Relay Expansion Module
clw143
Does adding a relay expansion module and relay box give you 2 additional PWM ports?
Re: Relay Expansion Module
Nope, but if they are different you can swap with your main relay box.
clw143
That seem like an opportunity for you all to expand on
Not sure what you mean, but technically its not possible as the expansion bus is only 4 wires and no way to talk to the pwm ports and control the relays on that bus.
- Sacohen
clw143 wrote:That seem like an opportunity for you all to expand on
It's been brought up before, but as lnevo said it a hardware limitation although it would be nice to have use of the additional PWM ports. the system is always changing and updating so who knows what the future entails.
