Avast ATO w water level
rossbryant1956
I was able to use hints found in here plus the wizard to get our new Avast ATO working but do not understand the water tube that came with that device. It all appears to work but the menu command that the wizard built stays at 0% regardless of it's position. LMK if you have ideas. Thx
bhazard
Re: Avast ATO w water level
The tube is attached to the pressure sensor.
If coded correctly, stick the tube into the water, you should hear a click of the outlet turning on/off. Pull the tube out, it should click again. Mount the tube where it starts to click.
