Help with custom screen
ReeferBee
Post by ReeferBee »
Hey guys I'm new here.
I found this code, posted by deckoz2302, of a really nice looking custom main screen.
//Custom Main, Graph & Menu
  Wire.requestFrom(8,8);
  for (int a=0;a<8;a++)
    if (Wire.available()) SeasonsVar[a]=Wire.receive();
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawDate(6, 2);
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 123, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 123, "|");
  ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,22,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
  ReefAngel.LCD.DrawText(0,255,10,30,"Display");
  ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,100,30,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
  ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
  ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
  ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
  ReefAngel.LCD.DrawText(0,255,8,68,"Sump");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, COLOR_CORNFLOWERBLUE, 40, 68, 10);
  ReefAngel.LCD.DrawText(0,255,70,68,"Room");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, COLOR_CORNFLOWERBLUE, 99, 68, 10);
  ReefAngel.LCD.DrawText(0,255,8,97,"Moon");
  DayAge = MoonAge(day(), month(), year());
  MoonState(DayAge);
  if (ThisPhase == 0) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"New");
  else if (ThisPhase == 1) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waxing Crescent");
  else if (ThisPhase == 2) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"First Quarter");
  else if (ThisPhase == 3) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waxing Gibbous");
  else if (ThisPhase == 4) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Full");
  else if (ThisPhase == 5) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waning Gibbous");
  else if (ThisPhase == 6) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Last Quarter");
  else if (ThisPhase == 7) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waning Crescent");
  //  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),COLOR_CORNFLOWERBLUE, 105, 109, 1);
  ReefAngel.LCD.DrawText(0,255,8,109, "Sunrise");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,15,119, SeasonsVar[1]);
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,20,119, ":");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,25,119, SeasonsVar[2]);
  ReefAngel.LCD.DrawText(0,255,75,109,"%");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255, 60, 109, SeasonsVar[0]);
  ReefAngel.LCD.DrawText(0,255,88,109, "Sunset");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,90,119, SeasonsVar[3]);
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,102,119, ":");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,107,119, SeasonsVar[4]);
I'm looking to change some things about it. One big thing I need help with is changing the code to show what mode my wp40 is currently running.
Here is my current code running on my RA +
    ReefAngel.WaterChangePorts = Port5Bit | Port7Bit | Port8Bit;
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardLights( Port1,13,0,0,0 );
    ReefAngel.StandardLights( Port2,12,30,0,30 );
    ReefAngel.DosingPumpRepeat( Port3,0,120,60 );
    ReefAngel.DosingPumpRepeat( Port4,29,120,60 );
    ReefAngel.StandardHeater( Port6,780,792 );
    if (hour()>=8 && hour()<12)
  ReefAngel.PWM.SetDaylight( TidalSwellMode(60,true) ); // Tidal Swell at 60% on sync mode
  ReefAngel.PWM.SetActinic( TidalSwellMode(60,false) ); // Tidal Swell at 60% on anti-sync mode
else if (hour()>=12 && hour()<16)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 80% + - 20 on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,false) ); // ReefCrest at 80% + - 20 on anti-sync mode
else if (hour()>=16 && hour()<17)
  ReefAngel.PWM.SetActinic( NutrientTransportMode(75,90,2000,false) ); // Nutrient Transport on anti-sync mode
else if (hour()>=17 && hour()<20)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 75% + - 20 on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,false) ); // ReefCrest at 75% + - 20 on anti-sync mode
else if (hour()>=20 && hour()<24)
  ReefAngel.PWM.SetDaylight( LongPulseMode(0,40,10,true) ); // Long pulse at 40% with 10s pulse on syncy mode
  ReefAngel.PWM.SetActinic( LongPulseMode(0,40,10,false) ); // Long pulse at 40% with 10s pulse on on anti-sync mode
thanks so much!
Barry
Current tank info: 150g mixed reef
"Some of the worst mistakes of my life were hair cuts" -Jim Morrison
Re: Help with custom screen
This should get you started:
byte vtechmode=0;
  vtechmode=6;
  vtechmode=2;
  vtechmode=5;
  vtechmode=2;
  vtechmode=6;
  vtechmode=4;
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawText(0,255,18,12,"Jebao Mode:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_CORNFLOWERBLUE, 40, 68, 10);
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_CORNFLOWERBLUE, 99, 68, 10);
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,MoonPhaseLabel());
ReeferBee
Post by ReeferBee »
Thanks Roberto!
Barry
ReeferBee
Post by ReeferBee »
I'm having issues with using the DrawHugeText command for my sump temperature display. Part of the temp display is cut off. I've tried everything to fix it, no matter where I position it on the main screen its still cut off. If I need to post a pic of the screen I will.
byte vtechmode=0;
  vtechmode=6;
  vtechmode=2;
  vtechmode=5;
  vtechmode=2;
  vtechmode=6;
  vtechmode=4;
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawDate(6, 3);
  ReefAngel.LCD.DrawText(0,255,18,16,"   WP40 Mode:");
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,27,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,27,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,27,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,27,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,27,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,27,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,27,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,255,45,27,"Night");
  ReefAngel.LCD.DrawText(0,255,15,40,"Sump");
  ReefAngel.LCD.DrawHugeText(COLOR_RED, 255, 25, 60, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,100,40,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 60, text, Num8x8);
  ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
Barry
ReeferBee
Post by ReeferBee »
I figured it out!
Barry
What was it?
ReeferBee
Post by ReeferBee »
Well, I thought I figured it out :)
I changed Num8x8 here:
To Num12x16
But now it's not showing the full temp reading. It says 9.69???
Any ideas?
Barry
ReeferBee
Post by ReeferBee »
I found my error once again. I changed the 10 after [T1_PROBE] to a 100, not knowing what the value was for. Now its back at 10 and everything looks great!
Barry
