Put it anywhere. Open up ReefAngel Client, go to Settings, then Load Memory File. Navigate to the settings file you just saved and it will load it up.rossbryant1956 wrote:save this file where?
Be sure to close out the program and restart it after you load the memory file.Bogdan wrote:Wherever on your computer.Then go Setting and Memory file and brows to where you saved the file.
Maybe it will work for you, it didn't for me.
Good luck.
enigma32 wrote:@Paulturner911:
It seems to be usually related to the VC++ redistributable... I imagine the installer ensures that you have the right one though. (Perhaps it doesn't, or maybe if it used to work you have installed something that changed the version of the library you had...)
Maybe try reinstalling the client?
Otherwise I think you'll have to wait for the author or someone else familiar with .Net programming to respond... I won't touch that stuff
Download the RAMemory.ini file for the version of the libraries you are using. 1.1.0 is here:Redadeath wrote:after insatlling fresh new reef angel client suite
i cannot enter the memmory tab
i got the latest online version of libraries Controller is running dev libraries v.1.0.9
Im getting that same error and have tried on different machines with clean installs. seems ill never get this working.Paulturner911 wrote:This is the error I am getting trying to run the program. I can run the dashboard and listener will run, logger will run, but when I switch notifier on, logger will stop.
Is there a new RAMemory.ini for 1.1.0?rimai wrote:For v1.0.9 libs, you need this one.
My errors.., Sorry my log is in french..#include <ReefAngel_Features.h>
//1 1ight
//2 light
//3 Heater
//4 Wp40
//5 ATO
//6 Skimmer
//7 Pompe Remonte
//8 Phosban
ReefAngel.FeedingModePorts = Port4Bit | Port6Bit | Port8Bit; // Ports toggled in Water Change Mode
ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Ports toggled when Lights On / Off menu entry selected
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit; // Ports turned off when Overheat temperature exceeded
ReefAngel.OverheatShutoffPorts = Port3Bit; // Use T1 probe as temperature and overheat functions
InternalMemory.OverheatTemp_write( 805 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port3,760,769 );
ReefAngel.StandardATO( Port5,7200 );
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Transitions.Transition.add(Object target, String strPropertyName, Object destinationValue)
at ReefAngelClient.Form1.SpinActiveRelayBar(SpinRelay spin)
at ReefAngelClient.Form1.btnScrollRelayUp_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.1022 (RTMGDR.030319-1000)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
ReefAngelClient
Assembly Version: 3.0.4768.39086
Win32 Version: 3.0.4768.39086
CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/ReefAngelClient.exe
Win32 Version: 4.0.30319.1002 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.0.30319.1001 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
DevExpress.Utils.v11.1
Assembly Version: 11.1.10.0
Win32 Version: 11.1.10.0
CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/DevExpress.Utils.v11.1.DLL
System.Windows.Forms.DataVisualization
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.5681
CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/System.Windows.Forms.DataVisualization.DLL
System.ServiceModel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
System.Core
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Runtime.Serialization
Win32 Version: 4.0.30319.1016 (RTMGDR.030319-1000)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
DevExpress.XtraEditors.v11.1
CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/DevExpress.XtraEditors.v11.1.DLL
DevExpress.Data.v11.1
CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/DevExpress.Data.v11.1.DLL
System.Configuration
Win32 Version: 4.0.30319.1015 (RTMGDR.030319-1000)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Data.SqlServerCe
Win32 Version: 4.0.8876.1
CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/System.Data.SqlServerCe.DLL
System.Data
Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.Xml
Win32 Version: 4.0.30319.1015 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
ReefAngelException
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/ReefAngelException.DLL
System.EnterpriseServices
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
Google.GData.Calendar
Assembly Version: 2.1.0.0
Win32 Version: 2.1.0.0
CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/Google.GData.Calendar.DLL
Google.GData.Client
CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/Google.GData.Client.DLL
System.Windows.Forms.Calendar35
Assembly Version: 3.5.4568.30457
Win32 Version: 3.5.0.0
CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/System.Windows.Forms.Calendar35.DLL
AForge.Controls
Assembly Version: 2.2.2.0
Win32 Version: 2.2.2.0
CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/AForge.Controls.DLL
AForge.Video
Assembly Version: 2.2.0.0
Win32 Version: 2.2.0.0
CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/AForge.Video.DLL
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
SMDiagnostics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
System.Runtime.DurableInstancing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.DurableInstancing/v4.0_4.0.0.0__31bf3856ad364e35/System.Runtime.DurableInstancing.dll
System.ServiceProcess
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceProcess/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.ServiceProcess.dll
System.WorkflowServices
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.WorkflowServices/v4.0_4.0.0.0__31bf3856ad364e35/System.WorkflowServices.dll
System.ServiceModel.Web
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Web/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Web.dll
System.ServiceModel.Discovery
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Discovery/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Discovery.dll
System.ServiceModel.Activities
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Activities/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Activities.dll
System.ServiceModel.Routing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Routing/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Routing.dll
System.ServiceModel.Channels
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Channels/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Channels.dll
System.IdentityModel
Win32 Version: 4.0.30319.1001 (RTMGDR.030319-1000)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.IdentityModel/v4.0_4.0.0.0__b77a5c561934e089/System.IdentityModel.dll
ReefAngelCrypto
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/ReefAngelCrypto.DLL
Transitions
Assembly Version: 1.2.0.0
Win32 Version: 1.2.0.0
CodeBase: file:///C:/Users/Velasco/AppData/Roaming/ReefAngel/Client/dlls/Transitions.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Do you remember which files?89delta wrote:Ok so I figured it out....un-install the client software and run regedit.Search for all reefangel registry settings. Delete only the ones for the client and re-install the software....works like a dream again.
