need help to control wp 40, first time setup
ReefDevil
been trying this
http://forum.reefangel.com/viewtopic.php?f=14&t=2895
it wont let me upload the code ....trying to just paste it where it says, at the bottom for the first part and inbetween the add your code below/above area have tried all the modes, cant get it to save one of them
is the the right place to start?
i have been looking at this mp40 since monday and cant get it to turn on at all
ReefDevil
Re: need help to control wp 40, first time setup
ReefAngel.FeedingModePorts = Port3Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 835 );
// Setup ATO Port for AI communication
ReefAngel.AI.SetPort( highATOPin );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,751,762 );
ReefAngel.StandardLights( Port4,16,0,22,0 );
ReefAngel.WavemakerRandom( Port5,60,124 );
ReefAngel.WavemakerRandom( Port6,70,148 );
ReefAngel.AI.SetChannel( White, PWMSlope(14,0,23,0,15,100,60,15) );
ReefAngel.AI.SetChannel( Blue, PWMSlope(13,0,23,0,31,100,60,31) );
ReefAngel.AI.SetChannel( RoyalBlue, PWMParabola(13,0,23,0,37,100,37) );
byte ReefCrestMode(byte WaveSpeed, byte WaveOffset, boolean PulseSync)
static unsigned long lastwavemillis=millis();
static int newspeed=WaveSpeed;
if ((millis()-lastwavemillis) > 5000)
if (random(100)<50) newspeed--; else newspeed++;
newspeed=constrain(newspeed,WaveSpeed-WaveOffset,WaveSpeed+WaveOffset);
newspeed=constrain(newspeed,0,100);
if (PulseSync)
return newspeed;
return WaveSpeed-(newspeed-WaveSpeed);
ReefAngel.Portal( "reefdevil" );
int x,y;
// Aqua Illumination
x = 10;
y = 20;
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x,y,"WH:" );
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+38,y,"BL:" );
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+76,y,"RB:" );
for ( int a=0;a<3;a++ )
ReefAngel.LCD.DrawText( COLOR_DODGERBLUE,DefaultBGColor,x+18,y,ReefAngel.AI.GetChannel(a) );
x += 38;
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 48, ReefAngel.Params );
// Main Relay Box
// Date and Time
if (PulseSync)
return newspeed;
int x,y;
x = 10;
y = 20;
x += 38;
// Parameters
// Main Relay Box
// Date and Time
ReefDevil
error says " a function definition is not allowed here before'{'
ReefDevil
if i plug the jebo cable into the ai sol port it does turn on so i know the pump works, just cant get any waves
if that helps you any
You are entering the wrong thing.
This is what you need to paste, just like in the post:
ReefAngel.PWM.SetDaylight( ReefCrestMode(60,20,true) ); // ReefCrest at 60% +/- 20% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(60,20,false) ); // ReefCrest at 60% +/- 20% on anti-sync mode
ReefDevil
int x,y;
x = 10;
y = 20;
x += 38;
// Parameters
ok changing it to this lets me save but it doesnt make any waves and pump is off
// Main Relay Box
// Date and Time
int x,y;
x = 10;
y = 20;
x += 38;
// Parameters
// Main Relay Box
// Date and Time
ReefDevil
it doesnt work, it will save the code but the pump doesnt turn on or off...i have the little white wire plugged into the left most (farthest from center) of the 2 outlets
ReefDevil
it will save the code as you have above but the pump doesnt even turn on....if i plug it in to the other slot for the ai sol it turns on but constant speed
ReefDevil
do i have to go on the portal and turn it on or something like that? im totally new to the wp 40 but managed to get the new router and wifi and portal up tonight....Im gonna get some sleep and look at this with fresh eyes tomorrow night
if its really just the 2 lines of code between the 2 lines for put the code here, im at a loss.
do you have to do anything to the iphone or portal settings to make it work?
No, just plug the cable into the relay box dimming ports and make sure you also use the power supply provided with the pump.
ReefDevil
the pmw bars on my portal are moving before they were blank,,, but the pump is a paperweight doesnt turn at all
ReefDevil
its only one white connector to the ra, the black cable to the black cable and the power cord right
thats what i have hooked up
ReefDevil
if the pwm bars are moving I dont see how its not sending the signal to the pump to turn on and speed up or slow down
Yes, but you plugged them into the dimming ports on the side of the relay box, right?
ReefDevil
im plugging in the white cable to the top of the ra itself...i dont have a relay box unless it came with it...
its like right next to the ph probe
ReefDevil
pluggin in on the other side of the ph probe from where the temp probes plug in ... there are 2 places with 2 pin taps on each one.
Huh?
The relay box is the one you plug your equipment into.
The ports you are plugging are the ATO ports.
ReefDevil
Bingo...Holly cow!!! my tank is ALIVE.. Im just a little slow on the computer....i can keep corals really well. lol
.. once again many thanks..... UR the BEST!!
