I recently purchased a wifi expansion and I got everything to work with the portal and my iphone but I cannot figure out how to connect the reef angel client suite to my wifi adapter. Am I missing a something in my code? because everything in the RA client settings is set correctly. thank you for your help
Here is my code:
ReefAngel.FeedingModePorts = Port3Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port5Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardHeater( Port1,773,778 );
ReefAngel.DosingPumpRepeat( Port6,0,50,15 );
ReefAngel.StandardLights( Port7,23,0,10,0 );
ReefAngel.SingleATO( true,Port8,10,0 );
ReefAngel.Portal( "tomek77pl" );
I also get this error message :
*****6/15/2013 8:23:34 PM*****
Message:
Inside WifiSend:
Unable to connect to the remote server
StackTrace:
at System.Net.WebClient.DownloadDataInternal(Uri address, WebRequest& request)
at System.Net.WebClient.DownloadString(Uri address)
at System.Net.WebClient.DownloadString(String address)
at ReefAngelWCFListener.ReefAngelListener.WifiSend()
