I've been trying myself to code this but just not having any luck with it.
I have a Standard ATO and need to set a code so that the pump isn't recycling on and off repeatedly when the water splashes in the sump.
How do I code the ATO pump to turn on only when the LowATO is active for at least 5 seconds? Appreciate any help I can get. Thanks
ATO Adjustment
Re: ATO Adjustment
The code Roberto gave you in this thread is not working?
http://forum.reefangel.com/viewtopic.php?t=3944#p33300
Re: ATO Adjustment
Also... If you are using StandardATO then it should be using two float switches...spread them out a bit more because the standard ato function fills until the high switch is up and does not turn back on until low is back down...
Re: ATO Adjustment
No, I couldn't get that code to work.
Re: ATO Adjustment
It was only doing the part that said turn on for xx minutes every yy minutes. It ignored the low ato isactive part.
Re: ATO Adjustment
Impossible... unless you're code was in wrong, or the code needing that needed to be reversed depending on your switch status... can you post the code you used (full INO)
Re: ATO Adjustment
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding";
prog_char menu1_label[] PROGMEM = "Water Change";
prog_char menu2_label[] PROGMEM = "ATO Clear";
prog_char menu3_label[] PROGMEM = "Clear Overheat";
prog_char menu4_label[] PROGMEM = "Fuge Lights";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label };
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
;ReefAngel.WaterChangeModeStart();
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.Relay.Override(Port7, ReefAngel.Relay.Status(Port7)+1);
void MenuEntry6()
ReefAngel.SetupCalibratePH();
ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port6Bit;
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port2Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.LightsOnPorts = Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.StandardHeater( Port3,775,780 );
ReefAngel.StandardLights( Port4,9,0,21,0 );
ReefAngel.StandardLights( Port7,21,0,9,0 );
ReefAngel.StandardLights( Port8,10,0,20,0 );
ReefAngel.StandardATO( Box1_Port1,600 );
ReefAngel.StandardLights( Box1_Port2,1,0,13,0 );
ReefAngel.StandardFan( Box1_Port3,785,790 );
ReefAngel.DCPump.SetMode( ReefCrest,70,25 );
ReefAngel.DosingPumpRepeat(Box1_Port1,0,10,60);
int x,y;
// "Sammy's Reef"
ReefAngel.LCD.DrawLargeText (12, 255,18,8,"Sammy's Reef");
// Salinity Display
ReefAngel.LCD.DrawLargeText(0,255,15,30,"Salt");
ReefAngel.LCD.DrawLargeText(2,255,15,40,"1.025"); //(Delete this line when sensor is installed)
//ConvertNumToString(text,ReefAngel.Params.Salinity, 1000); (add this line when sensor is installed)
//ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,15,40,text,Num8x8); (add this line when sensor is installed)
// Water Level Display
/// To be added when expansion is purchased
// Left Power Head Display (Actinic)
ReefAngel.LCD.DrawLargeText (0,255,15,50,"L Wave");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),COLOR_BLUE,15,60,1);
//Right Power Head Display (Daylight)
ReefAngel.LCD.DrawLargeText (0,255,75,50,"R Wave");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),COLOR_BLUE, 75, 60, 1); //<Color, Pos From Right, Pos From Top, Decimal Placement>
// Temperature Display
ReefAngel.LCD.DrawLargeText(0,255,15,70,"Temp");
ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 15, 80, text, Num8x8);
// PH Display
ReefAngel.LCD.DrawLargeText(0,255,75,70,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 75, 80, text, Num8x8);
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 107, TempRelay );
Re: ATO Adjustment
It may be working now, I have to wait and see but looks it's been set this way for the afternoon and not gone above the low ato switch yet.
I added the {}brackets to the if and else code...could that have made a difference?
