The controller screen shows 20, portal shows 20 and doesn't show the the pump settings. I must have something wrong but cant see it.
Also it the pumps runs really slow and the it stops
I appreciate the help
ReefAngel.FeedingModePorts = Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit;
InternalMemory.OverheatTemp_write( 851 );
//Feeedin mode length
ReefAngel.Timer[FEEDING_TIMER].SetInterval(300);
ReefAngel.Relay.On( Box1_Port1);
ReefAngel.StandardLights( Port1,14,0,19,0 );
ReefAngel.StandardLights( Port2,15,0,20,0 );
ReefAngel.StandardLights( Port3,19,55,22,0 );
ReefAngel.StandardLights( Port4,14,0,20,15 );
ReefAngel.StandardHeater( Port5,780,785 );
ReefAngel.StandardFan( Port6,780,800 );
ReefAngel.Relay.DelayedOn( Port7,60 );
ReefAngel.StandardLights( Box1_Port5,22,0,16,0 );
if (ReefAngel.DCPump.Mode==Custom)
ReefAngel.PWM.SetDaylight( ElseMode(70,30,true )); // ElseMode on sync mode, 70 +/- 30%
} else {
static time_t StartFeeding=0;
StartFeeding=now(); // if we entered feeding mode, register what time it was.
if (now()-StartFeeding > 1800 && now()-StartFeeding < 5400) // if feeding started between 1800 and 5400 seconds
ReefAngel.PWM.SetActinic(100);
ReefAngel.PWM.SetActinic(45);
ReefAngel.Portal( "ganjero" );
int x,y;
// Parameters
// Main Relay Box
// Relay Expansion
// Date and Time
static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
static int Delay = random( 500, 3000); // Set the initial delay
static int NewSpeed = MidPoint; // Set the initial speed
static int AntiSpeed = MidPoint; // Set the initial anti sync speed
if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
Delay=random(500,5000); // If so, come up with a new delay
int ChangeUp = random(Offset); // Amount to go up or down
if (random(100)<50) // 50/50 chance of speed going up or going down
LastChange=millis(); // Reset the time of the last change
if (WaveSync)
return NewSpeed;
return AntiSpeed;
