Logic based on pH
btorrenga
Logic based on pH
Post by btorrenga »
I want to run a function only if pH is less than 8.0. Is the proper way to do so something like the following syntax? I guess my question really is "how do I query pH?"
  if (ReefAngel.Params.PH() < 800)
    ReefAngel.Relay.On(Box1_Port6;
    ReefAngel.Relay.Off(Box1_Port6);
Re: Logic based on pH
Yes but there is a problem with that. The probes fluctuate a lot so it will flicker between 799-801 for instance changing every few ms. The logic you have will turn that port on and off a lot.
We have a function you can use similar to the heater function
ReefAngel.PHControl(relay, lowph, highph);
This will allow you to set a range for when it turns on to when it turns off.
This function turns the device on when ph <= lowph and off when ph >= highph
There is another function CO2Control that takes the same args but does the opposite.
btorrenga
Post by btorrenga »
Hmm, ok, I have some things to work through then.
When inputting values into the portal for pH on and off, would I enter 8, or 800? (or 8.3 and 830?)
If you use the portal to set the values you need to call the function with just the relay argument.
I'm not sure the syntax in the portal
