Apogee sensor.
johniii
Apogee sensor.
Post by johniii »
Is it possible for reef angel to read/record a mV DC signal? From an external sensor such as an apogee-sq120
Re: Apogee sensor.
Can you really just measure mV from the sensor?
phrusher
Re: Apogee sensor.
Post by phrusher »
Not familiar with the apogee but I recently completed a DIY PAR reader and the output from that was mV. But why connect it to the reef angel?
Re: Apogee sensor.
Which sensor did you use?
phrusher
Re: Apogee sensor.
Post by phrusher »
This. It's 400 to 1100 but as I understand it everything over about 700 is filtered out when submerging it in the tank. I haven't calibrated it yet against another meter but it was interesting to see how much lower the light got just by lowering the sensor a few centimeters (or inches for you guys :-P)
johniii
Re: Apogee sensor.
Post by johniii »
rimai wrote:Can you really just measure mV from the sensor?
Yes mV x 5 = par
Per apogees instructions
Sent from my DROID RAZR using Tapatalk 2
johniii
Re: Apogee sensor.
Post by johniii »
phrusher wrote:Not familiar with the apogee but I recently completed a DIY PAR reader and the output from that was mV. But why connect it to the reef angel?
Just because I could.
Re: Apogee sensor.
Try plugging into the probe and see if it goes out of scale...
A ph meter is nothing more than a mV meter.
Same for the ORP, but the scale of the ORP is much higher.
