ATO code is not working properly.
- Sacohen
- Sacohen
Re: ATO code is not working properly.
Lee;
Again thanks for all your help and even posting this modified code for the pump change.
Is there anything I need to to in the portal to activate it or will it start working randomly once it is uploaded?
I know it only changes modes once a day or after every reboot.
If there was a particular mode that I wanted (say short pulse) for a little bit,would I just change it in the portal and then on the next day or reboot it will kick into random mode again?
Finally do any of the speed and duration setting need to be set in the portal for this to work or is just works with my parameters of 40% speed with a 20% variation for the other modes?
Sorry for all the questions I jut want to make sure I understand how it works.
Thanks;
Thanks;
If you look at the code where I'm calling elsemode i replaced 40 with the speed setting in the portal. I left the 20% but you could change it to use duration instead for that param (thats what i do
If you are in custom mode it will use the random mode for that day. If you want something different just change it on the portal but you'll have to change it back to go back to the random/custom mode.
In my INO i have a separate memory variable that i use so i can change the custom sub-mode but that's getting more complicated because no easy way to change it...but if you want it we can do it..
- Sacohen
Still having issues with the ATO coming on for 2-5 seconds every 30 seconds or so.
Very strange.
The only thing I have changed is I switched the DeNit_Pump and DeNit_Doser to the way they should be.
Before I wrote this post I went back to a saved copy of the code before I changed anything and it is still doing it.
Salinity is 35.6ppt and WL is at the lower limit of 31%.
If it drops below 31% the pump should kick in and and stay on until it reached the upper limit of 34%, but it kicks in for a couple of seconds until it gets above 31% and then shuts off. Then a min or so later it does it again.
This can get to be very annoying, especially since this ATO pump is so noisy when it is on.
Any ideas on why this is happening?
Very strange.
Is this during the process or is this all the time? If it's all the time, it's possible one of the other checks we made is shutting it off.. I doubt the high ato is getting reached... but maybe the switch is flakey? More likely is the salinity probe. I've seen my ph probe bounce around sometimes and when you look at my charts it is not a stable number.. we can probe this like so..
Put that instead of the current salinity check. What will happen is that it will mask off the port.. You're ATO timeout will also probably kick in and you'll see the blue (iphone) or green (android) or it will be OFF instead of AUTO in the portal. If this happens we know its the salinity probe.
What we'll need to do is put some time of countdown that we want to see salinity 33.5 for 10 seconds lets say before we disable the ATO. In this case we may want to leave it with the override so you can address the salinity.. but this way if it blips you aren't getting the micro bursts...
// Disable ATO if Salinity is below 33.5.
if (ReefAngel.Params.Salinity<335)
ReefAngel.Relay.Override(ATO_Pump,0);
And if that doesn't do it, we can try shifting the same code to the ATO switch... one by one we'll find it.
- Sacohen
It happens all the time. The ATO during the process is working great.
I'll try switching out the Salinity code and see what happens.
Cool...sounds like probe jitter to me.lnevo wrote:And if that doesn't do it, we can try shifting the same code to the ATO switch... one by one we'll find it.
Roberto, i think i've seen sone code you've posted to help with that? I dont want to reinvent and troubleshoot the wheel
Are you referring to this?
http://forum.reefangel.com/viewtopic.ph ... nge#p31048
- Sacohen
Ok I put that code in and the ATO_pump in the portal went to OFF and on my Andriod I have the green dot.lnevo wrote:Is this during the process or is this all the time? If it's all the time, it's possible one of the other checks we made is shutting it off.. I doubt the high ato is getting reached... but maybe the switch is flakey? More likely is the salinity probe. I've seen my ph probe bounce around sometimes and when you look at my charts it is not a stable number.. we can probe this like so..
Put that instead of the current salinity check. What will happen is that it will mask off the port.. You're ATO timeout will also probably kick in and you'll see the blue (iphone) or green (android) or it will be OFF instead of AUTO in the portal. If this happens we know its the salinity probe.Code: Select all
// Disable ATO if Salinity is below 33.5. if (ReefAngel.Params.Salinity<335) ReefAngel.Relay.Override(ATO_Pump,0);
So this says the Salinity probe is causing the problem even thought the salinity level is 35.9 ppt and the code say to disable it if it is below 33.5 ppt?
What next?
Thanks for the help.
It means your probe is fluctuating. I'll look through the code in the post Roberto mentioned...what we want to do is make sure salinity is at that level for x amount of time before we decide to turn off the ATO.
- Sacohen
You can just disable the salinity safety for now until we get you code to reenable...
Or you can live with it...
- Sacohen
Yes. that's fine.
Just put it back to what it was and comment it out is fine?
Comment it out. Doesnt matter which version
- Sacohen
Done. I'll keep an ear open for it and see if it stay off or comes on and goes threw to 34%.
Update:
Last night it came on and stayed on until it reach 33% then shut off, so it seems to be working right.
Just need to figure out the code for the salinity, but that's not a rush.
I'm going to take a look at that thread and see if I can find it.
If I find something I'll post it here before inserting it in my code just to make sure.
Update:
Ok, that code actually did a lot of things, but it did help me to put this together....
This will go right in place of the previous salinity check or whatever you currently left in place or commented
It would be helpful moving forward especially for readers of the thread and myself
if you would post your latest and greatest working code assuming this piece works for you
I'm fairly confident (I know it at least compiles...) but I've been there before too...Please test and let me know.
// Track Salinity low duration
static unsigned long lastGoodSal;
static boolean lowSalFlag;
// Salinity is good, update counter
if (ReefAngel.Params.Salinity>=335) lastGoodSal=now();
// Counter hasn't been updating in 120 seconds..
if (now()-lastGoodSal>120) {
lowSalFlag=true; // Salinity is definitely below 33.5
} else {
lowSalFlag=false; // Salinity back to normal
// Disable ATO if lowSalFlag is true
if (lowSalFlag) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
- Sacohen
I will try it in a bit.
I actually just created a PDE thread that I'm going to be storing the code and I'll add that to my signature.
- Sacohen
OK. It's working, kind of. The code you added to let the salinity stabilize is working.
What is going on is that it will start and run for 2 min (I didn't time it but it seems like 2 min) and then it will stop.
What's happening is as the RO water is going into the sump it is affecting the Salinity probe in the sump and bringing the reading below the 33.5ppt.
So if I extend the 120 period that you have it will let the pump run until it reaches the 34% level and will only disable the ATO if the salinity is below 33.5ppt before the ATO kicks in.
You can do that or you could move your ATO outlet further from the probe.
- Sacohen
I'm going to re-plumb my system in the next week or so to work the chiller in. I'll try to get the ATO outlet further from the probe.
Lol you Floridians..everyone else is unplumbing their chillers!
- Sacohen
Here is the final working code.
Many thank to lnevo for his help in doing this.
// Define Relay Ports by Name
#define Actinic_Lights 1
#define Day_Lights 2
#define Unused 3
#define Pumps 4
#define Sump_Fan 5
#define DeNit_Doser 6
#define DeNit_Pump 7
#define Unused 8
#define ATO_Pump Box1_Port1
#define Moon_Lights Box1_Port2
#define Unused Box1_Port3
#define Unused Box1_Port4
#define Unused Box1_Port5
#define Unused Box1_Port6
#define Unused Box1_Port7
#define Dummy Box1_Port8
// Does not need to be global.
// unsigned long ATOUpdate=0;
ReefAngel.WaterChangePortsE[0] = Port1Bit;
//Set Standard Menu
ReefAngel.AddStandardMenu();
ReefAngel.DCPump.FeedingSpeed=30;
ReefAngel.DCPump.ActinicChannel=Sync; // Now you're pump will be affected by the portal settings.
ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
ReefAngel.Relay.On( Pumps );
ReefAngel.Relay.On( Dummy );
ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
ReefAngel.StandardLights( Day_Lights,13,0,21,0 );
ReefAngel.StandardLights( Sump_Fan,13,0,21,0 );
ReefAngel.WaterLevelATO(ATO_Pump,720,31,34);
ReefAngel.Relay.Set( Moon_Lights, !ReefAngel.Relay.Status( Actinic_Lights ) );
// DeNitrate Routine
int DeNit_Offset=3600;
int DeNit_Repeat=21600;
int DeNit_Doser_Offset=1200;
int DeNit_Doser_Runtime=1200;
int DeNit_Pump_Runtime=1200;
int DeNit_ATO_Offtime=1500;
// Pump comes on first
ReefAngel.Relay.Set(DeNit_Pump,(now()-3600)%21600<1200); // Runs for 1200s every 21600 seconds
// Doser comes on second
ReefAngel.Relay.Set(DeNit_Doser,((now()-3600)-1200)%21600<1200); // Runs for 1200s every 21600 seconds with 1200s offset
// Disable ATO
if ( (now()-3600)%21600<1500) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
// Delay WL ATO after water change and DeNit_Dosing
static time_t wcTimer=0;
if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) wcTimer=now();
// First 10 minutes after WC disable ATO
if (now()-wcTimer >= 0 && now()-wcTimer < 600)
// Counter hasn't been updating in 300 seconds..
if (now()-lastGoodSal>300) {
} else {
// Disable ATO if ATO High IsActive()
// Modified to use the DCPump class
if (hour()<12 || hour()>=22) {
ReefAngel.DCPump.Mode=Constant;
ReefAngel.DCPump.Speed=30;
} else if (InternalMemory.DCPumpMode_read()==Custom) {
ReefAngel.DCPump.Mode=Constant; // Won't really be constant. See next line.
ReefAngel.DCPump.Speed=ElseMode(50,20,true ); // ElseMode on sync mode, 50 +/- 20%
} else {
ReefAngel.DCPump.UseMemory=true; // Use whatever is in the portal
ReefAngel.Portal( "Sacohen","Seth0310" );
int x,y;
// Parameters
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel() );
strcat(text," ");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,39,75,"Salinity:");
ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,99,75,text);
// Main Relay Box
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
// Date and Time
static unsigned long LastChange=millis(); // Set the inital time that the last change occurred
static int Delay = random( 500, 3000); // Set the initial delay
static int NewSpeed = MidPoint; // Set the initial speed
static int AntiSpeed = MidPoint; // Set the initial anti sync speed
if ((millis()-LastChange) > Delay) // Check if the delay has elapsed
Delay=random(500,5000); // If so, come up with a new delay
int ChangeUp = random(Offset); // Amount to go up or down
if (random(100)<50) // 50/50 chance of speed going up or going down
LastChange=millis(); // Reset the time of the last change
if (WaveSync)
return NewSpeed;
return AntiSpeed;
