Im in the market for my first controler , but is the Reefangel the right controler for my needs ?
and please try not to answer with abbreviations or acronyms... know what i mean..
So this is the list of what my controler will have to do (OUT OF THE BOX) and i really mean out of the box...!!!
In other words, if i order a unit kit, that unit kit should have all the necessary parts included.
1- the controller must be able to turn off and on the Heater according to the water Temp ! especially in case the heater get stuck On.
2- The controller has to be able to send an email, or a phonetext in case something goes wrong.
3- An access to the controler wired or wirelessly via a computer or iphone or galaxy ,,,
4-In case of a poweroutage!!! , the controller has to inform me in real-time real quick!.
5-My Ato is a tunze, so if the RODI pump get stuck, it has to stop the rodi pump
6- Not a must, but my powerhead is a Jebao Wp25, if someday i get rich ill get a vortech.. so the controler has to be able to simulate waves or to manually shut down powerhead for feeding within a single click.. on both Jebao and vortech.
7- Lighting : I heard that Evergrow LED (AKa reefbreeders) can not be controlled by any controller unless modified...
Since i don't intend to modify my LEDs... i need a controller that can control a wide range of LED especially the cheap china LEDs. By controlling i mean DIMMING and simulate cloudy, storms, raining, sunset, dawn conditions..
8- Has to be able to detect PH,
9- Has to be able to detect water leak or flooding on the floor and send (email me) if that happens.
10- some form of compatibility with the upcoming mindstream water test analysis.
So is the Reef Angel the right controller out the box ? if not, which module do i need ?
LAstly, it is difficult to determine which ReefAngel unit you need. Because the Digital dimming and analog are two distinct unit, so what happen if you need the analog and then upgrade something which require the Digital ? or worst, what if you are using both analog and digital lighting ?
Remember,,,,, no abreviation or acronyms...thanx!
