Help with code
Drs1210
Help with code
Post by Drs1210 »
I just changed my display, but I'm having a few problems with it. For one, one of my relay box's on the screen is flickering. The other thing is that I have in my code where its suppose to display what mode my wp40 is in, but its shown where the date and time is at. Can anybody help me with this?
// Define Relay Ports by Name
#define KalkDoser          1
#define WCEmpty            2
#define Autotopoff         3
#define Refugium           4
#define KalkStirrer        5
#define WCFill             6
#define Heater             7
#define Return             8
#define RODIValve          Box1_Port1
#define Skimmer            Box1_Port2
#define Unused             Box1_Port3
#define Unused             Box1_Port4
#define Unused             Box1_Port5
#define Unused             Box1_Port6
#define Unused             Box1_Port7
#define Unused             Box1_Port8
byte wpMode;
int WCstatus;
  InternalMemory.LCDID_write(0);
  ReefAngel.AddDateTimeMenu();
  ReefAngel.PHMin=546;//PH7.0
  ReefAngel.PHMax=734;//PH10.0
  ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port7Bit | Port8Bit;
  ReefAngel.Timer[1].SetInterval(180);
  ReefAngel.Relay.On( Return ); // Return Pump
  ReefAngel.Relay.On( Skimmer ); // Skimmer
  CheckPower();           // Monitor for power outages
  ReefAngel.PWM.SetChannel( 0, PWMSlope(9,30,21,30,17,100,60,0) );
  ReefAngel.PWM.SetChannel( 1, PWMSlope(9,30,21,30,17,100,60,0) );
  ReefAngel.PWM.SetChannel( 2, PWMSlope(9,30,21,30,17,100,60,0) );
  ReefAngel.PWM.SetChannel( 3, PWMSlope(9,30,21,30,17,100,60,0) );
  ReefAngel.PWM.SetChannel( 4, PWMSlope(9,30,21,30,17,100,60,0) );
  ReefAngel.PWM.SetChannel( 5, PWMSlope(9,30,21,30,17,100,60,0) );
  ReefAngel.WaterLevelATO(Port3,120,43,45);
  if (ReefAngel.LowATO.IsActive()) ReefAngel.Relay.On(RODIValve);
  if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(RODIValve);
  ReefAngel.DosingPumpRepeat( Port1,0,45,6 );
  if (ReefAngel.Params.PH>=850) ReefAngel.Relay.Off(KalkDoser);
  ReefAngel.StandardLights( Port4,20,0,8,0 );
  ReefAngel.Relay.Set(Port5,now()%7200<900);
  ReefAngel.StandardHeater( Port7,780,785 );
  if (hour()>=6 && hour()<11)
    ReefAngel.PWM.SetDaylight( TidalSwellMode(60,true) ); // Tidal Swell at 60% on sync mode
    ReefAngel.PWM.SetActinic( TidalSwellMode(60,false) ); // Tidal Swell at 60% on anti-sync mode
    wpMode=1;
  else if (hour()>=11 && hour()<15)
    ReefAngel.PWM.SetDaylight( ReefCrestMode(65,20,true) ); // ReefCrest at 60% +/- 20 on sync mode
    ReefAngel.PWM.SetActinic( ReefCrestMode(65,20,false) ); // ReefCrest at 60% +/- 20 on anti-sync mode
    wpMode=2;
  else if (hour()>=15 && hour()<18)
    ReefAngel.PWM.SetActinic( NutrientTransportMode(75,90,2000,false) ); // Nutrient Transport on anti-sync mode
    wpMode=3;
  else if (hour()>=18 && hour()<20)
    wpMode=2;
  else if (hour()>=20 && hour()<23)
    wpMode=1;
    ReefAngel.PWM.SetDaylight( SineMode(38,48,30,true) ); // Sine at 30% 45% with for 30s on sync mode
    ReefAngel.PWM.SetActinic( SineMode(38,48,30,false) ); // Sine at 30% 45% with for 30s on anti sync mode
    wpMode=4;
    if (WCstatus==-1)
      ReefAngel.Timer[1].Start();
      WCstatus=0;
      ReefAngel.Relay.On(WCEmpty);
      WCstatus=1;
    if (ReefAngel.WaterLevel.GetLevel()<=15 && WCstatus>0 && WCstatus<10) WCstatus++;
    if (ReefAngel.WaterLevel.GetLevel()<=15 && WCstatus==10)
      WCstatus=11;
      ReefAngel.Relay.Off(WCEmpty);
      ReefAngel.Relay.On(WCFill);
    if (ReefAngel.WaterLevel.GetLevel()<=81 && WCstatus>10 && WCstatus<20) WCstatus++;
    if (ReefAngel.WaterLevel.GetLevel()>81 && WCstatus==20)
      ReefAngel.Relay.Off(WCFill);
      ButtonPress++;
    WCstatus=-1;
  ReefAngel.Portal("Drs1210");
  ReefAngel.ShowInterface(); // Display everything on the LCD screen
void CheckPower() {
  static boolean powerOutage=false;
  // Power Outage - turn off everything
  if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY)) // Expansion Relay NOT present
    powerOutage=true;
    ReefAngel.Relay.Off(Refugium);
    ReefAngel.Relay.Off(KalkStirrer);
    ReefAngel.Relay.Off(Heater);
    ReefAngel.Relay.Off(Skimmer);
  // Power Restored - Turn things back on
  if (powerOutage && ReefAngel.Relay.IsRelayPresent(EXP1_RELAY))
    LastStart=now();
    powerOutage=false;
    ReefAngel.Relay.On(Return);
    ReefAngel.Relay.On(Skimmer);
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawDate(6, 3);
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,56,84, "Res");
  ReefAngel.LCD.DrawText(COLOR_GREEN,255, 45, 83, "H");
  ReefAngel.LCD.DrawText(COLOR_GREEN,255, 45, 93, "I");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 77, 83, "L");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 77, 93, "O");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 75, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 101, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 78, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 88, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 98, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 78, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 88, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 98, "|");
  ReefAngel.LCD.DrawText(0,255,10,30,"Tank");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,100,30,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 91, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
  ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
  ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,8,68,"WC");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_CHOCOLATE, 25, 68, 10);
  ReefAngel.LCD.DrawText(0,255,66,68,"Room");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_MEDIUMORCHID, 94, 68, 10);
  ReefAngel.LCD.DrawText(0,255,15,83,"WL");
  ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(),1);
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 10, 92, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,26,92," %");
  // WP40 Mode
  ReefAngel.LCD.DrawText(0,255,x,y,"Jebao WP40 Mode:");
  ReefAngel.LCD.Clear(DefaultBGColor,x,y,128-x,y+8);
  if (wpMode == 1) ReefAngel.LCD.DrawText(COLOR_GREEN,255,x,y,"Tidal Swell");
  else if (wpMode == 2) ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,x,y,"Reef Crest");
  else if (wpMode == 3) ReefAngel.LCD.DrawText(COLOR_GOLD,255,x,y,"Nutrient");
  else if (wpMode == 4) ReefAngel.LCD.DrawText(COLOR_RED,255,x,y,"Sine Mode");
  ReefAngel.LCD.DrawText(0,255,96,83,"WP40");
  ConvertNumToString(text, ReefAngel.PWM.GetActinicValue(),1);
  ReefAngel.LCD.DrawLargeText(COLOR_OLIVE, 255, 99, 92, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,115,92," %");
  // Main Relay box
  ReefAngel.LCD.DrawOutletBox(14, 106, TempRelay);
  // Relay Expansion
  ReefAngel.LCD.DrawOutletBox( 14, 118, TempRelay );
    ReefAngel.LCD.FillCircle(57,96,3,COLOR_RED);
    ReefAngel.LCD.FillCircle(57,96,3,COLOR_GREEN);
    ReefAngel.LCD.FillCircle(70,96,3,COLOR_RED);
    ReefAngel.LCD.FillCircle(70,96,3,COLOR_GREEN);
Drs1210
Re: Help with code
Post by Drs1210 »
#define KalkDoser          1
#define WCEmpty            2
#define Refugium           4
#define WCFill             6
#define Heater             7
#define Return             8
byte wpMode;
int WCstatus;
  if (hour()>=6 && hour()<8)
    ReefAngel.PWM.SetActinic( TidalSwellMode(70,false) ); // Tidal Swell at 70% on anti-sync mode
    wpMode=0;
  else if (hour()>=8 && hour()<9)
    ReefAngel.PWM.SetActinic( ReefCrestMode(65,20,false) ); // ReefCrest at 65% +/- 20 on anti-sync mode
    wpMode=1;
  else if (hour()>=9 && hour()<13)
    ReefAngel.PWM.SetActinic( ElseMode(60,30,false )); // ElseMode on anti-sync mode, 60 +/- 30%
    wpMode=3;
  else if (hour()>=13 && hour()<16)
    wpMode=2;
  else if (hour()>=16 && hour()<20)
    wpMode=3;
  else if (hour()>=20 && hour()<21)
    wpMode=1;
  else if (hour()>=21 && hour()<23)
    wpMode=0;
    ReefAngel.PWM.SetActinic( SineMode(40,55,30,false) ); // Sine at 40% 55% with for 30s on anti sync mode
    wpMode=4;
  // If we are feeding override the schedule
  if (now()%86400==36000)
    ReefAngel.FeedingModeStart(); // 36000 is number of seconds from midnight
    ReefAngel.PWM.SetDaylight(30);
    ReefAngel.PWM.SetActinic(30);
    wpMode=5;
    else  {
    ReefAngel.PWM.SetDaylight(100);
  if (now()%86400==25200)
    ReefAngel.FeedingModeStart(); // 25200 is number of seconds from midnight
    wpMode=5;
  else  {
    if (WCstatus==-1)
      WCstatus=0;
      WCstatus=1;
      WCstatus=11;
      ButtonPress++;
    WCstatus=-1;
void CheckPower() {
    powerOutage=true;
    LastStart=now();
    powerOutage=false;
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,56,83, "Res");
  ReefAngel.LCD.DrawText(COLOR_GREEN,255, 45, 91, "I");
  ReefAngel.LCD.DrawText(COLOR_RED,255, 77, 91, "O");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 98, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 86, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 95, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 86, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 95, "|");
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 10, 91, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,26,91," %");
  // WP40 Mode
  ReefAngel.LCD.DrawText(0,255,18,12,"Jebao WP40 Mode:");
  ReefAngel.LCD.Clear(COLOR_WHITE, 1, 21, 132, 21);
  if (wpMode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255, 23, 21,"Tidal Swell");
  else if (wpMode == 1) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255, 25, 21,"Reef Crest");
  else if (wpMode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255, 8, 21,"Nutrient Trnsp.");
  else if (wpMode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255, 30, 21,"Else Mode");
  else if (wpMode == 4) ReefAngel.LCD.DrawLargeText(COLOR_RED,255, 30, 21,"Sine Mode");
  else if (wpMode == 5) ReefAngel.LCD.DrawLargeText(COLOR_TEAL,255, 21, 21,"Feeding Mode");
  ReefAngel.LCD.DrawLargeText(COLOR_OLIVE, 255, 99, 91, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,115,91," %");
  // Main Relay box
  // Relay Expansion
    ReefAngel.LCD.FillCircle(57,94,3,COLOR_RED);
    ReefAngel.LCD.FillCircle(57,94,3,COLOR_GREEN);
    ReefAngel.LCD.FillCircle(70,94,3,COLOR_RED);
    ReefAngel.LCD.FillCircle(70,94,3,COLOR_GREEN);
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Drs1210
Re: Help with code
Post by Drs1210 »
Nevermind I figured it out.
rossbryant1956
checkpower
Post by rossbryant1956 »
I saw in your loop section a reference to
then later on I see
void CheckPower() {
This seems cleaner than what I am doing. Can you explain why you did it this way? Thx
Re: Help with code
It came from my ino. I have tried to keep all my code features as functions so they are easier to copy for others, follows better coding standards and keeps loop() more readable.
rossbryant1956
Re: Help with code
okay, so in the loop you are calling the function "checkpower" so that as it loops thru it does the commands listed in the void section, yes?
Next question, what changes do I need to make (if any) to this line if I have multiple expansion relays that will be off during an outage? I have a total of three relay boxes.
thx
Re: Help with code
Nothing to that line, unless you change which relay exp is non-ups powered.
All you need to change in relation is which ports you are turning on/off.
rossbryant1956
Re: Help with code
both exp relays 2 & 3 will be non-ups powered.
Re: Help with code
So you can test either or both. Do you want the condition that both are off?
rossbryant1956
Re: Help with code
in my design both relays (2&3) will be non-ups. Thx
Re: Help with code
This one will test that both relays are offline. If you want it to be either change && to ||
  if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY) && (!ReefAngel.Relay.IsRelayPresent(EXP2_RELAY)) // Expansion Relay NOT present
