why no status in the RA server?
daniella3d
Post by daniella3d »
Hi,
If I go to my reef angel web server I can see the sliders for my 8 ports, I can see T1, T2, T3 and PH but I cannot see the little red or green dot to show the status of the ports, why is that?
So I cannot see if oa port is on or off. Also dunno if it's normal but all the sliders are on Auto.
what's going on?
thanks
Re: why no status in the RA server?
All sliders should be on Auto. That means that the ports are going to update as your code tells them to. If they are set to ON or OFF, that means they are forced ON or OFF and will not toggle as your code tells them.....they are overridden.
There are not any red or green dots to show the status of the ports. I'm not exactly sure but I'm sure there is a reason behind it and Roberto will have to comment on it.
It's just too old :(
We need new interface.... I was working on something and had to stop.
