Date and time issue
Date and time issue
Not sure what's going on. I have everything coded from the wizard and I am running the dimming module. For some reason, the lights are not staying on schedule. They don't come on at the right time and the dimming is not staying on schedule. When I go to the portal and update time, it jumps back in line. I have to do this at least 2x a day. Any thoughts?
Re: Date and time issue
It jumps back in time right when you update it through the portal or later on?
Right when I update it.
It does the same with my iPhone. Don't have android.
I learned something today...
I didn't know iphone had support to update date/time
Glad to be the one to bring that little nugget to light.
Still not sure why the lights and dimming do not keep on schedule unless I do an update to the time/date.
Could it have to do with the internal memory?
I had an issue with the battery in my RA. One terminal was loose so anytiem the controller reset I lost the time... just something to consider looking at..
I had to do it three times today and then it wouldn't even turn the lights off.
I ran the initial memory script and then just built everything into the pde. That should erase the internal memory and all run straight off the pde right?
Yes. It seems to be keeping the right time.
Does it keep the time if you power off RA and bring the power back on? Just to be sure, wait about 10 seconds before you power back on.
I'm not quite understanding yet how it is not following the schedule, so I want to make sure that the time is correct and that it is keeping the time correctly and following it correctly before we move on to something else.
Nope - I unplugged it and it came back on 25 minutes earlier. Was 9:15 and now it's 8:52
Then I go back to the iPhone app and update time and it goes back.
When I got up this morning the time on the controller was 12:46am - actual time 6:48am.
Ok. Am I sending everything back or just the board?
I still have the 32 bit board from the upgrade. I can swap out the plus board and send it - might need some help slimming Down the code to run on the old board.
Here is the code:
Brian
Please let me know how I can slim this down to work with the 32 bit board...#include <ReefAngel_Features.h>
ReefAngel.FeedingModePorts = Port4Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.DosingPumpRepeat( Port1,0,360,4 );
ReefAngel.DosingPumpRepeat( Port2,0,360,4 );
ReefAngel.StandardLights( Port3,10,0,22,0 );
ReefAngel.Relay.DelayedOn( Port4,10 );
ReefAngel.StandardHeater( Port5,795,805 );
ReefAngel.Relay.Set( Port8, !ReefAngel.Relay.Status( Port3 ) );
ReefAngel.PWM.SetChannel( 0, PWMParabola(10,0,22,0,10,35,10) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(10,30,21,30,0,30,0) );
ReefAngel.PWM.SetChannel( 2, PWMParabola(10,30,21,30,0,5,0) );
ReefAngel.PWM.SetChannel( 3, PWMParabola(10,30,21,30,0,10,0) );
ReefAngel.Portal( "blawson" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
Brian
Well how about that. Guess I didn't need the upgraded board.
So this is interesting... The old board is keeping time fine. When I came home from work, the LEDs didn't look right - too much blue. So I check the time and it was spot on. The screen showed the right led levels. I unplugged the dimmer box and only two sets of the four LEDs lit. Plugged it back in and nothing lit. I played with it I bit and then decided to check if the new board would light them. Switched the boards and viola they worked. Switched the boards back and they are working again.
I have no ideal what happened but wanted to see if anyone had some thoughts?
