Different modes?
anderzon_
Different modes?
I have seen that there are different modes, right now it's light on mode, and last I checked it was normal mode. What is it and how can I change it?
- Sacohen
Re: Different modes?
Where are you talking about?
In the Portal, on the Andriod App, or on the unit itself.
Lights on mode (if I understand the question) would be a manual override to turn the light on after the are set to go off.
For example the light turn off at 10pm, but at 10:30 you hear something strange in the tank and want to see what it is, you can turn the light override the off command and turn them on just to check things out and then turn them off again.
