Trying to set multiple on off times for 1 port
Elevatorguy1
Post by Elevatorguy1 »
Hello,
Total newbie here.
I've been looking for a simple way to turn my Kalk reactor on and off a couple times a day. I tried the standard lights but this only allows one on/off time.
Is there a simple way to do this?
Here's the code that I've come up with so far.
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <ReefAngel.h>
////// Place global variable code below here
////// Place global variable code above here
    ReefAngel.LightsOnPorts = Port1Bit | Port3Bit | Port4Bit | Port8Bit;
    ReefAngel.StandardLights( Port1,22,30,13,30 ); //*sump fuge light
    ReefAngel.StandardLights( Port2,13,30,22,30 ); //*top fuge light
    ReefAngel.StandardLights( Port3,13,30,22,30 ); //*Actinic
    ReefAngel.StandardLights( Port4,13,30,22,30 ); //*Daylight
    ReefAngel.StandardLights( Port5,0,0,0,1 ); //*kalk reactor
    ReefAngel.StandardATO( Port6,6000 ); //*Fresh water solenoid
    ReefAngel.StandardHeater( Port7,775,785 );
    ReefAngel.StandardLights( Port8,13,30,22,30 ); //*Light fan
    ReefAngel.PWM.SetDaylight( PWMSlope(13,30,22,30,5,60,30,5) );
    ReefAngel.PWM.SetActinic( PWMSlope(13,30,22,30,5,70,30,5) );
      byte x;
      byte y = 2;
      char text[7];
      ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 30, 2, "Gonzo's Reef"); // Put a banner at the top
      ReefAngel.LCD.DrawDate(6, 119); // Put the date and time at the bottom
      ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 132, 11); // Draw a black line under the banner
      x = 12;
      y += MENU_START_ROW+1; // MENU_START_ROW is 10, according to globals.h, so y=2+10+1=13
      ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, x, y+6, "Tank Temp pH");
      ConvertNumToString(text, ReefAngel.Params.PH, 100); // Get pH reading and convert
      ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+75, y+18, text, Font8x16); // Put pH on the screen
      ConvertNumToString(text, ReefAngel.Params.Temp[T1_PROBE], 10); // Get T1 temp and convert
      y += MENU_START_ROW*2;
      x = 10;
      ReefAngel.LCD.DrawHugeNumbers(COLOR_WHITE, COLOR_BLACK, x, y, text); // Draw the temperature, white numbers on a colored background
      x += (16*4) + 8;
      ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,8,y+25,"White %");
      ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, 24, y+35, 1); // Draw the white light %
      ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+8,y+25,"Blue %");
      ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), APColor, x+24, y+35, 1); // Draw the blue light %
      // Code for drawing the relay box
  TempRelay &= ReefAngel.Relay.RelayMaskOff;
  TempRelay |= ReefAngel.Relay.RelayMaskOn;
  ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
Re: Trying to set multiple on off times for 1 port
Very good start!!!
What about using dosing pump function?
How often and how long do you want to turn it on?
Elevatorguy1
Thanks Roberto!
Hmm. I did see that in the wizard. For now would like the reactor to turn on at 12:00am and off at 12:01am then a second time at 12:00pm and off at 12:01pm. Depending on cal and alk demands there maybe be a need in the future to turn the reactor on more than 2 times.
Use something this then:
ReefAngel.Relay.Set(Port1,now()%43200<60);
This code means it will turn on Port1 for 60s every 43200 seconds.
Elevatorguy1
You are fast!!!!
I went back to the wizard and used the dosing pump selection and came up with this. would this work?
ReefAngel.DosingPumpRepeat( Port5,0,720,60 ); //*kalk reactor
byte x;
byte y = 2;
char text[7];
x = 12;
x = 10;
x += (16*4) + 8;
Yeah, works too...
Elevatorguy1
Thanks Roberto!
Really happy with my RA and its not even on the tank yet. Really nice to be able to lay out what you need and your fantastic support. You're best Roberto!
