WiFi Attachment Setup Issue
ufgators2k
Hi everyone,
I just got the WiFi unit today and I tried running both the Utility and Coolterm. I get this error in the utility:
* Please, select a serial port and click the "Connect" button
Opening Serial Port...
Verifying speed at 9600 baud
** ERROR: Connecting to /dev/tty.usbserial-AH01Q7UY
** Additional installation required to use serial, read the console below.
However there is nothing in the console below. FYI, I am on a Mac running Mountain Lion.
Re: WiFi Attachment Setup Issue
Did you install the mac. Usb-serial driver?
ufgators2k
ufgators2k
I just downloaded the driver again and rebooted. Same issue. I don't have any issues talking to the Reef Angel Controller. I have a blue and green blinking light as well.
Jean-Christophe
I have the same problem, did you find a solution? I'm following.
Ok, so it's not just a local problem then....
Let me look into this.
Ok, I think this is isolated to MacOSX.
So, I compiled another one.
Give it a try and let me know if it works.
http://www.reefangel.com/files/wifi_uti ... c_1.06.zip
Jean-Christophe
Still the same, I think i'll install a windows part to fix it...
** ERROR: Connecting to /dev/tty.usbserial-AH01Q70Z
ufgators2k
I ended up dusting off an old Dell laptop and doing it that way. I never got the Mac (Mountain Lion) to work. Can the WiFi Utility have a radio button to select the baud rate so it can be used after the device is initially configured (57600 instead of 9600)?
The wifi utility actually goes through 9600 and changes it to 57600 everytime, so there is no need to change it.
Jean-Christophe
Works fine with windows.
Ok, so after investigating this for a while, I noticed that it has to do with specific settings in your local MacOSX machine.
Here is the thread that led me to a work around:
http://forum.arduino.cc/index.php?topic ... msg1016859
You basically need to run two commands in sudo mode:
I remember reading somewhere that there is a version that doesn't use locks and you don't need to run those commands. I just need to figure out how.
I'll try to find a more permanent solution.To use the serial library, first open
Applications -> Utilities -> Terminal.app
and enter the following:
sudo mkdir -p /var/lock
sudo chmod 777 /var/lock
I have recompiled using a processing 1.5.1 instead of the current released one.
Can anyone with a Mac try this version to see if it works before I package in the installer?
http://www.reefangel.com/files/wifi_uti ... _1.06a.zip
Jean-Christophe
Yes this version works on mac (I have snow leopard), I just tried it.
