Single ATO with timer?
Smotz
Hi All -
Can anyone advise how to code a single ATO to stay turned on for say 2 minutes then disengage?
Re: Single ATO with timer?
Huh?
If it turns off, when would it turn back on?
Are you talking about timeout?
Sent from my Galaxy S3 using Tapatalk 2
Smotz
Sorry, guess I didn't explain it well.rimai wrote:Huh?
I would like the ato to be engaged when the single float switch activates and then simply turn off after X amount of time ( 2 minutes ).
Turn off after 2 minutes even if the water goes past the float, is that correct?
Smotz
Yes. With a single, it will go past the float. After a bit I will be able to determine exactly how much time is needed to get the refill where I want it.rimai wrote:Turn off after 2 minutes even if the water goes past the float, is that correct?
Try this:
On setup():
On setup():
ReefAngel.Timer[1].SetInterval(120);
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port1);
if (ReefAngel.Timer[1].IsTriggered())
ReefAngel.Relay.Off(Port1);
Smotz
Thanks Roberto - so I understand:rimai wrote:Try this:
On setup():Code: Select all
ReefAngel.Timer[1].SetInterval(120);Code: Select all
if (ReefAngel.LowATO.IsActive()) { ReefAngel.Timer[1].Start(); ReefAngel.Relay.On(Port1); } if (ReefAngel.Timer[1].IsTriggered()) { ReefAngel.Relay.Off(Port1); }
I would change "Port1" to whatever port my ATO pump is on - correct?
The setInterval(120) is 120 seconds - correct?
I can change "Timer[1]" to whatever I want to call the function?
Yes, change the port to whatever you want, but keep Timer[1]. This is an internal timer.
Smotz
Roberto - I found a flaw in my logic:rimai wrote:Yes, change the port to whatever you want, but keep Timer[1]. This is an internal timer.
This 'single ATO with timer' will work with the exception of if the water runs out in the reservoir. Then the float would immediately reactivate for the duration of the timer, then reactivate again, and again..
Can you think of anything to prevent this?
I would add a check for what time the last run was and if it was right after the runtime of your ato then set the relay mask off for the device and maybe set a portal variable that you can trigger a txt message. This way you can reset the mask once you see whats wrong and it will keep your ato pump from burning out.
Smotz
yea, thats what I would do too.lnevo wrote:I would add a check for what time the last run was and if it was right after the runtime of your ato then set the relay mask off for the device and maybe set a portal variable that you can trigger a txt message. This way you can reset the mask once you see whats wrong and it will keep your ato pump from burning out.
Smotz
Much appreciatedlnevo wrote:I'll try throw some code together by tomorrow.,
Ok, trickier than I thought it would be, but just need to wrap my head around it... sorry it took so long.
It should be clear how the logic works, but let me know if any questions.
If someone wants to copy this, keep in mind the mask code needs to be adjusted if your ATO is on a relay expansion box.
// Define these for your preference
byte floatThreshold=30; // How soon is too soon?
byte ATOPort=Port1; // Made this a variable so we can change it in one spot
int runtime=240; // Replaces the Timer[1].SetInterval
// startTime replaces Timer[1] and endTime added to track last run
static time_t startTime, endTime;
static boolean atoRunning;
if (ReefAngel.LowATO.IsActive()) // Float switch is active.
startTime=now(); // Time to start
if (startTime()-endTime() < floatThreshold) // Has enough time passed since the last run?
bitClear(ReefAngel.Relay.RelayMaskOff,ATOPort-1); // Set off mask to disable the relay
if (now()-startTime < runTime) // Are we within the runTime
ReefAngel.Relay.On(ATOPort);
atoRunning=true;
else // runTime is over
ReefAngel.Relay.Off(ATOPort);
if (atoRunning) {
endTime=now();
atoRunning=false;
// Assign custom variable to value of the off mask
// Default is 1 for off mask so setup the alert if value is < 1
ReefAngel.CustomVars[0]=bitRead(ReefAngel.Relay.RelayMaskOff,ATOPort-1);
// Dummy variable to keep portal feature activated (may not be necessary...)
ReefAngel.CustomVars[7]=255;
Smotz
Nice - I will give this a try - thank you so much!lnevo wrote:Ok, trickier than I thought it would be, but just need to wrap my head around it... sorry it took so long.
// // Define these for your preference // byte floatThreshold=30; // How soon is too soon? byte ATOPort=Port1; // Made this a variable so we can change it in one spot int runtime=240; // Replaces the Timer[1].SetInterval // startTime replaces Timer[1] and endTime added to track last run static time_t startTime, endTime; static boolean atoRunning; if (ReefAngel.LowATO.IsActive()) // Float switch is active. { startTime=now(); // Time to start if (startTime()-endTime() < floatThreshold) // Has enough time passed since the last run? { bitClear(ReefAngel.Relay.RelayMaskOff,ATOPort-1); // Set off mask to disable the relay } } if (now()-startTime < runTime) // Are we within the runTime { ReefAngel.Relay.On(ATOPort); atoRunning=true; } else // runTime is over { ReefAngel.Relay.Off(ATOPort); if (atoRunning) { endTime=now(); atoRunning=false; } } // Assign custom variable to value of the off mask // Default is 1 for off mask so setup the alert if value is < 1 ReefAngel.CustomVars[0]=bitRead(ReefAngel.Relay.RelayMaskOff,ATOPort-1); // Dummy variable to keep portal feature activated (may not be necessary...) ReefAngel.CustomVars[7]=255;
