I am a total noob at my RA but I got everything running as Im using it just for basic things, but the only problem I ran into is that my RA uses my only temp probe to check of overheat. Is it possible for the controller to use a single temp probe to control my heater and check for the overheat? or /will I have to purchase extra temp probes? thank you guys for your help
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port5Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardHeater( Port1,600,778 );
ReefAngel.DosingPumpRepeat( Port6,0,50,15 );
ReefAngel.StandardLights( Port7,0,0,10,0 );
ReefAngel.SingleATO( true,Port8,10,0 );
By this, your heater should come on at anything less than 60 degrees F, Shut off at 77.8 degrees F, and overheat at 80 degrees, shutting off ports 1, 3, 5, and 7. What's your current temp? Is the red light on?
my current temp is 77.9 but when I take the temp probe out and the temp drops util 75.5 the socket will still not turn on, its red which indicates its shut off.
I got it to work when I changed the temp from 60F to 70F. I want the heater to turn on when ever it is under 77.8, so my code would look like this for the heater? ( Port1,778,778 )?
Means turn on when lower than 60, turn off at 77.8. So you would want your high temp a little higher than that or your heater will be switching on and off all the time.
thank you for your help, I set it to (Port1,788,788) . The wizard is where I got confused I tried setting the lowest temp so I would turn on when ever it was not 78.8F
You really dont want the parameters equal. Its going to continuously cycle the relay on and off like that.
I would suggest setting the low/on temp to 76 or something and the high you can leave as is.
You want the heater on for a set amount of time to heat the water. You will probably damage your heater and eventually the relay the way you have it...
