Something like:
9am - 10am moon lights
10am - 8pm actinics
11am - 7pm day lights
8pm - 12:00am moon lights
I already have my normal light schedule set up so that the moon lights come on after my main lights go out but would like to have them on before and after main lights. Here is my current code:
ReefAngel.Init(); // Initialize Controller
ReefAngel.AddStandardMenu();
ReefAngel.AddDateTimeMenu();
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit; // Turn off Ports 1 and 5 when Feeding Mode is activated
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit; // Turn off Ports 1, 5 when Water Change Mode is activated
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port6Bit | Port7Bit; // Turn off Ports 3, 4, 6 and 7 when overheat occurs
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit; // Turn on/off Ports 3 and 4 when Light On/Off menu option is selected
ReefAngel.OverheatProbe = T1_PROBE; // Use Temperature probe 1 to check for overheat
//These ports are always on
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port8);
ReefAngel.LCD.DrawLargeText(COLOR_STEELBLUE,COLOR_WHITE,28,121,"Joe's Reef"); // Display Reef Angel banner
ReefAngel.StandardLights(Port2,20,0,1,0); // Moonlights
ReefAngel.StandardLights(Port3,60); // Actinic Lights
ReefAngel.StandardLights(Port4); // Daylight Lights
ReefAngel.StandardHeater(Port6,780,790); // Heater
ReefAngel.StandardLights(Port7,0,0,6,0); // Refugium Light
ReefAngel.ShowInterface(); // Display everything on the LCD screen
ReefAngel.Portal("jabregousmc");
}Joe
