ph control
Barendvh
ph control
How does this control work?
Re: ph control
That's meant for equipment that raise pH.
Turn on when it gets lower than X pH and turns off when it gets higher than Y pH.
Barendvh
Re: ph control
Thank you Roberto is this based on the main pH reading or the PH expansion unit?
Barendvh
Re: ph control
Thank you I cannot program so I rely on the wizard. Is it easy to change? If not I am just going to keep the main tank on the expansion unit. What is the tolerances for the switching?
Re: ph control
You can code it as tight as you want, like turn on at 7.91 and off at 7.92, but that is going to give you a lot of turn on/off.
If you want to use the ph expansion module, you can add this to your code:
if (ReefAngel.Params.PHExp <= 791) ReefAngel.Relay.On(Port5);
if (ReefAngel.Params.PHExp >= 800) ReefAngel.Relay.Off(Port5);
Barendvh
Re: ph control switching
p
Hi I am still struggling to get the RA to switch on and off with the PH control
Please could you look at the code below and tell me what I am doing wrong
InternalMemory.OverheatTemp_write( 275 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port4,247,252 );
ReefAngel.StandardFan( Port5,255,260 );
ReefAngel.StandardLights( Port6,19,0,7,0 );
ReefAngel.PHControl( Port8,625,650 );
ReefAngel.Portal( "barendvh" );
int x,y;
// Salinity
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,75, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,75, ReefAngel.Params.PHExp );
ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
int x,y;
// Salinity
// pH Expansion
Re: ph control
Which equipment are you trying to control based on pH?
PHControl is for equipments that raise pH and CO2Control is for equipments that lower pH.
Barendvh
Re: ph control
I am trying to control my calcium Reactor
Barendvh
Re: ph control
solinoid valve
Barendvh
Re: ph control
I am not measuring CO2
Barendvh
Re: ph control
I am trying to switch the solenoid of when the PH is 6.2 and on if the PH gets above 6.5.
Barendvh
Re: ph control
Barendvh
Re: ph control
So how should I do this
Barendvh
Re: ph control
Barendvh
Re: ph control
You are a absolute star it is working. Where are you in the world?
I am in South Africa
Barendvh
Re: ph control
Should you ever come to South Africa you are welcome to look me up.
Have a great day
Have a great day
