Jabeo controller help
My jabeo controller went out on me last night, I was wondering if there was anyway I could DIY my own controller? Has anyone done this? I know the reef angel can control it, but I don't have enough cash to buy a reef angel.
Re: Jabeo controller help
http://www.fish-street.com/jebao_wp-40_ ... gory_id=35
order a replacement probably the easiest route...
Not looking to order a new one really I understand it's easiest but this is twice its gone out on me don't wanna keep tossing cash into just the controller
You could build one out of an arduino. But some soldering and coding may/would be acquired.
Sent from my XT912 using Tapatalk
Which is why I came here as I know RA is adruino basedjohniii wrote:You could build one out of an arduino. But some soldering and coding may/would be acquired.
I will send a pm
johniii wrote:I will send a pm
I can't pm back yet, says I'm not authorized
What's a lpf? I have a dimmer knob I was using to control the speed of the pump
You gotta have so many post to pm. Lpf=low pass filter. It will smoothen the pwm signal to a closer to linear one. Requires a resistor and capacitor.
Alright, and pretty sure I can do adruino I use to code java for a game I hosted.johniii wrote:You gotta have so many post to pm. Lpf=low pass filter. It will smoothen the pwm signal to a closer to linear one. Requires a resistor and capacitor.
Alright so I need an adruino board a low pass filter a pwm and a converter correct?
+1 to this. Under 30.madboy007 wrote:you can buy a cheap one on ebay!
I found all the stuff on eBay. My controller started working again but I'm selling the pump as I'm getting a vortech for xmas
