Delay after water change
anderzon_
Right now I have it programmed so that the return pump, skimmer, heater, wave maker and ato turns of during water change mode. Can I do that there is a delay of 15 minutes on the heater and ato after I turned off the water change mode to return to normal mode? My heater is on port 1 and the ato is on port 4.
- Sacohen
Re: Delay after water change
Have you tried the wizard?
There is a setting where you can tell it what ports to delay after a start up.
The code would be like this...
ReefAngel.Relay.DelayedOn( Port1,15 );
ReefAngel.Relay.DelayedOn( Port4,15 );- lnevo
That won't work for heaters and ATO ports.. you'll need to implement your own delays.
Sacohen has code the suppresses the ATO after water changes for 10 minutes I beileve... although he's using the WaterLevel ATO. I believe I did some code for rossbryant to do similar for his ATO like device..
- Sacohen
Yes I forgot that you put that in.
The code the lnevo put in for me is ...
My ports are labeled so you would replace ATO_Pump with the port #.
Lnevo would you need a separate line for the heater and ATO or can you do it like this...
// First 10 minutes after WC disable ATO
if (now()-wcTimer >= 0 && now()-wcTimer < 600)
ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);Lnevo would you need a separate line for the heater and ATO or can you do it like this...
ReefAngel.WaterLevelATO(Port1, Port4 ,720,0,1);- lnevo
You're missing these line which needs to come first.
For the heater, you could do similar to the WaterLevelATO with bogus temps to make sure it doesn't go on...
static time_t wcTimer=0;
if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) wcTimer=now();
anderzon_
Thanks:) Was not quite clear in my last post. My ato is a separate ato I have only connected on port 4, I can use it with standard delay, I have simply missed this. The heater, however, I want to start 15 minutes after the return pump skimmer etc. The reason for this is that the during water change the water drops so that it is above the surface.
The standard delay wont work with the ato either...both will require similar code to what steve and i posted.
skehole
So, for example, I use an auto Aqua smart ATO unit that is controlled by RA only in that it is plugged in to my relay. This will require a custom bit of code and not a standard delayed start in the wizard?
If so, why? I'm simply curious.
Try the delayed start first. If that doesn't work the way you want, let us know.
