need help getting kessil 360w's to work with RA
Reefbound
Re: need help getting kessil 360w's to work with RA
Ok the code loaded... and is now connected to the lights and they are on. When I connected the first wire to the light controller the blues came on first then, when the second wire was plugged the whites lit so it would seem its controlling them individually. by looking at your code it looks like you have them shutting down at 1800 and 1900 this pm is that correct?
Yes, I just copied the same settings you were using in your post.
Reefbound
Ok, the lights did not shut down, I want to try a timing change, as in, having them start and shut down at the same time using your code. When I get up in the very early a.m. I will load the code and see what happens.
Start and end at the same time will produce nothing.
You need to let it run for at least a few minutes.
I'm very confused on what is happening..
The wizard code should work, since everyone uses it.
I'm gonna load the code into a test controller and see what is happening.
Does the AP/DP change though the day?
Reefbound
No the ap/dp show a constant 100%. When I changed the times the first time the lights ramped up perfectly but did not shut down. that was with code generated by the wizard.
Last night when it did not shut down it was almost two hours past shut down time. Do I need to wait longer ? does it need more time.
I'll wait until I hear from you before I do anything.
Reefbound
Can it be that these a360's work differently than the 350's. The 350's have two separate channels for white and blues, whereas the 360's have a color channel and a intensity channel?
I think your libraries are screwed up or your code is getting messed up somewhere...theres no way that your lights would stay on and your ap/dp show at 100/100 when they should be off and that has nothing to do with the kessils
Reefbound
Thanks lnevo, Do you think I should uninstall the Audrino interface,delete the folders and try reinstalling?
Certainly a good move...
Do you have wifi? We can also try manually setting the ap/dp if you do to see if its doing what it should and take the kessil out of the equation.
Reefbound
Arduino software has been removed and files deleted, and has been reinstalled. Libraries version reports 1.0.9, Before I uninstalled I tried to check the version and nothing but red letters and numbers show in the window. What should I try next? the wizard or Roberto's last code on page six.
Let's try the wizard code and see what happens.
You can change the time to end in something like 10 minutes from now to see what you get.
This way we don't need to wait until the end of the day.
Like this:
I'm on PDT, so it's almost 9:00am. Change it to your appropriate time zone.
Like this:
ReefAngel.PWM.SetDaylight( PWMParabola(7,0,9,0,12,100,12) );
ReefAngel.PWM.SetActinic( PWMParabola(8,0,9,0,12,100,12) );
Reefbound
I set them to go off at 1:15pm e.s.t and they have not gone out as of yet. 1:21
Reefbound
100% on both.
Did you use military time?
Can you post the code you used?
Also, can you double check what time your controller is showing?
Reefbound
here ya go. I did use military time. Looking at the controller it's showing 02:28 pm...that's weird its not military.
ReefAngel.Relay.On( Port2 );
ReefAngel.PWM.SetDaylight( PWMParabola(9,0,20,0,12,100,12) );
ReefAngel.PWM.SetActinic( PWMParabola(9,0,13,15,12,100,12) );
And its still showing 100 for both channels?? Cause one should be 12 and the other should be something else.
Reefbound
lnevo, with that loaded code from above DP:92 AP:12 and the lights don't shut down.
I still want to see the r99 output but 92/12 is good to see some change...you kept saying 100...
One of your channels control brightness and the other is for color temp...so not being shut down is ok...
Btw, where did the 12 come from...have you tried putting 0 instead? The 12 is the min dim if your drivers flicker at lower percent..i dont know if that would be an issue with the kessil
Reefbound
Roberto, It was pleasure talking to you this evening and thank you for trying to figure this controller out. Unfortunately, I have discouraging news. AP: 0 DP: 0 and the lights are still on, all be it, very dim.
What next? should I plug them back into my timer for the night.
I think we will need to do what others do too.
We need to turn the ports on the relay box off so you get no power on the Kessils.
You are using it on port1 and port2 correct?
Use this in your code:
ReefAngel.StandardLights(Port1,8,0,20,0);
ReefAngel.StandardLights(Port2,8,0,20,0);
