Dimmable Rapid Led Onyx
pesc64
Post by pesc64 »
I'm going to receive the dimmable Onyx fixture. The unit has 3 separate channels. I own a RA with PWM dimming. I assume I should order the order the Analog Dimming Expansion. Is this correct?
Re: Dimmable Rapid Led Onyx
Yes
cjrudy
Post by cjrudy »
So the analog dimming expansion will work with a PWM RA unit ? I didnt know this. Opens up some additional lighting possibilities.
Yeah, you can mix and match :)
I can even make custom modules with any combination of signals.
For example you can order a dimming module with 4 analog and 2 PWM or 1 Analog and 5 PWM or any combination you prefer.
cjrudy
Post by cjrudy »
That's great, you also mentioned in another thread about ordering the PWM dimming expansion module with 0-5VDC signal instead of 0-10VDC if needed for the LDD drivers. Lots of options.
Of course with all the lighting possibilities its harder to make a decision :)
