psidriven
Posts: 5 Joined: Wed Oct 09, 2013 10:09 am
Post
by psidriven » Tue Oct 29, 2013 4:32 pm
I ran out of sockets on my relay box. is it safe to have two heaters on the plug and two powerheads on another plug using power strips?
Posts: 12857 Joined: Fri Mar 18, 2011 6:47 pm
Post
by rimai » Tue Oct 29, 2013 5:39 pm
What size are the heaters?
Post
by rimai » Thu Oct 31, 2013 4:43 pm
You should be ok
psidriven
Post
by psidriven » Fri Nov 01, 2013 8:17 am
thanks. what is a safe amp/volt limit for each outlet? probably do the same thing for my powerheads, though they probably use less juice than the heaters.
Post
by rimai » Fri Nov 01, 2013 8:21 am
5 amps each outlet, but the box has 10A total capacity
