Coding dosing pumps
lucho
Coding dosing pumps
I need help understanding the coding of dosing pumps. I would like to use internal memory as much as possible. Can somebody point me in the right direction? Thanks
Re: Coding dosing pumps
If you look inside the ReefAngel.cpp file, you will see what the function does.
Here is the snippet:
You can use those two memory locations to change the behavior of the dosing pump.
void ReefAngelClass::DosingPumpRepeat1(byte Relay)
// 0 minute offset
DosingPumpRepeat(Relay, 0,
InternalMemory.DP1RepeatInterval_read(),
InternalMemory.DP1Timer_read());
lucho
Thanks Roberto! Very helpful
