Jebao Reef Crest question
Smotz
I have my reefcrest set to 45,12 - why does it go as low as 25% - shouldn't this give me a min of 33% and a max of 57%?
ReeferBee
Re: Jebao Reef Crest question
Good question. Same thing with mine, not sure why this happens.
Barry
Current tank info: 150g mixed reef
"Some of the worst mistakes of my life were hair cuts" -Jim Morrison
Curious if your pump is set to sync or antisync?
If you are using the dosing pump class, it is hard coded to +/-10% for lagoon and +/-20% for reefcrest
DCPump class you mean...your getting ahead of me...need to put that bit together
ReeferBee
Daylight is true
Actinic is false
So anti sync... Right?
it's pre set to 20 so if you put 12 like the OP it's combined? Like 32 + - ?
Actinic is false
Barry
ReeferBee
I don't know what dcpump class is lol
Barry
Smotz
+1
Sent from my SCH-I605 using Tapatalk 4 Beta
Smotz
wpWavStr=45;rimai wrote:Where are you putting 12?
wpWavOff=12;
ReefAngel.DCPump.SetMode( ReefCrest,wpWavStr,wpWavOff );
This is the SetMode function for the DCPump class:
void DCPumpClass::SetMode(byte mode, byte speed, byte duration)
Smotz
rimai wrote:This is the SetMode function for the DCPump class:Code: Select all
can you elaborate how i would use that base on my code?
You can't.
Like I said.
Reef Crest is hard coded to 20% and Lagoon to 10%.
If you want to do your own function, you will need to use the custom mode.
Like I said.
Smotz
what is the correct way to use reefcrest in custom mode?rimai wrote:You can't.
Like I said.
if (ReefAngel.DCPump.Mode==Custom) {
ReefAngel.PWM.SetDaylight(ReefCrestMode(ReefAngel.DCPump.Speed,ReefAngel.DCPump.Duration, ReefAngel.DCPump.DaylightChannel-1));
ReefAngel.PWM.SetActinic(ReefCrestMode(ReefAngel.DCPump.Speed,ReefAngel.DCPump.Duration, ReefAngel.DCPump.ActinicChannel-1));
} else {
ReefAngel.DCPump.UseMemory=true;
although Roberto, I think we should allow Duration to be part of the default mode for ReefCrest. You could say ReefAngel.DCPump.Duration for Lagoon and ReefAngel.DCPump.Duration*2 for ReefCrest. That's my $.02 Just seems a waste of custom mode :)-
Isn't it just going to confuse people?
Set offset with the duration field?
Smotz
I know I'm confused.rimai wrote:Isn't it just going to confuse people?
I set my reefcrest to a certain strength depending on the hour. I wanted to take advantage of the new class and just set my portal settings to custom.
I don't know... makes perfect sense to me.rimai wrote:Isn't it just going to confuse people?
