_RE_CLOSE []'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Wifi/ReefAngel_Wifi.h:36: error: 'const prog_char XML_RE_CLOSE [4]' previously defined here
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:94: error: redefinition of 'const prog_char XML_RE_ON []'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Wifi/ReefAngel_Wifi.h:37: error: 'const prog_char XML_RE_ON [3]' previously defined here
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:95: error: redefinition of 'const prog_char XML_RE_OFF []'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Wifi/ReefAngel_Wifi.h:38: error: 'const prog_char XML_RE_OFF [4]' previously defined here
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:96: error: redefinition of 'const prog_char XML_ATOLOW []'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Wifi/ReefAngel_Wifi.h:39: error: 'const prog_char XML_ATOLOW [9]' previously defined here
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:97: error: redefinition of 'const prog_char XML_ATOHIGH []'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Wifi/ReefAngel_Wifi.h:40: error: 'const prog_char XML_ATOHIGH [19]' previously defined here
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:98: error: redefinition of 'const prog_char XML_END []'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Wifi/ReefAngel_Wifi.h:43: error: 'const prog_char XML_END [13]' previously defined here
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:138: error: 'ButtonPress' was declared 'extern' and later 'static'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Globals/ReefAngel_Globals.h:485: error: previous declaration of 'ButtonPress'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:140: error: 'ds' was declared 'extern' and later 'static'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Globals/ReefAngel_Globals.h:486: error: previous declaration of 'ds'
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel/ReefAngel.h:263: error: 'NokiaLCD' does not name a type
sketch_sep20a.cpp: In function 'void DrawCustomMain()':
sketch_sep20a:39: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:40: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:44: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:47: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:48: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:55: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:57: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:60: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:61: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:63: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:64: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:72: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a.cpp: In function 'void loop()':
sketch_sep20a:130: error: 'class ReefAngelClass' has no member named 'ShowInterface'
sketch_sep20a:134: error: 'class ReefAngelClass' has no member named 'SingleATOLow'
sketch_sep20a.cpp: In function 'void CheckCloud()':
sketch_sep20a:462: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:463: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:464: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:465: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:466: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:471: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:473: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:476: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:477: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:482: error: 'class ReefAngelClass' has no member named 'LCD'
sketch_sep20a:484: error: 'class ReefAngelClass' has no member named 'LCD'
help me to put me on the good way
thank
Re: newbie with question
I think you got a mismatch of libraries.
Please use the libraries update utility and make sure to convert or update to the latest development libraries.
http://reefangel.com/update/
wijigong
Post by wijigong »
ok good i try this
after the only error is
sketch_sep20a:48: error: 'class ReefAngel_NokiaLCD' has no member named 'DrawLargeText'
sketch_sep20a:57: error: 'class ReefAngel_NokiaLCD' has no member named 'DrawHugeNumbers'
Good.
Now, you are only missing the fonts definitions.
http://forum.reefangel.com/viewtopic.php?f=14&t=109
I don't know which fonts you are using, but these are the fonts available:
#define FONT_8x8
#define FONT_8x16
#define FONT_12x16
#define NUMBERS_8x8
#define NUMBERS_8x16
#define NUMBERS_12x16
#define NUMBERS_16x16
These lines, or whichever you are using, have to be placed inside the file ReefAngel_Features.h
wijigong
Post by wijigong »
if y need to uncomment or other???
ReefAngel_Globals\ReefAngel_Globals.cpp.o: In function `ConvertNumToString(char*, int, unsigned char)':
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Globals/ReefAngel_Globals.cpp:103: multiple definition of `ConvertNumToString(char*, int, unsigned char)'
RA_092011_2217.cpp.o:C:\DOCUME~1\user\LOCALS~1\Temp\build1579756703640831023.tmp/RA_092011_2217.cpp:30: first defined here
ReefAngel_Globals\ReefAngel_Globals.cpp.o: In function `MoonPhase()':
C:\Documents and Settings\user\Mes documents\Arduino\libraries\ReefAngel_Globals/ReefAngel_Globals.cpp:79: multiple definition of `MoonPhase()'
RA_092011_2217.cpp.o:C:\DOCUME~1\user\LOCALS~1\Temp\build1579756703640831023.tmp/RA_092011_2217.cpp:197: first defined here
I think the code you are trying to compile is too advanced for someone just starting up.
You've got custom screen, moonphase, PWMSLope, storm, PWM Expansion and the works!!! Too much going on at once.
You should really start with the basics first and start building from there.
I'd recommend you start by using just the code generated with RAGen, then start adding features that you would like to have one at a time.
Take a look at this thread:
http://forum.reefangel.com/viewtopic.php?f=15&t=60
wijigong
Post by wijigong »
ok but
with ragen it is possible to
control wavemaker
dimm led
thunderstorm
cloud
is the minimum i need to purchase the reef angel
do you have pde exemple with this fonction
thank a lot
wijigong
Post by wijigong »
finalie y remove couple off feature i dont need
want i compile no error
but with this code i have the standard menu
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
byte PWMChannel[]={
0,0,0,0,0,0};
// now();
CheckCloud();
void CheckCloud()
#else
#endif
#ifdef printdebug
#endif
if (cloudchance)
#ifdef printdebug
t*=60;
t+=1311551999;
now();
#endif
if (cloudchance)
#ifdef printdebug
if (second()==0)
#endif
#ifdef printdebug
#endif
else PWMChannel=0;
//delay(10);
#ifdef printdebug
#endif
PWMChannel=20;
#ifdef printdebug
#endif
cloudindex++;
#ifdef printdebug
t*=60;
t+=1311551999;
now();
#endif
#ifdef printdebug
#endif
wijigong
Post by wijigong »
th pwm expansion is the port for dim the led???
is need with the new version of reef angel???
i think begins to understand!!!
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
byte PWMChannel[]={
0,0,0,0,0,0};
wijigong
Post by wijigong »
finaly in other post y find it:
// Autogenerated file by RAGen (v1.0.4.92), (09/01/2011 21:51)
// RA_090111_2151.pde
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define ATOSetup
#define MetalHalideSetup
#define DirectTempSensor
#define DisplayLEDPWM
#define SingleATOSetup
#define StandardLightSetup
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
randomSeed(analogRead(0));
ReefAngel.PHMin=526;// 526=PH7.0
ReefAngel.PHMax=813;// 813=PH10.0
ReefAngel.FeedingModePorts = B10000000;
ReefAngel.OverheatShutoffPorts = B01000000;
ReefAngel.Timer[1].SetInterval(random(10,150));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port4);
ReefAngel.StandardATO(Port1);
ReefAngel.MHLights(Port3);
ReefAngel.Relay.Toggle(Port4);
ReefAngel.StandardFan(Port6);
// Have PWM on from 12p to 9:30p, with gradual 150 minute ramp up and 180 down for actinic, and 120 minute ramp up and down for daylight starting at given times
// From 12pm to 1pm, actinic will slowly ramp up from 10% to 100%, and from 12:30p to 2p, daylight will slowly ramp up from 10% to 50%
// From 8:30p to 9:30p, actinic will slowly ramp down from 100% to 10%, and from 7p to 8:30p daylight will slowly ramp down from 50% to 10%
if (hour()<16)
ActinicPWMValue=PWMSlope(12,0,21,30,10,100,150,ReefAngel.PWM.GetActinicValue());
ActinicPWMValue=PWMSlope(12,0,21,30,10,100,180,ReefAngel.PWM.GetActinicValue());
DaylightPWMValue=PWMSlope(12,30,20,30,10,50,120,ReefAngel.PWM.GetDaylightValue());
CheckCloud();
void CheckCloud()
#define Min_Cloud_Duration 8
#define Max_Cloud_Duration 20
#define Max_Clouds_per_Day 2
// In this example, start could be after 11:30am
#define Start_Cloud_After NumMins(15,00)
// In this example, end could before 6:00pm
#define End_Cloud_Before NumMins(18,00)
#else
#endif
if (cloudchance)
if (cloudchance)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
int x=0;
int x=0;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
is everyting what i need
do you already ship in canada with usps :D
There ya go!! :)
Yes, I have shipped to Canada via USPS.
