Feed Mode
ganjero
Feed Mode
I have two jebao pumps on my dimming ports, one in the display and one in the sump. What I need is the one in the display to run in the custom random ode 24/7 and the one in the sump to run at a constant flow at 30% and 30min after feed mode is entered run at 100% for an hour.
Re: Feed Mode
There are several random modes in the forums. Pick the one you like and use it.
For the feeding override, try this:
static StartFeeding=0;
StartFeeding=now(); // if we entered feeding mode, register what time it was.
if (now()-StartFeeding > 1800 && now()-StartFeeding < 5400) // if feeding started between 1800 and 5400 seconds
ReefAngel.PWM.SetActinic(100);
ReefAngel.PWM.SetActinic(30);
ganjero
Re: Feed Mode
Thank you, I'll try it out Im new to this controller and languange. COuld you please point out where do I insert that in my code?
ganjero
Re: Feed Mode
Tried the above but the pump runs at 45% constant but it doesnt do the 100% 1 hours that I want
ReefAngel.FeedingModePorts = Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port4Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit;
InternalMemory.OverheatTemp_write( 851 );
ReefAngel.Relay.On( Box1_Port1);
ReefAngel.StandardLights( Port1,14,0,19,0 );
ReefAngel.StandardLights( Port2,15,0,20,0 );
ReefAngel.StandardLights( Port3,19,55,22,0 );
ReefAngel.StandardLights( Port4,14,0,20,15 );
ReefAngel.StandardHeater( Port5,780,785 );
ReefAngel.StandardFan( Port6,780,800 );
ReefAngel.Relay.DelayedOn( Port7,60 );
ReefAngel.StandardLights( Box1_Port5,22,0,16,0 );
if (ReefAngel.DCPump.Mode==Custom)
ReefAngel.PWM.SetDaylight( ElseMode(70,30,true )); // ElseMode on sync mode, 70 +/- 30%
static time_t StartFeeding=0;
ReefAngel.PWM.SetActinic(45);
ReefAngel.Portal( "ganjero" );
int x,y;
// Parameters
// Main Relay Box
// Relay Expansion
// Date and Time
static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
static int Delay = random( 500, 3000); // Set the initial delay
static int NewSpeed = MidPoint; // Set the initial speed
static int AntiSpeed = MidPoint; // Set the initial anti sync speed
if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
Delay=random(500,5000); // If so, come up with a new delay
int ChangeUp = random(Offset); // Amount to go up or down
if (random(100)<50) // 50/50 chance of speed going up or going down
LastChange=millis(); // Reset the time of the last change
if (WaveSync)
return NewSpeed;
return AntiSpeed;
Re: Feed Mode
I just tested this code and it worked just fine.
I changed 1800 seconds and 5400s to 18 and 54 to make it faster.
ganjero
Re: Feed Mode
When you tested the code (i assumed you tested my entire code? or was it just the feeding part?) after activating the feed mode it the actinic channel when to 100 after 18 seconds and back to 45 after 54?rimai wrote:I just tested this code and it worked just fine.
BTW how long is the feed mode and can you change the length of it?
Re: Feed Mode
Yes, I tested as is posted.
I started the feeding and stopped it after 1 second. It didn't want to wait for 15min
ganjero
Re: Feed Mode
Thank you, I have to try it again. I'm not sure if you saw my q above, can you change the length of the feed mode? Let's say to 5minrimai wrote:Yes, I tested as is posted.
