I am lost now as to what i have to do. Need all the advise i can get to make this work.
I have already connected the PWM dimming module to the RA and have also loaded the test code following the below instruction from the Manual:
Uploading the test code
1. Start your Arduino software
2. Open the PWM Expansion test code by going to menu File->Sketchbook->Example Codes and selecting
CustomMainScreen_PWMExpansion
3. Upload the code to your Reef Angel Controller.
Now Question is :
1)can i just cut the jebao cable connector (which is suppose to go to the Daylight or actinic dimming port)
and connect either end to channel 1 and the other to Gnd?
2)how to code if i want to run my return pump on
constant 100% in the day (12pm-10pm)
constant 80% (10pm-12am)
constant 60% (12am-12pm)
3) code it to run at 20% on feeding mode
4) do i need to change anything in the library?
Thank you all in advance
