lnevo's virtual outlets
rossbryant1956
Post by rossbryant1956 »
I was playing with Lee's code on virtual outlets, uploaded to portal, decided I don't understand them enough right now, took them out of my code, re-uploaded and now cannot get them to disappear from the portal.
How can I get the portal to return back to just the 3 relay boxes I have? Thx.
my current code:
    #include <WiFiAlert.h>
    // Custom Menu
    #include <avr/pgmspace.h>
    prog_char menu0_label[] PROGMEM = "Turn Lights On";
    prog_char menu1_label[] PROGMEM = "Turn Lights Off";
    prog_char menu2_label[] PROGMEM = "Start Feeding";
    prog_char menu3_label[] PROGMEM = "Start Water Change";
    prog_char menu4_label[] PROGMEM = "Clear Overheat";
    prog_char menu5_label[] PROGMEM = "Calibrate pH";
    prog_char menu6_label[] PROGMEM = "Calibrate Salinity";
    menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label  };
    #define Mem_B_SwabbieRepeat   115
    #define Mem_B_SwabbieTime     116
    #define Mem_I_CalDP1Vol       128
    #define Mem_I_CalDP1Time      130
    #define Mem_I_DP1Volume       132
    #define Mem_I_CalDP2Vol       134
    #define Mem_I_CalDP2Time      136
    #define Mem_I_DP2Volume       138
    #define Mem_B_MaintSkimmer    151
    #define Mem_B_PrintDebug      198
    #define Mem_B_ResetMemory     199
    void init_memory() {
    InternalMemory.write(Mem_B_SwabbieRepeat,6);
    InternalMemory.write(Mem_B_SwabbieTime,1);
    InternalMemory.write_int(Mem_I_CalDP1Vol,11);
    InternalMemory.write_int(Mem_I_CalDP1Time,600);
    InternalMemory.write_int(Mem_I_DP1Volume,30);
    InternalMemory.write_int(Mem_I_CalDP2Vol,11);
    InternalMemory.write_int(Mem_I_CalDP2Time,600);
    InternalMemory.write_int(Mem_I_DP2Volume,30);
    InternalMemory.write(Mem_B_ResetMemory,false);
    // Define Custom Variables for Portal
    #define Var_DPump1         4
    #define Var_DPump2         5
    #define Var_AcclDay        6
     // Define Relay Ports by Name
    #define DT_LightsOne       1
    #define DT_LightsTwo       2
    #define Unused3            3
    #define Unused4            4
    #define DT_LWM             5
    #define GT_LWM             6
    #define DosePumpOne        7
    #define DosePumpTwo        8
    #define Unused11           Box1_Port1
    #define Swabbie            Box1_Port2
    #define GT_LightsOne       Box1_Port3
    #define GT_LightsTwo       Box1_Port4
    #define DT_RWM             Box1_Port5
    #define GT_RWM             Box1_Port6
    #define DT_Heat            Box1_Port7
    #define DT_Pump            Box1_Port8
    #define RV_Heat            Box2_Port1
    #define RV_Pump            Box2_Port2
    #define GT_Heat            Box2_Port3
    #define Unused24           Box2_Port4
    #define GT_OverFill        Box2_Port5
    #define GT_Fill            Box2_Port6
    #define Skimmer            Box2_Port7
    #define GT_Pump            Box2_Port8
   // #define VO_RefillATO       Box3_Port1
   // #define VO_EnableATO       Box3_Port2
   // #define VO_StartFill       Box3_Port3
   // #define VO_Vacation        Box3_Port4
   // #define VO_AutoFeed        Box3_Port5
   // #define VO_Unused          Box3_Port6
   // #define VO_Calibrate       Box3_Port7
   // #define VO_LockPorts       Box3_Port8
    // Setup on controller startup/reset
        ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items)); // Initialize the menu
        ReefAngel.FeedingModePortsE[0] = Port8Bit; // Turn off on Box1 when feeding mode is activated is activated
        ReefAngel.FeedingModePortsE[1] = Port7Bit | Port8Bit; // Turn off on Box2 when feeding mode is activated is activated
        ReefAngel.WaterChangePorts = Port5Bit | Port6Bit ; // Turn off when water change mode is activated
        ReefAngel.WaterChangePortsE[0] = Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Turn off on Box1 when water change mode is activated
        ReefAngel.WaterChangePortsE[1] = Port3Bit | Port8Bit | Port7Bit | Port6Bit | Port1Bit; // Turn off on Box1 when water change mode is activated
        // ReefAngel.PHExpMin = 1832;
        // ReefAngel.PHExpMax = 2150;
        ReefAngel.TempProbe = T2_PROBE;  // Set the 2nd plug to be DT Main temp
        ReefAngel.OverheatProbe = T2_PROBE;  // to monitor the overheat and temperatures
        ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit;  // Items turned off when Overheat temperature exceeded
        ReefAngel.OverheatShutoffPortsE[0] = Port7Bit | Port3Bit | Box1_Port4;  // Items turned off on Box1 when Overheat temperature exceeded
        ReefAngel.OverheatShutoffPortsE[1] = Port3Bit | Port7Bit;  // Items turned off on Box2 when Overheat temperature exceeded
        InternalMemory.OverheatTemp_write( 829 ); // Set the DT Overheat temperature setting
        ReefAngel.LightsOnPorts = Port1Bit | Port2Bit; // Toggle Lights
        ReefAngel.LightsOnPortsE[0] = Port3Bit | Port4Bit; // Toggle Lights
   // Ports that default on
        ReefAngel.Relay.On(DT_Pump); // Turn on DT Pump
        ReefAngel.Relay.On(GT_Pump); // Turn on GT Pump
        ReefAngel.Relay.On(Skimmer); // Turn on Skimmer
   // Ports that default off
        ReefAngel.Relay.Off(Swabbie);
        CheckPower();           // Monitor for power outages
        CheckSwitches();        // Monitor for float switches
        RunSwabbie();           // Skimmer neck cleaner
        // RunDosingPumps();       // Dose by volume or time
        // LogDosingPumps();       // Keep track of dosing
        // CalibrateDPumps();      // Calibrate Dosing pumps
        DelayedOnModes(Skimmer); // DelayedOn after mode change only
        ReefAngel.StandardLights( DT_LightsOne,14,00,22,00 ); // DT Lights on at 2:00pm and off at 10:00pm
        ReefAngel.StandardLights( DT_LightsTwo,22,00,01,00 ); // DT-Moon Lights on at 10:00am and off at 1:00am
        ReefAngel.StandardLights( GT_LightsOne,14,00,21,45 );  //GT Lights Main 2:00pm - 9:45pm
        ReefAngel.StandardLights( GT_LightsTwo,15,00,22,30 ); //GT Lights Actinic 3:00pm - 10:30pm
        ReefAngel.WavemakerRandom( DT_LWM,60,100 );
        ReefAngel.Relay.Set( DT_RWM, !ReefAngel.Relay.Status( DT_LWM ) ); //Randomize DT powerheads
        ReefAngel.WavemakerRandom1( GT_LWM,60,100 );
        ReefAngel.Relay.Set( GT_RWM, !ReefAngel.Relay.Status( GT_LWM ) ); //Randomize GT powerheads
        StandardHeater1( DT_Heat,779,791 ); //DT-Heat
        StandardHeater2( GT_Heat,779,791 ); //GT-Heat
        ReefAngel.DosingPumpRepeat( DosePumpOne,0,720,5 );
       // if the hour is 2p or 8p, minute is 55 and seconds is 0, start the feeding mode
        if ( ((hour() == 14) || (hour() == 20)) &&
        (minute() == 55) &&
        (second() == 0) )
         ReefAngel.FeedingModeStart();
       // if the hour is between 1a and 6a, start the Reservoir Pump
         if (hour()>=1 && hour()<6)
         ReefAngel.Relay.On(RV_Pump);
         ReefAngel.Relay.Off(RV_Pump);
        // turn on RV_Heat when temp falls below 76.0 and turn off when temp gets above 80.0
         if (ReefAngel.Params.Temp[T3_PROBE] <= 780 && ReefAngel.Params.Temp[T3_PROBE] > 0) ReefAngel.Relay.On(RV_Heat);
         if (ReefAngel.Params.Temp[T3_PROBE] >= 791) ReefAngel.Relay.Off(RV_Heat);
        //turn on GT Fill when switch is tripped
         if (hour()>=19 && hour()<20)  // Turn on GT_Fill if water is needed
         ReefAngel.Relay.Set(GT_Fill,ReefAngel.IO.GetChannel(2));
         ReefAngel.Portal("rossbryant1956");
        // ReefAngel.Params.ORP=ReefAngel.PH.Read();
        void CheckPower() {
        static boolean powerOutage=false;
        static WiFiAlert powerAlert;
        if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY) && (!ReefAngel.Relay.IsRelayPresent(EXP2_RELAY))) // Expansion Relay NOT present
        powerOutage=true;
        ReefAngel.Relay.Off(DT_LightsOne);
        ReefAngel.Relay.Off(DT_LightsTwo);
        ReefAngel.Relay.Off(Port3);
        ReefAngel.Relay.Off(Port4);
        ReefAngel.Relay.Off(Port7);
        ReefAngel.Relay.Off(Port8);
        powerAlert.Send("Power+Outage!");
        if (powerOutage && ReefAngel.Relay.IsRelayPresent(EXP1_RELAY) && ReefAngel.Relay.IsRelayPresent(EXP2_RELAY)) // Expansion Relay IS present
        LastStart=now();
        powerOutage=false;
        ReefAngel.Relay.On(DT_LightsOne);
        ReefAngel.Relay.On(DT_LightsTwo);
        ReefAngel.Relay.On(DosePumpOne);
        ReefAngel.Relay.On(DosePumpTwo);
        powerAlert.Send("Power+restored.",true);
     // I_O Expansion & Float Valves
        void CheckSwitches() {
        static boolean GT_OverFillOverride=true;
        static WiFiAlert switchAlert, skimmerAlert, atoAlert;
        skimmerAlert.SetDelay(3600);
        switchAlert.SetDelay(3600);
       if (ReefAngel.DisplayedMenu==FEEDING_MODE || ReefAngel.DisplayedMenu==WATERCHANGE_MODE)
       // Turn off GT_OverFill if sump overflowing
       if (!ReefAngel.IO.GetChannel(3)) {
         if (!GT_OverFillOverride) {
         switchAlert.Send("GT_Sump+level+alarm!+MixPump+disabled.");
         ReefAngel.Relay.Override(GT_OverFill,0);
     } else {
        GT_OverFillOverride=false;
       // Turn off DT_Pump if sump overflowing
       static boolean DT_OverFillOverride=true;
       if (!ReefAngel.IO.GetChannel(0)) {
         if (!DT_OverFillOverride) {
         switchAlert.Send("DT_Tank+level+alarm!");
         ReefAngel.Relay.Override(DT_Pump,0);
     } else {
        DT_OverFillOverride=false;
        ReefAngel.Relay.Override(DT_Pump,2);
        // Turn off GT_Pump if sump overflowing
       static boolean GT_PumpOverFillOverride=true;
       if (!ReefAngel.IO.GetChannel(1)) {
         if (!GT_PumpOverFillOverride) {
         switchAlert.Send("GT_Tank+level+alarm!");
         ReefAngel.Relay.Override(GT_Pump,0);
     } else {
        GT_PumpOverFillOverride=false;
        ReefAngel.Relay.Override(GT_Pump,2);
       // Turn off Skimmer if waste collector is full.
       if (!ReefAngel.LowATO.IsActive()) { // switch is on by default
       skimmerAlert.Send("Skimmate+container+full!+Skimmer+disabled.");
       ReefAngel.Relay.Override(Skimmer,0);
       //if (InternalMemory.read(Mem_B_MaintSkimmer) > 0) // Reset last Skimmer counter
       //InternalMemory.write(Mem_B_MaintSkimmer,0);
       // Turn off Skimmer if Return pump has been shutoff.
       if (!ReefAngel.Relay.Status(DT_Pump)) {
      // Alert if ATO timeout flag
      if (bitRead(ReefAngel.Flags,ATOTimeOutFlag))
      atoAlert.Send("ATO+timeout!+ATO+disabled.");
      // Swabbie
      void RunSwabbie() {
      int repeat=InternalMemory.read(Mem_B_SwabbieRepeat)*60;
      int runtime=InternalMemory.read(Mem_B_SwabbieTime)*60;
      static time_t t;
      // Manual mode
      if (ReefAngel.Relay.isMaskOn(Swabbie)) {
      ReefAngel.Relay.Override(Swabbie,2);
      t=now();
      if (now()-t < runtime) {
      ReefAngel.Relay.On(Swabbie);
      } else {
      ReefAngel.DosingPumpRepeat(Swabbie,0,repeat,runtime);
      void DelayedOnModes(byte relay) {
      static unsigned long startTime=now();
      if (startTime==LastStart && ReefAngel.HighATO.IsActive()) {
      ReefAngel.Relay.On(relay);
      } else {
      ReefAngel.Relay.DelayedOn(relay);
      // Definitions for dosing pumps
    //  #define numDPumps 2
   //  byte pump[numDPumps]={ DosePumpOne, DosePumpTwo };
    //  byte varReport[numDPumps]={ Var_DPump1, Var_DPump2 };
     // byte memDPTime[numDPumps]={ Mem_B_DP1Timer, Mem_B_DP2Timer };
     // int memDPVolume[numDPumps]={ Mem_I_DP1Volume, Mem_I_DP2Volume };
     // int memDPRepeat[numDPumps]={ Mem_I_DP1RepeatInterval, Mem_I_DP2RepeatInterval };
     // int memCalTime[numDPumps]={ Mem_I_CalDP1Time, Mem_I_CalDP2Time };
    //  int memCalVol[numDPumps]={ Mem_I_CalDP1Vol, Mem_I_CalDP2Vol };
     // void RunDosingPumps() {
     // float rate;
     // byte dpTime;
     // int dpRepeat, calcTime, totalVolume;
   //   static byte doseTime[numDPumps]={
   //   InternalMemory.read(memDPTime[0]),
   //   InternalMemory.read(memDPTime[1])
   //   for (int i=0;i < numDPumps; i++) {
    //  dpTime=InternalMemory.read(memDPTime[i]);
    //  dpRepeat=InternalMemory.read_int(memDPRepeat[i]);
   //   rate=(float)InternalMemory.read_int(memCalVol[i])/InternalMemory.read_int(memCalTime[i]);
   //  calcTime=(InternalMemory.read_int(memDPVolume[i])/rate)/(1440/dpRepeat);
   //   totalVolume=rate*(dpTime*(1440/dpRepeat));
   //   if (dpTime!=doseTime[i]) { // Memory has changed.
   //     InternalMemory.write_int(memDPVolume[i], totalVolume); // Update volume
    //    doseTime[i]=dpTime;
    //  } else if (dpTime!=calcTime) { // Calculated time has changed.
    //    InternalMemory.write(memDPTime[i], calcTime); // Update time
    //    doseTime[i]=calcTime;
      // Make sure we're not calibrating
      //if (!ReefAngel.Relay.Status(VO_Calibrate))
      //ReefAngel.DosingPumpRepeat(pump[i], i*5, dpRepeat, doseTime[i]);
    // ReefAngel.CustomVar[7]=1;
     void StandardHeater1(byte HeaterRelay, int LowTemp, int HighTemp)
        if (ReefAngel.Params.Temp[T2_PROBE] == 0) return; // Don't turn the heater on if the temp is reading 0
        if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay); // If sensor 2 temperature <= LowTemp - turn on heater
        if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay); // If sensor 2 temperature >= HighTemp - turn off heater
   void StandardHeater2(byte HeaterRelay, int LowTemp, int HighTemp) //Heater for Grow Tank
        if (ReefAngel.Params.Temp[T1_PROBE] == 0) return;  // Don't turn the heater on if the temp is reading 0
        if (ReefAngel.Params.Temp[T1_PROBE] <= LowTemp && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay);  // If sensor temperature <= LowTemp - turn on heater
        if (ReefAngel.Params.Temp[T1_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay);  // If sensor temperature >= HighTemp - turn off heater
      // Globals for Params on Custom Main
    byte x,y;
    void MenuEntry1()
    ReefAngel.DisplayMenuEntry("Item 1");ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
    #ifdef RelayExp
    for ( byte i = 0; i < MAX_RELAY_EXPANSION_MODULES; i++ )
        ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
    #endif  // RelayExp
    ReefAngel.Relay.Write();
    void MenuEntry2()
    ReefAngel.DisplayMenuEntry("Item 2");ReefAngel.Relay.RelayMaskOn = 0;
    #ifdef RelayExp
        ReefAngel.Relay.RelayMaskOnE[i] = 0;
    #endif  // RelayExp
    void MenuEntry3()
    ReefAngel.DisplayMenuEntry("Item 3");ReefAngel.FeedingModeStart();
    void MenuEntry4()
    ReefAngel.DisplayMenuEntry("Item 4");ReefAngel.WaterChangeModeStart();
    void MenuEntry5()
    ReefAngel.DisplayMenuEntry("Item 5");ReefAngel.OverheatClear();
    void MenuEntry6()
    ReefAngel.DisplayMenuEntry("Item 6");ReefAngel.SetupCalibratePH();
    void MenuEntry7()
    ReefAngel.DisplayMenuEntry("Item 7");ReefAngel.SetupCalibrateSalinity();
    // End Custom Menu Globals
      int x,y;
      char text[7];
      ReefAngel.LCD.DrawDate( 6, 122 );  //6 pixels left, 122 lines down
      // I/O Expansion
      byte bkcolor;
      x = 14;
      y = 11;
      for ( int a=0;a<6;a++ )
      ReefAngel.LCD.DrawText(0,255,18,26,"GT");  //18 left, 10 down
      ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 37, text, Num8x8);
      ReefAngel.LCD.DrawText(0,255,57,26,"DT"); //57 left, 10 down
      ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 50, 37, text, Num8x8);
      ReefAngel.LCD.DrawText(0,255,94,26,"Res"); //94 left, 10 down
      ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
      ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 90, 37, text, Num8x8);
      ReefAngel.LCD.DrawText(0,255,16,52,"DT pH"); //18 left, 39 down
      ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 15, 65, text, Num8x8);
      ReefAngel.LCD.DrawText( 0,255,57,52, "GT pH"); //57 left, 39 down
      ConvertNumToString(text, ReefAngel.Params.PHExp, 100);
      ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 55, 65, text, Num8x8);
      ReefAngel.LCD.DrawText(0,255,100,52,"Sal"); //100 left, 39 down
      ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 98, 65, text, Num8x8);
      ReefAngel.LCD.DrawOutletBox( 12, 80, TempRelay );
       // Relay Expansion
      // Relay Expansion
      TempRelay = ReefAngel.Relay.RelayDataE[1];
      TempRelay &= ReefAngel.Relay.RelayMaskOffE[1];
      TempRelay |= ReefAngel.Relay.RelayMaskOnE[1];
      ReefAngel.LCD.DrawOutletBox( 12, 107, TempRelay );
    // ReefAngel.LCD.DrawGraph( 5, 5 );
Re: lnevo's virtual outlets
I think you have to take them out completely not just comment.
What did you not understand? Maybe we can talk through it.
rossbryant1956
thx, gone to movies. Will do that later tonite. Thx for offer, just finished implementing your skimmer and swabbie code, works like a charm!! Thx! Want to do dose pumps next so stay tuned.
rossbryant1956
I do remember seeing something in an old post that the system will pick up a reference to another relay box, even if commented out and then display that so I thought you right. However I did delete those commented out references and uploaded but the virtual outlet ports are still showing on the portal. Other ideas are welcome. Thx
rossbryant1956
gone this morning. thx
