ATO Install
kirkwood
ATO Install
Can anyone recommend where to buy the pieces needed for in sump ATO install? Basically looking for the types of plastic pieces that come with the JBJ ATO to attach the float switches.
ATO Install
I found some nice acrylic brackets on ebay. I think they were like $15. They were very cleanly cut and work perfectly
the2ndtinman
Re: ATO Install
I used egg crate just super glued it.
Sent from my EVO using Tapatalk 2
kirkwood
Re: ATO Install
what did you search to find them?lnevo wrote:I found some nice acrylic brackets on ebay. I think they were like $15. They were very cleanly cut and work perfectly
- Contact:
ATO Install
Float switch bracket
Which found the same guy i got mine from.
bigbear4x4bear
bigbear4x4bear
ATO Install
I really like the water level sensor for this..float switches are nice for monitoring sump level that shouldn't change much...binder wrote:yeah, I am curious too. i am looking to get some for monitoring my reservoir level.kirkwood wrote:what did you search to find them?lnevo wrote:I found some nice acrylic brackets on ebay. I think they were like $15. They were very cleanly cut and work perfectly
Just my $.02
- Contact:
ATO Install
yeah. mine is primarily going to be for a rudimentary level check without having to get additional equipment.lnevo wrote:I really like the water level sensor for this..float switches are nice for monitoring sump level that shouldn't change much...binder wrote:yeah, I am curious too. i am looking to get some for monitoring my reservoir level.kirkwood wrote: what did you search to find them?![]()
Just my $.02
