New section for code bits?
Ask in here.
There is a wealth of knowledge here, but it's scattered all over.
How about a new section, where each post is a single piece of code for solving a problem? No discussion (can be put somewhere else). That way things would be easy to search.
Something like this.
Turn Lights Down on Overheat
This will dim your LED's when the temperature hits 83 and return them to normal when the temperature drops below 80. Put it in the loop section.
// Lights down on overheat
    static boolean overheat=false;
    if (ReefAngel.Params.Temp[T1_PROBE] >= 830) overheat=true;
    if (ReefAngel.Params.Temp[T1_PROBE] <= 800) overheat=false;
    if (overheat)
      ReefAngel.PWM.SetActinic(15);
      ReefAngel.PWM.SetDaylight(15);
Any thoughts?
Re: New section for code bits?
I have been thinking about this for a while. This is exactly what the wiki should be used for.
That's why I asked if someone could make a nice outline for the different topics we could put code snippets in there and have them organized nicely.
http://forum.reefangel.com/wiki
I like it :)
Yes, you can use the wiki: http://forum.reefangel.com/wiki
I'm not a big wiki user, but if someone wants to make the sections, etc it would be pretty straight forward to filling in the snippets. I know there's like 5 ways to do ATO :) and 100 ways to do Feeding Modes, etc. :) I just need a structure to follow :)
