First, I apologize for asking a question that has probably been asked a million times. I've searched and searched the forums and have yet to find any answer to my specific problem. It probably doesn't help that I'm a total newb to writing code, so I probably wouldn't recognize the answer if I saw it... I just received a Jebao WP40 along with the Reef Angel cable to connect to my RA controller. I can't seem to get the Jebao to work though. It just plain doesn't do anything when connected to my RA via the cable.
Two questions:
I first should double check where to plug the cable into on the RA? I'm assuming the ATO Port? Does it matter which one?
Next, if it's plugged in correctly then it must be my code. Please help. Just in case, I do not have any expansion modules.
Newb needs help
abfranklin3
Re: Newb needs help
Apparently I either don't know or don't have the access to post my code....
abfranklin3
Re: Newb needs help
byte offset = 3;
byte waterLevel = ReefAngel.WaterLevel.GetLevel();
byte dispLights = ReefAngel.PWM.GetDaylightValue();
byte sumpLights = ReefAngel.PWM.GetActinicValue();
byte atoPort = 3;
// Header = Title + Date and Time
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor, 35, offset, "Allan's Reef");
ReefAngel.LCD.DrawDate(6, offset + 10);
ReefAngel.LCD.Clear(COLOR_BLACK, 1, offset + 20, 128, offset + 20);
offset = 26;
// Main Relay Box & Parameters
ReefAngel.LCD.DrawCircleOutletBoxHorizontal(2, offset, TempRelay);
ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 50, offset, "Temp:");
ReefAngel.LCD.DrawLargeText(COLOR_PURPLE, 255, 49, offset + 9, text, Font8x16);
ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 101, offset, "pH:");
ReefAngel.LCD.DrawLargeText(COLOR_ORANGE, 255, 93, offset + 9, text, Font8x16);
ReefAngel.LCD.Clear(COLOR_BLACK, 1, offset + 23, 128, offset + 23);
offset = offset + 27;
// Lights
if (dispLights > 0)
ReefAngel.LCD.DrawText(COLOR_GREEN, DefaultBGColor, 10, offset, "Display");
ReefAngel.LCD.DrawText(COLOR_RED, DefaultBGColor, 10, offset, "Display");
if (sumpLights > 0)
ReefAngel.LCD.DrawText(COLOR_GREEN, DefaultBGColor, 72, offset, "Refugium");
ReefAngel.LCD.DrawText(COLOR_RED, DefaultBGColor, 72, offset, "Refugium");
ConvertNumToString(text, dispLights, 1);
strcat(text, "%");
ReefAngel.LCD.DrawLargeText(COLOR_BLUE, DefaultBGColor, 15, offset + 9, text, Font8x16);
ConvertNumToString(text, sumpLights, 1);
strcat(text, "%");
ReefAngel.LCD.DrawLargeText(COLOR_BLUE, DefaultBGColor, 95, offset + 9, text, Font8x16);
ReefAngel.LCD.Clear(COLOR_BLACK, 1, offset + 24, 128, offset + 24);
// Water Level & ATO
if (waterLevel >= 100)
ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor, 5, offset, "Tank Level");
ReefAngel.LCD.DrawLargeText(COLOR_BLUE, DefaultBGColor, 25, offset + 9, "Full", Font8x16);
else if (waterLevel >= 50)
ReefAngel.LCD.DrawText(COLOR_ORANGE, DefaultBGColor, 5, offset, "Tank Level");
ConvertNumToString(text, waterLevel, 1);
strcat(text, "%");
ReefAngel.LCD.Clear(DefaultBGColor, 1, offset + 9, 128, offset + 18);
ReefAngel.LCD.DrawLargeText(COLOR_ORANGE, DefaultBGColor, 25, offset + 9, text, Font8x16);
ReefAngel.LCD.DrawText(COLOR_RED, DefaultBGColor, 5, offset, "Tank Level");
strcat(text, "%");
ReefAngel.LCD.DrawLargeText(COLOR_RED, DefaultBGColor, 25, offset + 9, text, Font8x16);
ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 70, offset + 2, "ATO:");
ReefAngel.LCD.DrawText(COLOR_GREEN, DefaultBGColor, 95, offset + 2, "Avail");
ReefAngel.LCD.DrawText(COLOR_RED, DefaultBGColor, 95, offset + 2, "Empty");
ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 72, offset + 12, "Pump:");
if ((TempRelay&(1<<(atoPort - 1)))==1<<(atoPort - 1))
ReefAngel.LCD.Clear(DefaultBGColor, 102, offset + 12, 128, offset + 21);
ReefAngel.LCD.DrawText(COLOR_GREEN, DefaultBGColor, 102, offset + 12, "On");
ReefAngel.LCD.DrawText(COLOR_RED, DefaultBGColor, 102, offset + 12, "Off");
// Wavemaker
ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 8, offset, "Jebao Mode");
ReefAngel.LCD.DrawText(COLOR_BLACK, DefaultBGColor, 95, offset, "Speed");
ReefAngel.LCD.DrawLargeText(COLOR_ORANGE, DefaultBGColor, 5, offset + 9, "Reef Crest", Font8x16);
ReefAngel.LCD.DrawLargeText(COLOR_GREEN, DefaultBGColor, 98, offset + 9, "XX%", Font8x16);
Ports assignment:
Port1 - ATO
Port2 - Refugium Light
Port3 - Actinic Fixture
Port4 - Daylight fixture
Port5 - Powerhead
Port6 -
Port7 - Heater
Port8 -
ReefAngel.PHMin=520;
ReefAngel.PHMax=801;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.DosingPumpRepeat( Port1,0,120,20); // Add water for 20 seconds every 120 minutes with 0 minutes offset
ReefAngel.StandardLights( Port2,19,30,9,30 );
ReefAngel.StandardLights( Port3,9,30,19,30 );
ReefAngel.StandardLights( Port4,10,0,19,0 );
ReefAngel.StandardHeater( Port7,751,761 );
ReefAngel.DCPump.SetMode( ReefCrest,30,10 );
byte offset = 3;
byte atoPort = 3;
offset = 26;
// Lights
if (dispLights > 0)
if (sumpLights > 0)
strcat(text, "%");
strcat(text, "%");
strcat(text, "%");
strcat(text, "%");
// Wavemaker
Ports assignment:
Port1 - ATO
Port5 - Powerhead
Port6 -
Port7 - Heater
Port8 -
abfranklin3
Re: Newb needs help
Thanks! I actually tried that too and forgot to mention. The Jebao still didn't work plugged into the relay box, so it must be in the code I guess. Any suggestions?
abfranklin3
Re: Newb needs help
Figured it out!
Changed my code to this:
ReefAngel.StandardLights( Port5,10,0,19,0 );
ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 80% +/- 20% on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,false) ); // ReefCrest at 80% +/- 20% on anti-sync mode
