need custom PDE help
Re: need custom PDE help
You just gotta play with the x and y's now. You don't define x and y in your DrawCustomMain I believe so you shouldn't have them in your DrawText and stuff... for the 4 lines you added, just start changing the x and y values to what works...
Now it's just a matter of moving things aroudn where you want them.
jjdezek
Post by jjdezek »
ok still have a problem with the temp and ph showing up correctly. the big numbers overlap the words temp and ph. how do you offset the words from the numbers in each set of coding is that what the x+80,y+10 are for?
Yes, exactly. So just play around with it. You could always take out the x+ and y+ and just put hard coded numbers. It's odd that the temp and ph are offset though because the placement of the labels and variables should all be relative to each other, but not sure what's going on.
Either way you're on the right track.
jjdezek
Post by jjdezek »
heres my code
#define NUMBERS_8x16
ReefAngel.LCD.DrawDate(6, 112);
ReefAngel.LCD.DrawText(COLOR_INDIGO, COLOR_WHITE,25,5, "Jeremy's Reef");
DrawStatus (20,80);
DrawParams (5,40);
DrawParamsa (0,10);
    ReefAngel.WaterChangePorts = Port1Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardATO( Port1,60 );
    ReefAngel.StandardLights( Port3,18,0,10,0 );
    ReefAngel.WavemakerRandom( Port5,30,100 );
    ReefAngel.WavemakerRandom( Port6,30,100 );
    ReefAngel.StandardHeater( Port7,752,755 );
    ReefAngel.PWM.SetChannel( 0, PWMSlope(7,0,22,0,0,40,180,0) );
    ReefAngel.PWM.SetChannel( 1, PWMSlope(7,30,21,30,0,35,180,0) );
    ReefAngel.PWM.SetChannel( 2, PWMSlope(7,0,22,0,0,40,180,0) );
    ReefAngel.PWM.SetChannel( 3, PWMSlope(7,30,21,30,0,35,180,0) );
    ReefAngel.PWM.SetChannel( 4, PWMSlope(7,0,22,0,0,40,180,0) );
    ReefAngel.PWM.SetChannel( 5, PWMSlope(7,30,21,30,0,35,180,0) );
    if (hour()>=8 && hour()<12)
  ReefAngel.PWM.SetDaylight( ReefCrestMode(100,20,true) ); // ReefCrest at 100% +/- 20% on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(100,20,false) ); // ReefCrest at 100% +/- 20% on anti-sync mode
else if (hour()>=12 && hour()<18)
  ReefAngel.PWM.SetDaylight( ShortPulseMode(0,100,200,true) ); // Short pulse at 100% with 200ms pulse on sync mode
  ReefAngel.PWM.SetActinic( ShortPulseMode(0,100,200,false) ); // Short pulse at 100% with 200ms pulse on anti-sync mode
  ReefAngel.PWM.SetDaylight( LongPulseMode(0,100,10,true) ); // Long pulse at 100% with 10s pulse on sync mode
  ReefAngel.PWM.SetActinic( LongPulseMode(0,100,10,false) ); // Long pulse at 6100% with 10s pulse on anti-sync mode
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
   ReefAngel.PWM.SetActinic(0);
   ReefAngel.PWM.SetDaylight(0);
    ReefAngel.Portal( "jjdezek" );
void DrawParamsa(int x, int y){
char buf[16];
  ReefAngel.LCD.DrawText(DPColor,DefaultBGColor,x+60,y+10,"WP40L:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), DPColor, x+78, y+10,1);
ReefAngel.LCD.DrawText(APColor,DefaultBGColor,x+60,y+20,"WP40R:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),APColor, x+78, y+20,1);
void DrawParams(int x, int y) {
  char buf[16];
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+5,y,"Temp:");
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+80, y, "PH:");
  // Temp and PH
  y+=10;
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+80, y, buf, Num8x16);
  y+=5;
void DrawStatus(int x, int y) {
  int t=x;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"High",Font8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,y,"Low",Font8x16);
    ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_GREEN);
  } else {
    ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_RED);
  if (ReefAngel.LowATO.IsActive()) {
    ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_GREEN);
  } else {
    ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_RED);
jjdezek
Post by jjdezek »
Here is the screen
Looking good. Looks like the only thing left is to move the WP40R and WP40L labels over to the left. Something to keep in mind is that characters are 8pixels wide and you replaced two characters (AP and DP) with 5. That should tell you a bit how much to move them over.
jjdezek
Post by jjdezek »
For the wp40 I have it set at 0,10 and that's where it placed it. It's acting like the temp 1,2,and3 are still there.
Lets see the code. Its acting like the temps are still there because that was there default location when i copied the code for you. I suspect its not 0 and 10 as you think
jjdezek
Post by jjdezek »
I posted the code above the last screen shot
I see that! Kudos on creating your own function!!!!
You are indeed passing in 0,10 to your DrawParamsa function but inside that function the first draw is x+60!!!
So now go into your new function and adjust the values. You are well on your way!!
I feel like a proud poppa :D
jjdezek
Post by jjdezek »
yup that fixed it now its showing the full wp40L and wp40R centered in the screen
jjdezek
Post by jjdezek »
Sweet! Great job! Sorry I couldn't just do all that for you, but I do most of my replies from my phone or at work and don't have the compiler handy and drawing elements you really need the screen to test and see what you're doing. But it seems your picking it up pretty well and you built an awesome looking display! And now you can add C programmer to your resume!
jjdezek
Post by jjdezek »
Yeah I noticed that updated with correct one. Thanks for your time and help.
jjdezek
Post by jjdezek »
Yeah not yet still have some learning to do before I can put that on a resume. Next thing is to set up a toggle for the different wave patterns :D
