jebo wp40
Re: jebo wp40
Yes, there is a way...
It's your homework now to change the position of the stuff to your liking :)
It's all based on the x and y, which are coordinates of where you want to display stuff.
The top left corner is 0,0 and it goes to 132,132 at the bottom right corner.
Just go changing the coordinates for each stuff you want to move and play around until you get what you want :)
805reefer
Re: jebo wp40
Post by 805reefer »
ok that sounds good to me so it showing its in tidal swell mode but is should be in sine mode? so whats showing on the screen is what mode its in right
805reefer
Re: jebo wp40
Post by 805reefer »
    static time_t feeding;
// Time schedule first
if (hour()>=6 && hour()<11) {
  //ReefAngel.PWM.SetDaylight( TidalSwellMode(45,true) ); // TidalSwell at 45% on sync mode
  ReefAngel.PWM.SetActinic( TidalSwellMode(30,true) ); // TidalSwell at 30% on sync mode
  wpMode=1;
} else if (hour()>=11 && hour()<15) {
  //ReefAngel.PWM.SetDaylight( ReefCrestMode(70,20,true) ); // ReefCrest at 70% +/- 20% on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(40,20,true) ); // ReefCrest at 40% +/- 20% on anti-sync mode
  wpMode=2;
} else if ( (hour()>=15 && hour()<18) && (now()-feeding > SECS_PER_DAY) ) { // We haven't fed today
// ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,60,6000,true) );
  ReefAngel.PWM.SetActinic( NutrientTransportMode(25,35,6000,true) );
  wpMode=3;
} else if (hour()>=15 && hour()<18) {
// ReefAngel.PWM.SetDaylight( ReefCrestMode(70,20,true) ); // ReefCrest at 70% +/- 20% on sync mode
   ReefAngel.PWM.SetActinic(ShortPulseMode(15,42,3000,true));
  wpMode=2;
} else if (hour()>=18 && hour()<20) {
  ReefAngel.PWM.SetActinic( ReefCrestMode(32,20,true) ); // ReefCrest at 32% +/- 20% on anti-sync mode
  wpMode=2;
} else if (hour()>=20 && hour ()<23) {
// ReefAngel.PWM.SetDaylight(SineMode(20,40,30,true) ); //SineMode from 20% to 40% for 30 seconds on sync mode
  ReefAngel.PWM.SetActinic(SineMode(20,40,30,true) ); //SineMode from 20% to 40% for 30 seconds on sync mode
  wpMode=1;
} else {
  //ReefAngel.PWM.SetDaylight(SineMode(15,40,30,true) ); //SineMode from 15% to 40% for 30 seconds on sync mode
  ReefAngel.PWM.SetActinic( TidalSwellMode(20,true) ); // TidalSwell at 20% on sync mode
  wpMode=4;
  if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) {
  //ReefAngel.PWM.SetDaylight(0);
  ReefAngel.PWM.SetActinic(0);
// If we are feeding override the schedule
// ReefAngel.PWM.SetDaylight(30);
  wpMode=0;
  feeding=now();
Re: jebo wp40
I think you got it inverted....
Look at your code that displays the modes:
  if (wpMode == 0) ReefAngel.LCD.DrawText(COLOR_GREEN,255,x,y,"Feeding");
  else if (wpMode == 1) ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,x,y,"Tidal Swell");
  else if (wpMode == 2) ReefAngel.LCD.DrawText(COLOR_GOLD,255,x,y,"Reef Crest");
  else if (wpMode == 3) ReefAngel.LCD.DrawText(COLOR_RED,255,x,y,"Nutrient");
  else if (wpMode == 4) ReefAngel.LCD.DrawText(COLOR_BLUE,255,x,y,"Sine Wave");
And look at what you are assigning to wpMode here:
  wpMode=1;
} else {
  wpMode=4;
Can you see that they are inverted?
805reefer
Re: jebo wp40
Post by 805reefer »
oh got you so thats because i changed some of the modes around right?
Re: jebo wp40
Exactly
Re: jebo wp40
my tutorial on custom main screens covers the x,y coordinates of the screen. if you get confused, read that tutorial and it should help.
805reefer
Re: jebo wp40
Post by 805reefer »
Ok will do I'm going to start working on it in about an hour I really appreciate all the help
805reefer
Re: jebo wp40
Post by 805reefer »
ok thanks to binder and his tutorial i got my screen to show the whole mode now and not only half... now another issue so i put it in feeding mode for the first time today and noticed that my pump didnt shut off which i have it set to 0 what do i need to do here
  wpMode=1;
  wpMode=2;
  wpMode=3;
  wpMode=5;
  wpMode=2;
  wpMode=4;
} else {
  wpMode=1;
  wpMode=0;
  feeding=now();
// If we have finished feeding, start NTM for 3 hours
if (now()-feeding < 3*SECS_PER_HOUR) {
//ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,60,6000,true) );
  ReefAngel.PWM.SetActinic( NutrientTransportMode(25,40,6000,true) );
  wpMode=3;
Re: jebo wp40
Hmm well oddly you have the WaterChange mode code twice...which isn't the issue here, but it makes me wonder what we may not be seeing...can you post your whole code? I don't see any reason why it wouldn't set to 0. The code looks good...
805reefer
Re: jebo wp40
Post by 805reefer »
wow just saw that so i removed one of the water changes and still nothing heres the code
static byte wpMode;
    ReefAngel.WaterChangePorts = Port4Bit;
    ReefAngel.LightsOnPorts = Port6Bit | Port7Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardHeater( Port1 );
    ReefAngel.DosingPumpRepeat1( Port3 );
    ReefAngel.DosingPumpRepeat2( Port5 );
    ReefAngel.DayLights( Port6 );
    ReefAngel.ActinicLights( Port7 );
    ReefAngel.PWM.Channel0PWMSlope(40);
    ReefAngel.PWM.Channel1PWMSlope(10);
    ReefAngel.PWM.Channel2PWMSlope(20);
    ReefAngel.PWM.Channel3PWMSlope(35);
    ReefAngel.PWM.Channel4PWMSlope(25);
if (hour()>=6 && hour()<9) {
  wpMode=1;
} else if (hour()>=9 && hour()<12) {
  wpMode=2;
} else if ( (hour()>=12 && hour()<15) && (now()-feeding > SECS_PER_DAY) ) { // We haven't fed today
  wpMode=3;
  wpMode=5;
  wpMode=2;
  wpMode=4;
} else {
  wpMode=1;
  ReefAngel.PWM.SetActinic (0);
  wpMode=0;
  feeding=now();
  wpMode=3;
    ReefAngel.Portal( "805reefer" );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
  // WP40 Mode
x = 15;
y = 33;
  ReefAngel.LCD.DrawText(0,255,x,y,"RF:");
  ReefAngel.LCD.Clear(DefaultBGColor,x,y,128-x,y+8);
  else if (wpMode == 5) ReefAngel.LCD.DrawText(COLOR_GREEN,255,x,y,"Short Pulse");
805reefer
Re: jebo wp40
Post by 805reefer »
when i push water change the pump does turn off..... as far as the wave patterns they all work each time the mode changes the flow is changing... what are you seeing
805reefer
Re: jebo wp40
Post by 805reefer »
ya im tying to learn but im just having so many different problems trying to figure this stuff out im glad we have some pros on here thats for sure
Re: jebo wp40
I see what the problem is. Move the feeding_mode section below the nutrient transport mode section. That is overriding the feeding mode. My bad on that one.
805reefer
Re: jebo wp40
Post by 805reefer »
ok cool that fixed it i really appreciate all you help and time you spent with me on this thanks again im sure there will be more to come :mrgreen:
Smotz
Re: jebo wp40
Post by Smotz »
Any way this can get displayed on my tablet via the app?
Re: jebo wp40
If everything goes well, yes.
I'm working on a libraries update and creating a new class for these dc pumps.
They will have new XML tags for mode, speed and duration, which apps and the portal will be able to leverage and utilize it to display in the user interface.
Smotz
Re: jebo wp40
Post by Smotz »
rimai wrote:If everything goes well, yes.
Thats awesome.
bhazard
Re: jebo wp40
Post by bhazard »
Awesome! Loving the Reef Angel. Support is top notch.
Re: jebo wp40
