Possible relay issue??
ecam
I have an ATI 80w 8 bulb fixture plugged into my unit. Im overriding the menu from auto to on for the lights... this will stay on and then reset to auto and turn off . Is this a possible relay issue? or normal function?
Re: Possible relay issue??
That's expected behavior when the controller reboots.
The controller is rebooting probably due to electrical noise in the expansion bus or the portal server generating an error.
There is a known bug that will be patched in the next release to prevent the controller rebooting when the portal server generates an error.
Amos Poh
ecam wrote:I have an ATI 80w 8 bulb fixture plugged into my unit. Im overriding the menu from auto to on for the lights... this will stay on and then reset to auto and turn off . Is this a possible relay issue? or normal function?
Is 80w x 8 too much for the relay to handle?
