My Jebao "Else" mode
cjrudy
Re: My Jebao "Else" mode
So if you pick reefcrest it automatically runs them in anti sync mode ?
- Sacohen
The setting under Internal Memory in the Portal are only Mode, Speed and Duration. You can't change anything else through the portal.cjrudy wrote:Can the portal set anti sync modes ?
I don't think so. How can it do an anti sync if you only have 1 pump?cjrudy wrote:So if you pick reefcrest it automatically runs them in anti sync mode ?
cjrudy
Ill be setting up my second today, Lee said above thy automatically run one sync one anti sync
You define it in the wizard which pumps are sync which are anti-sync...
I dont know the syntax but something like this..
ReefAngel.DCPump.Daylight=Sync;
...Actinic=AntiSync;
..channel0=Sync;
However you define it is how it will run.
..channel0=Sync;
- Sacohen
This is the code the wizard generates....
ReefAngel.DCPump.DaylightChannel = AntiSync;
ReefAngel.DCPump.ActinicChannel = Sync;-
cjrudy
I have both pumps, WP25 and WP40 set up and running in Else mode, one sync one antisync
So far so good, love the randomness of the Else mode
- Sacohen
I set my 25 up this weekend and have the 40 (Sync) and 25 (Anti-Sync).
I like the flow. The 25 is placed toward the bottom of the tank and really is just blowing behind my reefscape and pointed up a bit to keep things moving.
I have the 40 at 40,20 (so it runs from 60% to 20%) and the 25 is running 80, 20 (100% to 60%). It seems to work real nice.
cjrudy
So if both mine are set at 70, 30 then they're really not running up to 100% ??
How does this work ?
- Sacohen
The way I understand it is that the 70 is you base or center point and it will vary 30% above and below that center point. So if I have it correct you would be running 100% to 40%.
Here is a partial quote from cosmith71 in the original post about how it works...
cosmith71 wrote:Call with ElseMode( MidPoint, Offset, Sync );
Where Midpoint is the middle of the range you want, and Offset is the +/- range. Sync and anti-sync are opposites (true for sync or false for anti-sync) For example, ElseMode ( 70, 30, true ) will return values from 40% to 100%. The speed changes every 0.5 to 5 seconds and can be anywhere in between MidPoint +/- Offset.
- cosmith71
What Steve said.cjrudy wrote:So if both mine are set at 70, 30 then they're really not running up to 100% ??
They will run at anywhere from 40 (70-30) to 100 (70+30).
cjrudy
Ok, I get it now.......thanks
anderzon_
Hi
Ive tried to get this work but it doesn't work. Where in the code should I paste the code.
Here is my code:
Here is my code:
#include <ReefAngel_Features.h> #include <Globals.h> #include <RA_Wifi.h> #include <Wire.h> #include <OneWire.h> #include <Time.h> #include <DS1307RTC.h> #include <InternalEEPROM.h> #include <RA_NokiaLCD.h> #include <RA_ATO.h> #include <RA_Joystick.h> #include <LED.h> #include <RA_TempSensor.h> #include <Relay.h> #include <RA_PWM.h> #include <Timer.h> #include <Memory.h> #include <InternalEEPROM.h> #include <RA_Colors.h> #include <RA_CustomColors.h> #include <Salinity.h> #include <RF.h> #include <IO.h> #include <ORP.h> #include <AI.h> #include <PH.h> #include <WaterLevel.h> #include <Humidity.h> #include <DCPump.h> #include <ReefAngel.h>
void setup() { // This must be the first line ReefAngel.Init(); //Initialize controller ReefAngel.SetTemperatureUnit( Celsius ); // set to Celsius Temperature
ReefAngel.Use2014Screen(); // Let's use 2014 Screen // Ports toggled in Feeding Mode ReefAngel.FeedingModePorts = Port6Bit; // Ports toggled in Water Change Mode ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port8Bit; // Ports toggled when Lights On / Off menu entry selected ReefAngel.LightsOnPorts = 0; // Ports turned off when Overheat temperature exceeded ReefAngel.OverheatShutoffPorts = Port1Bit; // Use T1 probe as temperature and overheat functions ReefAngel.TempProbe = T1_PROBE; ReefAngel.OverheatProbe = T1_PROBE; // Set the Overheat temperature setting InternalMemory.OverheatTemp_write( 270 );
// Feeeding and Water Change mode speed ReefAngel.DCPump.FeedingSpeed=0; ReefAngel.DCPump.WaterChangeSpeed=0;
// Ports that are always on ReefAngel.Relay.On( Port2 ); ReefAngel.Relay.On( Port3 ); ReefAngel.Relay.On( Port4 ); ReefAngel.Relay.On( Port5 ); ReefAngel.Relay.On( Port6 ); ReefAngel.Relay.On( Port8 );
////// Place additional initialization code above here }
void loop() { ReefAngel.StandardHeater( Port1,250,254 ); ReefAngel.StandardLights( Port7,17,0,20,0 ); ReefAngel.DCPump.UseMemory = true; ReefAngel.DCPump.SetMode( ReefCrest,100,10 ); ReefAngel.DCPump.DaylightChannel = Sync; ReefAngel.DCPump.ActinicChannel = Sync; ////// Place your custom code below here
// This should always be the last line ReefAngel.Portal( "anderzon_" ); ReefAngel.ShowInterface(); }- cosmith71
After this line. Can someone else chime in on the DCPump stuff? I don't use it. I really should break down and get the WiFi unit for this tank.anderzon_ wrote:Hi
Here is my code:
ReEfnWrX
Hey Guys,
Just got my RA connected and trying to add in Else mode as well as a schedule to go from Else(Higher speed) to Nutrient to Else(lower speed)
Schedule is
Else(Higher speed) - 11am-8pm
Nutrient Transport - 8pm-11pm
Else(Lower speed) - 11pm-11am
So I added the Else code at the very end of everything.
When calling the modes in the custom section, I removed the Actinic(antisync) lines since I only have one WP-40. Will this affect anything?
Other than that, is the way i implemented the code correct? Based on the codes I have seen I'm guessing that
//This should always be the last line //Is not always the last line?lol
Schedule is
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port7Bit;
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port4Bit;
ReefAngel.StandardHeater( Port1,775,780 );
ReefAngel.StandardLights( Port2,21,30,12,0 );
ReefAngel.StandardLights( Port3,12,0,21,30 );
ReefAngel.MHLights( Port4,14,0,20,30,5 );
ReefAngel.SingleATO( true,Port7,300,0 );
ReefAngel.StandardLights( Port8,12,0,21,45 );
ReefAngel.DCPump.SetMode( ReefCrest,75,10 );
if (hour()>=11 && hour()<20)
ReefAngel.PWM.SetDaylight( ElseMode(70,20,true) ); // ReefCrest at 70% +/- 20% on sync mode
else if (hour()>=20 && hour()<23)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(40,80,200,true) ); // Nutrient Transport 40%minspeed - 80%maxspeed - 200ms
else if (hour()>=23 && hour()<11)
ReefAngel.PWM.SetDaylight( ElseMode(45,15,true) ); // ReefCrest at 45% +/- 15% on sync mode
ReefAngel.Portal( "ReEfnWrX" );
if (WaveSync)
return NewSpeed;
return AntiSpeed;
}- cosmith71
LOL, yeah, it's not always the last line. It should be the last line of the loop() function, though. You could actually put it before setup() if you like, it's just a style choice.
I don't use the DCPump stuff, so I can't advise on that. If it were me, I'd remove it all since your code isn't using it (you're writing directly with the PWM.SetDaylight function).
Otherwise looks fine.
- Sacohen
My code is setup to use the DCPump.
lnevo also set it up to randomly choose a mode from a designated list which Else Mode is part of.
It is actually running the Else mode today.
A link to my code is in my signature.
ReEfnWrX
By remove it, you are saying to remove the line #include <DCPump.H>
Also, I just uploaded the code, I changed the current time on the controller to 9am and the Daylight dimming shows it slowly fluctuating between 80-90 so far does not seem like Else mode at all... This does not seem to be working correctly since it should be 45% with a 15% swing.
- cosmith71
Remove this stuff:ReEfnWrX wrote:By remove it, you are saying to remove the line #include <DCPump.H>
ReefAngel.DCPump.ActinicChannel = None;-
ReEfnWrX
So I removed those lines and reuploaded.
Now on the controller it shows 0 for Daylight Dimming, there is no activity and the pump is now off
if (WaveSync)
return NewSpeed;
return AntiSpeed;
ReEfnWrX
Ok, so when the controller is inbetween 11pm-11am (Slower speed Else) it stops adjusting the pumps speed.
If I change controller time to after 11am for Else(Faster speed) it works properly.
It's a commonly made logic mistake...
You can't have an hour greater than 23 AND less than 11.
&& = AND
|| = OR
So you can change the && to || to fix that last else if statement
&& = AND
|| = OR
ReEfnWrX
You know, 15 years ago I would have told you, the reason I will not get into coding is because if I spend hours trying to find that one space or character that is out of place, I would throw my computer through my window.....
Good thing I have calmed down with age
- cosmith71
Change this:ReEfnWrX wrote:Ok, so when the controller is inbetween 11pm-11am (Slower speed Else) it stops adjusting the pumps speed.
else if (hour()>=23 && hour()<11)Code: Select all
else if (hour()>=23 || hour()<11)Edit: Sorry, didn't see that Lee had chimed in.
anderzon_
Thx, Do I need this in my custom code:cosmith71 wrote:After this line. Can someone else chime in on the DCPump stuff? I don't use it. I really should break down and get the WiFi unit for this tank.anderzon_ wrote:Hi
Here is my code:
if (ReefAngel.DCPump.Mode==Custom) { ReefAngel.PWM.SetDaylight( ElseMode(70,30,true )); // ElseMode on sync mode, 70 +/- 30% ReefAngel.DCPump.UseMemory = false; } else { ReefAngel.DCPump.UseMemory = true; } static time_t StartFeeding=0; if (ReefAngel.DisplayedMenu==FEEDING_MODE) StartFeeding=now(); // if we entered feeding mode, register what time it was. if (now()-StartFeeding > 1800 && now()-StartFeeding < 5400) // if feeding started between 1800 and 5400 seconds ReefAngel.PWM.SetActinic(100); else ReefAngel.PWM.SetActinic(45);
And below my portal name the rest of the code. Should I then change to custom portal?
- Sacohen
anderzon_
If I use this code, I can then switch between this and other programs through the portal?
Temperature
} else {
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 62, ReefAngel.Params,
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 107, TempRelay );
if (WaveSync)
return NewSpeed;
return AntiSpeed;
- Sacohen
I'm not the best with code, but it looks like you have it to run ReefCrest mode unless you put it in custom and then it will run Else mode.
Is that what you want?
anderzon_
right now I run reef crest. I want to be able to choose between programs from the portal.
howaboutme
I am just plugged in my wp-25 last night and have it running on constant mode at a low power %. I created the code from the Wizard. Now I cant to get into something similar to what's in this thread but I am at a lost as to where to begin. I have been trying to look through codes and comments and have been getting confused. What is also confusing me is that this (and others) are older threads and I know that the current libraries have all (or most?) of the wave patterns built in which simplifies the code. For those reasons, I don't want to just do some copy and pasting and have things not go right.
I like this thread because it's dealing w/ else mode w/ 1 pump (or at least it started out this way) and that's my current set up. What I eventually want to do is use the else mode when the lights are on and then ramp down the pump the remainder of the day/night at a low power (like 30%, constant). But before I get into the schedule code, I want to get the else mode to work.
First question:
Where does this go in the code?
Or is it not code since i dont even see the exact wording in other codes.
2nd question:
Can anyone help me (based on the code in this thread for 1 pump) figure out what the code is? The only difference is I do not want the pump to go higher than 45% (assume lowest is still 30%) and I have my 1 pump plugged into the actinic port. I may adjust that later as I get my tank accustomed to the extra flow. There never was one last post on this thread that states what the correct code is after reconciling all of the problems, questions, answers, etc.
3rd question:
Will I be able to make adjustments on the fly for this mode and will I be able to switch to the pre-set modes via the portal?
Excuse me if these have been answered in 1 way shape or form. It's just confusing for a newbie when I reconcile different posts about the same, or somewhat the same, subject matter. Thanks in advance!
First question:
Call with ElseMode( MidPoint, Offset, Sync )2nd question:
3rd question:
Jack
- cosmith71
Put this in your loop() section:
This will get you a range from 30-44% 37 +/- 7%). The "true" sets sync mode, which really doesn't matter since you're only using one pump. It has to be there for the sake of proper syntax.
I have no clue about the Portal question. I don't use it that way. Maybe someone else can chime in?
Hope this helps,
ReefAngel.PWM.SetActinic( ElseMode(37,7,true)); // ElseMode on sync mode, 37 +/- 7%I have no clue about the Portal question. I don't use it that way. Maybe someone else can chime in?
Hope this helps,
