Wifi - Error 23: XML SAX Parser & Bad Config
Piper
Post by Piper »
A few weeks ago I added an external antenna to my wifi adapter and updated the firmware to 4.00 at the same time. Since then I've been getting a much more reliable connection but I frequently get Error 23: XML SAX Parser error messages. Especially when I try to refresh/update from the Android App. I found this thread about changing the FlushSize so I did that tonight but when I try to save the config I get a *BAD CONFIG* error. get e posted below along with the exact message I get in Tera Term.
Since making the change to the FlushSize I can repeatedly refresh/update from Kurt's Android App with no more SAX errors. Just not sure what my Config Error is an if it's really a problem.
<4.00> save
Storing in config
*BAD CONFIG*
<4.00>
<4.00> get e
wifly-GSX Ver 4.00.1, Apr 19 2013 11:48:31 on RN-131
Beacon=100
Reboot=0
IF=UP
DHCP=ON
IP=[Internal IP of Wifi]
NM=255.255.255.0
GW=x.x.x.x
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=10
IdleTimer=3
CmdChar=$
DNS=68.94.156.1
Name=www.reefangel.com
Backup=backup2
Lease=300
FTP=208.109.14.133:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=80
FTP_mode=0x0
SSID=wlan_02
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=0
Linkmon-AP=0
Passphrase=[Wifi pass phrase]
EAP_Id=
EAP_User=
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
LaunchStr=
TimeEna=0
TIMEADR=129.6.15.28:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
~Charlie
Re: Wifi - Error 23: XML SAX Parser & Bad Config
I wouldn't worry much, but if you really want to get rid of that, you will need to restore to factory and go through the setup again.
But this time, you use the attached tera term macro attached.
Piper
Post by Piper »
Thanks, Roberto. I'm going to go with Plan A. It seems to be working just fine right now. Haven't had a SAX error since I made that change last night.
I think it's just a deprecated option.... not worth the rebuild :) I went through it and it was more painful then just leaving it alone :)
