ATO timeout? Red LED
duck
Post by duck »
I am getting an ATO time out on the controller. My topoff is connected to the RODI via a 12v solenoid/valve. I am using the dual ato with the low as the trigger to fill and the high as a backup. Where is this timeout coming from? here is the code.
//Return              1
//Blue LED and Fans   2
//White LED           3
//Alk                 4
//Powerhead           5
//Heater              6
#define ATO           7
//Skimmer             8
    ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port7Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port7Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.StandardLights( Port2,10,0,22,0 );
    ReefAngel.StandardLights( Port3,10,0,22,0 );
    ReefAngel.StandardHeater( Port6,760,770 );
    ReefAngel.PWM.SetDaylight( PWMParabola(12,0,19,0,0,30,0) );
    ReefAngel.PWM.SetActinic( PWMParabola(10,0,22,0,0,30,0) );
    //Alk Dosing Pump 1 Minute Every 25 Minutes
    if (now()%1500<60) ReefAngel.Relay.On(Port4); else ReefAngel.Relay.Off(Port4);
    //Powerhead On Every 4 Hours With 30 Min Pause
    if (now()%1800<12600) ReefAngel.Relay.On(Port5); else ReefAngel.Relay.Off(Port5);
    //Heater Control on at 76.0F and off at 76.8F
    ReefAngel.StandardHeater(Port6,760,768);
    //ATO Low Activation with High Safety (Port 7)
    if (ReefAngel.HighATO.IsActive()) ReefAngel.SingleATOLow(ATO);
      else ReefAngel.Relay.Off(ATO);
Re: ATO timeout? Red LED
Try replacing this:
With this:
  if (ReefAngel.HighATO.IsActive()) ReefAngel.SingleATO(true,ATO,60,0);
Change the 60 to whatever timeout in seconds you need.
duck
Post by duck »
hrmm I set it at 800 secinds and its still timing out? I clear the timeout and it comes back.
Does it take 800s to timeout?
duck
Post by duck »
no, it shuts off the relay after its done filling usually within 140 seconds, and then when the 800 second timeout amount is up it throws the red led.
Are you sure you got the correct floats in the right position?
duck
Post by duck »
its been working perfect for a year, I added leds to my tank and had to upload code to make the changes. I had to format a machine that crashed and reinstalled the reefangel setup and modified my wizard generated sketch with some lines from my old code. Now im having issues?
That's what I mean.
Are you sure you were using low ATO port?
Use just this function instead:
Does the ATO pump turn on/off when you move the float?
duck
Post by duck »
ok commented everything else out and inserted just
the float goes low and clicks the relay/solenoid. when it gets to the proper level, it shuts back off. no timeouts and its been over an hour.. I would like to utilize the other ATO as a backup in case the first one gets stuck on. That is what I had at first I believe.
Is the other float above (outside of water) the one you are using to turn on/off the relay?
duck
Post by duck »
it actually triggers about 1/8 an inch higher than the other float. so yes its "above" the other float.
I'm not sure how it is being tripped and causing the timeout then :(
