Explain to me like I am 5 on what the libraries do
- Rodasphoto
- Contact:
Explain to me like I am 5 on what the libraries do? Why is advantageous to update them?
The libraries are what give you all the reefangel commands and support all the refangel hardware.
with newer versions of the libraries, more functionality can be added as well as bugs or problems being fixed. it is not necessary to update them if nothing is broken. however, sometimes a feature that you may want can be included in an update which would require you to update your libraries.
sometimes library updates can break functionality. this usually does not happen. we try very hard to keep things backward compatible. if we cannot, then we make extra notes about how to fix what gets broken.
i still am running 1.0.2 on my controller running my tank. i haven't had a reason to update them yet.
Re: Explain to me like I am 5 on what the libraries do
I was still using v0.8.5 at the office up until today.
I think it's been 2 years I haven't changed anything on that controller.
- DrewPalmer04
I see libraries as the back ground workers you never see...you code what you want to happen and those workers get the complex job done without you having to know what they are doing. You just reference them in the code and they take care of the rest.
- Rodasphoto
- Contact:
Makes sense. As someone who is just beginning to learn to code I wish the more advance options like weather would be available via the Reef Angel wizard to simplify and expedite programming.
those extras are still being worked on and tested. things get a little complex with coding them properly. once things are more stable, im sure there could be a way to add it to the main libraries and thus into the wizard. i will say that some of that stuff requires updating code on the dimming module and some more advanced configurations. rest assured, we will be trying to simplify things.Rodasphoto wrote:Makes sense. As someone who is just beginning to learn to code I wish the more advance options like weather would be available via the Reef Angel wizard to simplify and expedite programming.
- Rodasphoto
- Contact:
I think you guys doing a great job. The amount of features that are being added and the short amount of time is nothing short of incredible.
